AMR Sport 26
QC, CANADA
AMR Sport 26
AMR-RC have a new model, the Sport 26, I already build one and there's some pictures, note the cover over the engine compartment, this part is not include in the original kit, it's my own idea just to give a little personal touch, so dont ask AMR to get this part.
RCU Forum Manager/Admin
My Feedback: (9)
RE: AMR Sport 26
I have this one on the bench right now and I'm also doing a build thread on it. I'll start posting the build thread in a few days so everybody can follow along. I just want to get ahead of the build a bit before I start putting the build thread up.
Yves,
what did you use to tint your windows?? Rit dye???
Ken
Yves,
Ken
QC, CANADA
RE: AMR Sport 26
To tint the windows of my planes, I use Nite-Shades from VHT Speciality Product, it's in spray, the way I work, I remove only the inside protective film of the plastic windows, I lay it on a cardboard, then I give one, two or three coat of this transparent dye, more coat you spray, more dark and more you get opacity.
For the front window or windshield, I spray two coats of dye, then I wash with an alccol pad to keep just a little dark, so I can see the level of the gas in the tank and if all work properly inside the fuse.
QC, CANADA
RE: AMR Sport 26
Hi,
My rudder servo (phot #1) is in the center section of the fuselage to keep the CG at the proper point, so you can see his installation done bye the the bottom of the fuse. Next for the throttle and choke servos, the throttle one (Photo #5) is on the left fuse side aside of the gaz tank, then the choke one (Photo #4) is on left fuse side but in the cabin, you can see it true the windshield (Photo #6) they are rod with 4-40 rods. (Photo #3).
