3 bladed prop for a DLE-20 gasser
Hi
Being new to this sport after years of absence I wonder if any one can advise me
I have recently purchase a Hanger 9 F4U .60 Corsair [HAN2725]
For this I have a new DLE-20 gasser and would like to fit a 3 blade prop
Can anyone recommend a carbon fibre or composite material unit suitable
As this has not been run in I will need 2 sizes
Your advice is greatly appreciated
OZ Flyer
OZ Flyer
RE: 3 bladed prop for a DLE-20 gasser
The available selection of three blade props is pretty limited. If you are willing to use a two blade it will be a lot easier to find a match for the engine/airplane and your flying style.
A commonly used two blade for this engine is a 16x8
A 14x9 three blade (Master Airscrew makes one) would be slightly less load on the engine than the 16x8 two blade
A 15x7 three blade (Master Airscrew makes one) would be slightly more load on the engine than the 16x8 two blade
My Feedback: (-1)
In the gas engine forum I think there is a page on the DLE 30 with the different props people have used and RPM readings. You may want to go there ans see if they posted one for the 20. Three blades are hard to find in hobby shops these days and spinners are even harder to locate unless you order them for places like Truturn.
Hi Guys
I would like to thank you for the information on prop choices
I have purchased a Master Airscrew 15x8 to run this in then I intend to increase this to a 16x8
You are right 3 blade units are rare
so once again your input is appreciated
Good weather and fine plane is music to my ears
As soon as old faithful is up and runnning i wiil post photos
Cheers OZ Flyer
Cheers OZ Flyer
Engel make some small 3-blade carbon propellers.
http://www.engelmt.de/en/index.php
Including:
13.5x13.5 3-blade
15x11 3-blade
15.5x13 3-blade
I think 3-blade propellers are more suitable for larger models, as a way of reducing noise. A 3-blade propeller normally has a smaller diameter than a 2-blade propeller of similar load, therefore the propeller tip speed will be lower and hence less noise. This should not be necessary on a 20cc motor. With that motor you would probably want to use the most efficient propeller available, and that would be a good 2-blad prop.
Magne
Including:
13.5x13.5 3-blade
15x11 3-blade
15.5x13 3-blade
Magne
ok so i'm bringing this topic back to life as i have a DLE-20 on a ESM Stuka and was wondering if anyone has had any experience with the 3 blade props for thsi engine. I'm thinnk a Biela 3 bladed16x10 ?
hi , im thinking to use thee blade prop on dle 20 the engine on P47 i guess it will sond better and look more scale but after i read what you said i think im going to keep it simple 16x8 prop , thanks ,
