Citrabria Aerobatic Pro scale size?
NJ
RE: Citrabria Aerobatic Pro scale size?
I think you'll find the "Pro" is close to 1/5 scale. As far as I know the full scale "Pro" has a wing span of 33' 5" or when converted to inches is 401". Divide 401" by the 80" wing span of the Balsa USA "Pro" and the answer is 5 with 1" remainder. Because 80" is approximately 1/5 of 401", the BSA "Pro" is 1/5 scale. I could be wrong on the wing span of the full scale "Pro", so if I am, simply recalculate with the correct wing span (in inches) and you get the answer.
Good luck,
DaveB
Good luck,
DaveB
