4 Star 40 Wing question
Recently moved across country and misplaced my 4 Star Plans. Doing a re-build after a winter crash , and have run into a problem. is the bottom of the wing flush with the fuselage? I'm getting everything dialed in before covering,mounting the wing, and things don't look right! The the rear bottom of the wing is not flush with F3. the front bottom of the wing is flush with f2, so i'm a little confused. Any help would be greatly appreciated. Thanks for your time
RE: 4 Star 40 Wing question
Thank You so much guys. The picture of the plans was perfect. It also showed me the balance point and wing incidence, stuff i'll need a little down the road. Going to finish mounting the wing tonight, and hopefully start covering by the weekend. Thanks again for your time and energy
