BIG HOTS cg ????????????
Reply
Old 11-19-2010, 10:29 AM
coachdavis10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default BIG HOTS cg ????????????
i'M ASKING THIS HERE BECAUSE OF THE NUMBER OF BUILDERS THAT READ HERE. i'VE BEEN FLYING A BIG HOTS I GOT FROM A FRIEND FOR A FEW NONTHS.... I WAS IN THE MIDDLE OF BUILDING A BIG HOTS WHEN I GOT THIS ONE. I HAVE FINALLY COMPLETED MINE AND BALANCED IT YESTERDAY... MAJOR TAIL HEAVY. TOOK LIKE 2 POUNDS HANGING OFF THE PROP TO BALANCE. I NEVER CHECKED THE ONE I GOT FROM A FRIENS BECAUSE IT HAD BEEN FLOWN AND SO ON AND SO ON... I DECIDED TO BALANCE IT... IDENTICAL TO THE ONE I BUILT... WHAT ICAN'T FIGURE IS THIS IS THE BEST FLYING AIRPLANE I OWN... I WAS UNDER THE ASSUMPTION THAT TAIL HEAVY PLANES "WILL NOT" FLY.... fINALLY TO MY QUESTION... tHE CG ON THE PLANS IS 6 1/2"FROM LEADING EDGE... DOES ANYBODY KNOW IF THIS IS CORRECT? DID ANYBODY FIND THIS TO BE INCORRECT ?
coachdavis10 is offline
Old 11-20-2010, 04:06 AM
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BIG HOTS cg ????????????
Usually on the main spar.
john josey is offline
Old 11-20-2010, 04:15 AM
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may find this of some interest.
http://www.rcuniverse.com/forum/m_96...tm.htm#9625675
Old 01-30-2011, 06:36 PM
mwhar760
mwhar760's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the plans i have shows right at 7" from leading the edge ???? how much control throws do you have in your flight surfaces???/ i have no idea where to start???? i'm in the finishing stages on mine i have a pretty good 4.2 sachs i mounted in mine.
ID:	1556102   Click image for larger version
ID:	1556103   Click image for larger version
mwhar760 is offline
Old 01-30-2011, 07:57 PM
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CG starting point is where shown on the plans then after flight testing you can start moving the CG around to suit yourself. Control throws on a new plane are about 10 to 12 degrees on elevator and ailerons, as much as you can get from rudder.
Gray Beard is offline
Old 03-09-2011, 06:32 PM
Postman2
Postman2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mwhar760
the plans i have shows right at 7'' from leading the edge ???? how much control throws do you have in your flight surfaces???/ i have no idea where to start???? i'm in the finishing stages on mine i have a pretty good 4.2 sachs i mounted in mine.
Nice plane. I have had some plans of this plane for sometime. I have a 60size Hots and love the way it flys. I bought if frm a guy relocating abt 5 yrs ago. However, I have but one such experience at building from plans and that was at a club members shop. I was wondering if the lighting holes were addition/ modification? My main hangup wud be cutting out the wing ribs all the same. Anyway, like to see pix when ur finished. I like it.
Postman2 is offline
Old 03-10-2011, 11:10 AM
mwhar760
mwhar760's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had the laser cutter cut the short kit he did all that and also made the holes for the 48" wing tube to make mine a 2 piece wing!!! http://lazer-works.com/list.htmlhere are some finished pic's still waiting for the servo's
ID:	1576489   Click image for larger version
ID:	1576490   Click image for larger version
ID:	1576491   Click image for larger version
ID:	1576492   Click image for larger version
mwhar760 is offline
Reply
Display Modes
