T/F wood pecker???
T/F wood pecker???
I final sand my balsa with 1,000 grit wet dry paper to get the best finish possiable for me when i paint or cover the plane....why would you prep a plane and then run this wood pecker over the wood???? Would it not show through the covering as damage????
Share what you know!
Thanks, Terry
Thanks, Terry
My Feedback: (118)
TX
RE: T/F wood pecker???
Terry,
When applying film covering over larger areas it is quite easy to trap air and create bubbles or creases in the covering. The wood pecker was designed to help in preventing this. I have used it, but the holes were noticeable through the covering. I use a sharp skinny pin to puncture the balsa in a pattern with about 1/2" between holes. A light sanding after, remove the dust and cover away.
Another advantage of the relief holes is that when the aircraft is exposed to the sun bubbles are less likely to form.
Bliksem
Bliksem
My Feedback: (-1)
I still feel the wood packer is one of those tools that should never have been put on the market. It's just aother item to sell to the people just getting into the hobby. Once you have covered a few planes you will develope little ticks so you don't get air bubbles and your plane will look a lot better for it. It's one of the tools I have filed under JUNK.
CO
ORIGINAL: noveldoc
I love it.
Just don't press too hard.
Tom
I love it.
Tom
Just don't drop it on your (bare) foot.
My Feedback: (54)
Run it over the surface, then sand. Blow out the holes with your compressor before covering. I quit using it most of the time now though because you figure out how to get air out from under the covering without it eventually. Also works when putting on trim; run it over the covering beneath and it reduces bubbles in your trim pieces.
I use the woodpecker, but not on wood. I use it when a covering job requires more than one layer of Ultracote(windshield patterns, numbers, etc.). The holes in the base layer do not show through in the top layer and most gas(bubble) build up is relieved.
Interesting responses. I love the thing. Especially for overlapping pieces and I'm going to try it now to provide more adhesion surface...good suggestion. And if you use it aggressively enough it truly does minimize the bubbling over sheeted areas. I'd rather see the pecker marks thru the covering than blisters on the surface.
Fortunately you don't see either when its flying around,
Clay
Clay
NJ
In the 30+ years I've been building and covering models, I have yet to try this contraption - or anything like it. My good friend and experienced builder swears by it so I convinced myself to buy one and try it. I would agree with others of its merits as used for overlaping covering or trim. I tried it on balsa prior to covering and noted the holes through the covering - I will not be trying that application again!
I'll stick to my tried and trued method of using my #11 blade to lightly poke the covering as I encounter bubbling whilst applying heat to it.
WA
i have one and the only time i used it was for the sheeted areas on my RV-4 before ironing down the monocrap. saw right through it. now i've figured out the tacking down the edges and shrinking with the heat gun. maybe i'll give it another try. definitely going to with the trim covering over base colors. we'll see how that works out. i'm getting ready to cover my new kadet MKII. can't get anymore sheeted than that thing.
and i'm going to guess the desert over in 'Stan-land', or Saudi or Kuwait...
Thanks guys.. the thing I found intresting was the post up toward the top that stated the wood pecker did help avoid bubbles when the plane was in the sun and hot...that sounds good..
Thanks for everyone who chimed in! Build alot this winter!
Terry B
Terry B
Use it too hard on a solid stab and risk flight failure. I never had it happen to me but I've read about it here on RCU. Yes that anecdoctal evidence but so is using it to avoid bubbbles in monokote in the summer. In my opinion doing a proper covering job, including air holes between ribs that exit into the fuselage to prevent pressure build up and keeping the model in the shade do far more preventing bubbles than the wood pecker. Use a temperature controlled iron when covering so you don't overheat the covering. Get it as flat as possible by tacking the corners. See Minflyer's covering videos. I also use thinned balsarite on solid surfaces, it aids in preventing bubbling by adhering the covering firmly to the wood. It also aids surface prep by sealing the wood and after a light sanding all the fuzz is gone.
John
John
