Canopy Glue
Canopy Glue
Well, my bottle of RC-56 finally ran out. I remember hearing somewhere that this stuff is no longer produced.
So what is a good substitute? Got to dry clear, ya know...
Steve
Steve
Canopy Glue
Steve:
Yes, RC-56 is no more. But. Pacer has their "Formula 560" which, as near as I can tell, is the same stuff with a slightly different name.
Dennis:
Screws? No, thank you. The canopy tends to crack around them, at least for me. Exception is a Lexan canopy, they hold up very well. But how do you know it's Lexan?
And a big definite NO! on electrical tape. Get fuel anywhere near it and it's an immediate mess.
Just my experiences.
Bill.
Dennis:
Bill.
My Feedback: (26)
Canopy Glue
I have had problems with cracking around canopy screws as well. Any of the canopy glues with "56" or "560" in them seem to be the same formula. Last time I checked there was about three brands out there. Check Tower Hobbies. If you can cut away a small stripe of covering, the glue adheres to the wood better than the covering. I just finished a Decathlon and used RC 56 to glue the windows against the covering after punching a bunch of pin holes where it attaches.
Canopy Glue
I've had trouble with cracking around canopy screws, as well. The fix is to cut small rounds of fuel tubing and fit them over the screws - just like washers. Works well and they don't vibrate loose either.
GA
Canopy Glue
I've used Formula 560 and agree it works well. But I find using it a nerve-wracking process because the stuff is thin and wants to run everywhere (at least it dries clear!) Does anyone have any tips on how to get good coverage without making a mess?
AZ
Canopy Glue
I use the 560 but I put it in a small glue gun syringe which will let me apply a very small bead. I agree, it is thin, and wants to run all over, and the water clean-up isn't as easy as they make it out to be. I have a squirt bottle and paper towels handy every time I do one.
I also agree with cutting a small strip of film away (if the plane is covered with film) so you can glue to the bare wood. And I don't like screws.....never have seen a full scale plane with the canopy screwed on (grin).....
A good tip: once in place, use Ace bandage....the type that stretches and sticks to itself, to wrap around the canopy and fuselage to hold the canopy down tight while the glue dries. I don't like to use tape, it can pull the covering loose.
Clair Sieverling
Clair Sieverling
Canopy Glue
I also direct my exhaust down and don't have trouble with the tape. One plane has thirty or so flights on it and the tape still seems fine.
Dennis-
NY,
Attaching canopy
After I apply the glue to the canopy, I use lengths of fuel tubing to hold it down to the fuse while drying. The tubing doesn't loosen up.
My Feedback: (23)
Canopy Glue
Has anybody tried clear silicone adhesive (the Home Depot bathroom caulk kind) as canopy glue? It works great for sealing fuel tanks and/or fuel tubing on firewalls, but I wonder if the acetic acid in it will eat or fog canopies.
Canopy Glue
Volfy:
It's hard to apply a small bead using RTV, other than that I see no reason it wouldn't work fine so long as there is a vent for the fumes to exit.
Bill.
Bill.
Canopy Glue
Volfy, that stuff is pretty obnoxious and agressive; as in hard to remove once applied. You'd have to use acetone or MEK, which dulls plastic film big-time; not to mention eating butyrate plastic, which most canopies are drawn from, most paints, etc.
I would say it is a disaster waiting to occur...
Steve
Steve
