Painting On Monokote? No Flat Black Lusterkote anywhere.
Hello all,
Iwould like to paint the top front of my TFCorsair flat black from the cockpit to the front on the cowl.Ihave searched for flat black lusterkote and can't find any. My question is...What kind of flat black paint will work over monokote, and then Ihave a can of clear lusterkote to go over the top of the flat black. Has anyone done anything like this? Please let me know how Ican make this happen. Thanks!
My Feedback: (15)
CA
RE: Painting On Monokote? No Flat Black Lusterkote anywhere.
One other option is tape the Monokote down and use 0000 steel wool, it takes some elbow grease but I was able to make a great looking non glare or flat black section of Monokote for my Astro Hog. Obviously not as cool as a Corsair though! The black section on the hood is the steel wool Monokote, it holds up great and easy to clean.
TX
I used some of that new paint that is suppose to stick to plastic surfaces - however in my quest to get finished fast I assumed (i know, i know) it would stick to the monocote on my Decathlon but it is flaking off. If I was to do this again I would sand the monocote down and be sure to use a good masking tape cause some places it found it's way under the tapes edge. Good luck!
IL
It's disappointing how little Lustrekote it available. They use to have tons of colors, but now are just down to a handful.
Idid a test paint on an older plane and it turned out really well. Isanded the monokote with 1000 grit (600 would be fine or scotch brite) thenwipe it down with alcohol. I used a small can of universal black glossauto paint from checker auto I had laying around, and sprayed a flat clear over the top of that, and it looks really good. Nice flatlook.I tried to put scratches in it with my fingernails and all it did was leave a little dullmark. It didn't come off the monokote.
