What Is This Plane!!!
RE: What Is This Plane!!!
I thought the falcon 56 had a high wing? The skylark had a low wing. This one has sort of a high mid wing. It kind of looks a little like an easy sport 40 but that was an arf so I dont know.
Sorry, definitively not a Falcon 56.
In those, the horizontal tail is airfoiled and the vertical tail is solid; the wing goes over the fuse with no part of the fuse over it; engine mount are wood beams extending thru the firewall; and the structure of the wing is different, with full span ailerons and solid balsa wingtips.
http://masportaviator.com/2007/12/01...erg-falcon-56/
I believe that your plane is an Easy Sport .40 manufactured by Great Planes and converted to a tail dragger by the previous owner(s).
Here is the manual of the kit (now discontinued):
http://manuals.hobbico.com/gpm/gpma0150-0152-manual.pdf
It shows that the CG should be located at 4-1/8" aft from the LE.
Specs here:
http://www.greatplanes.com/discontinued/gpma0150.html
Specs here:
Sterling models came out with two direct competitors for the Falcon 56 and the Sr Falcon. The Big plane was a Gazariator or something like that. Can't remember the name of the little one, but I'm guessing that is what you have.
Here's the big one
http://www.ivyandmartin.demon.co.uk/...tor_review.htm
NOW I remember! the Sterling Fledgelling is what you might have!
Here's the big one
My Feedback: (60)
AZ
Don't think it's a Fledgeling as it has all sheet tail surfaces. I agree with Lnewqban, it has all the earmarks of a modified Easy Sport 40. If you do a Google image search for "Easy Sport 40" you will find a number that have been built as tail draggers and they look just like what you have here.
I don't think it's a Sterling Fledgeling. I flew one for several years. The empenage was more rounded top and bottom and had full span ailerons (which could always be changed).
That's an Easy Sport 40 done up as a taildragger. I built 2 of them from kits, very nice flying model. Only difference with yours is that the landing gear is beefed up, stock configuration is a single wire. Go to Tower Hobbies site and you can compare pics of the Easy Sport ARF. Have fun!
FB
FB
ORIGINAL: Free Bird
FB
FB
Yeap, GP Easy sport 40. I built one as my second kit and airplane.
