I WANNA BUY NEW KIT
Motor Details :-
Rotational Speed <o></o> | 2600 RPM/V<o></o> |
Free Load Current <o></o> | 2.0A |
Max. Current <o></o> | 8A-20A |
Input Voltage <o></o> | 6 - 22V<o></o> |
Max. Efficiency <o></o> | 98%<o></o> |
Weight<o></o> | 44.46g<o></o> |
Motor Dimensions (Diameter x Length) <o></o> | 27.8mm x 23.0mm<o></o> |
Shaft Diameter <o></o> | 3.00mm (Front and Back)<o></o> |
Speed contorller requiement<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="30" unitname="a"></st1:chmetcnv><o></o> | 20A |
Input <st1lace>Battery</st1lace> Types <o></o> | NiCd/ Nimh/ Li-po <st1lace>Battery</st1lace><o></o> |
Recommend Model <o></o> | Airplane |
looking for a siutable kit for low cost..............
Unless you gear the motor down.
Good luck,
Mike
