Balsa Splitter/Stripper
Reply
Old 04-04-2011, 09:06 AM
cpeisher
My Feedback: (13)
cpeisher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsa Splitter/Stripper
Has anyone built a balsa splitter/stripper similar to this...
http://www.gryffinaero.com/models/ff...p/dmstrip.html
I haven't found any plans for one yet, so i was wondering what people did to print out the custom scale that would be used on the hypotenuse of the triangle to gauge the strip width.
I know it depends on the angle, and i have a spread sheet showing me the scale of the sliding measuring scale as it relates to the width of the strip. I.e. at 15 degrees, to get a 2" wide strip i would need a scale 7.727" long. (please check my math...)Also, what would you recommend for me to print out the custom measuring tape and affix it to the splitter/stripper?
Any ideas? Or is this just a waste of time and i should buy the strips already cut?
cpeisher is offline
Old 04-04-2011, 12:56 PM
noveldoc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa Splitter/Stripper
My Master Airscrew for $6.99 from Tower Hobbies works just fine. Just need to pay a little attention to what you are doing.
Tom
noveldoc is offline
Old 04-04-2011, 05:47 PM
Terry Bolin
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the MAS cutter and Love it.. on the hard stuff or thick stock, I just make a few passes to get through it....using new blades really help toooo
Terry Bolin is offline
Old 04-05-2011, 07:43 AM
carlgrover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I needed a bunch of balsa strips for a project I might buy them. If I need to cut a few, I do it on the Master Airscrew stripper or with a bandsaw. The stripper in the link was very nice but it is kind of large and is single purpose only. Things that big have a tendency to clutter up the shop.
carlgrover is offline
Old 04-05-2011, 08:25 AM
cpeisher
My Feedback: (13)
cpeisher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ended up spending about 3 hours in the shop making my own rudimentary splitter. It was fun and i wanted to use my planer and table saw and drill press anyway. Ihad some rock maple to use for the beam to hold the blade, and a wide oak panel to serve as the base. I'll post some pictures later. It worked very well, just dont have the screw adjust feature of the master airscrew.
cpeisher is offline
Old 04-05-2011, 09:05 AM
AmishWarlord
AmishWarlord's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm with Carl,
I use the Master Airscrew stripper for a few light duty cuts or the band saw for heavy or numerous cuts.
Wile this stripper is nice at $77 I think it belongs in the "Expensive fishing tackle designed to catch fishermen rather than fish" column
Now if your a collector of high dollar RC airplane building accessories then go for it.
I just ordered my second MS stripper yesterday since I can't find my first one I bought in 1989 after the last move. I'm sure it's in a box or drawer somewhere waiting to poke my finger.
Making your own strips is so much better than figuring how many strips you'll need for a project.
AmishWarlord is offline
Old 04-06-2011, 04:41 AM
cpeisher
My Feedback: (13)
cpeisher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The picture you posted is the version of the splitter that wooden has evolved to, from what i understand. the original designer stopped making them and licensed the design to the company who makes the model you posted. I think i read that in an rcgroups forum. I think i'd like to make that model eventually, more for the geometric challenge of figuring the angles, slide distance and strip width, and getting it to all work, that for the amount of unility i would get from it. I could make the thing from scrap i have laying around, so it would only cost time.
cpeisher is offline
Old 04-06-2011, 05:29 AM
rcnats
My Feedback: (56)
rcnats's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's what I use...AWESOME!!!
http://www.hobby-lobby.com/balsa_stripper_2482_prd1.htm
rcnats is offline
Old 04-08-2011, 06:02 PM
AmishWarlord
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not much to figure out on the angles two equal angle wedges will cancel each other out. Just a matter of a good length to support the stock and to mark 1/16, 1/8, 1/4 and so on.
I bought one of these test stands off ebay a few years ago. Really nice workmanship on this. I think one of these would prove more challenging and useful than a mere balsa stripper for you to build.
Old 04-08-2011, 09:09 PM
cpeisher
My Feedback: (13)
cpeisher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, there is the matter of marking on the hypotenuse of the triangle the width of the strip you're about to cut. That's the part that gets tricky. But like you said, any two mirror image right triangles will suffice to get a "fence" that stays parallel to the blade...
That's a pretty nice test stand. I made one a while back, but the plywood i can get here locally in 3/4" is typically 11 or less ply, and the 1/2" and 1/4" has proportionally less plys. The better stuff usually has 13 or so in 3/4" It looks like your stand is made from pretty good quality 1/4" and 1/2" ply and what appears to be rock maple for the engine "blocks". I've thought about upgrading mine to include a throttle handle and a better fuel tank mount. Can you post a few more pictures of your test stand so i can see a few more angles of it?
cpeisher is offline
Old 04-09-2011, 12:49 PM
Tarasdad
Tarasdad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's not hard to figure the divisions. Just mark your increments (1/32", 1/16" or whatever) along the short side then carry them across with a square. Where the line intersects the hypotenuse is where you would move the piece to to achieve that thickness cut.
Tarasdad is offline
Contact Us Archive Advertising Cookie Policy
