Sr. Telemaster - Candy Drop
FL
:idea:
Am just finishing the fuse for a Sr. Tele and want to build-in a drop to be used for candy at club functions, parachutes, etc.
Have a latch but have no idea how to go about doing this -
If any one has done this or any ideas would appreciate hearing from you -
I have seen one in a traner. All they did was cut out the bottom, and hinged it on one side. They then got then got a micro servo, and set it up on the side. It was connected using a torque tube. When closed, the torque tube is at about 30-45 degrees from the side, so the the door can be opened all the way to ninety degrees. Don't forget to add some reinforcement.
Hope this helps.
Hope this helps.
