Top Flite Giant P-47 Build
Reply
Old 09-28-2012, 03:59 PM
  #476
SitNFly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Top Flite Giant P-47 Build
I am also slogging thru this build and appreciate the thread. I had a question about finishing the flap area. With the small rib stubs getting in the way, is it possible to glass this area? Or do you paint it and call it good?
SitNFly is offline
Old 09-28-2012, 07:25 PM
  #477
redbiscuits
redbiscuits's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just primed that area and sanded it smooth. It would almost be impossible to get glass to lay over those ribs without bubbling up in the corners. To me, that would have looked worse than a little wood grain showing through.
Good tip Fabio, I'll give that a shot.
redbiscuits is offline
Old 09-29-2012, 11:03 AM
  #478
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trying to get an idea of where everything is going to go. I have A-123 batteries up front next to the fuel tank, I will build a battery tray so I can secure them in there nicely.
They are going to be powering a Spektrum AR12100 Power Safe Receiver. I'm going to have to locate a spot for the choke servo as one will not fit in the supplied servo tray. The choke will also be how I can cut the engine from the transmitter. I'm running out of channels with my TX.
I was originally thinking about a smoke system, but I may wait to get a few flights on her before I add it.
ID:	1806042   Click image for larger version
Old 09-29-2012, 02:17 PM
  #479
Ram360
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anybody mounted the Sierra retracts in there p47?  Trying to get an idea how to modify the wing for them.
Ram360 is offline
Old 09-30-2012, 03:29 PM
  #480
yates55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After getting the bottom sheeting on I couldnt stand not putting it under the fuse, plenty of sanding to do but a very productive day
yates55 is offline
Old 10-01-2012, 03:57 AM
  #481
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking Good!
Old 10-02-2012, 03:08 PM
  #482
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inter cooler doors done.
You guys were right. It is impossible to make them all with the little strip provided.
I cut the four corners out the front of the cowl to have enough plastic to build them.
Primed and ready to go.
Sheeting the fuse next.
I removed the tail gear so that I can start working on the mechanism to open and close the doors.
I will insert the tail gear later since I ran the lines already into the fuse.
ID:	1807343   Click image for larger version
ID:	1807344   Click image for larger version
ID:	1807345   Click image for larger version
Doomking is offline
Old 10-03-2012, 03:36 AM
  #483
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like how you did your door linkages Fabio, I will try to duplicate your set-up.
I must have the worlds worst luck when it comes to digital servos. I was testing the throttle servo and noticed it buzzing and getting warm just sitting on the bench not hooked up to any linkage or anything. I thought that it was strange so I emailed Airtronics looking for answers. Last night I went back at it and hooked it up to a different reciever and it just quit working all together. Now I have to send it in to see what happened.
All-in-all I have a bad taste in my mouth when it comes to digital servos [:'(]
Old 10-03-2012, 04:11 AM
  #484
Ram360
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Fabio.
Ram360 is offline
Old 10-03-2012, 11:49 AM
  #485
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At list it happened on the bench.
I always had good luck with Hitec 5645 and Spektrum 821.
They are reasonably priced and they do the job every time.
That's what I am using in all my warbirds.
Fabio
Doomking is offline
Old 10-03-2012, 01:14 PM
  #486
shrek514
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello everyone.i am new to this tread. i read the trhead and love what you guys are doing with your birds.i have the 60 size p-47 from top flite and just love it.i am now thinking of purchasing the giant scale one .i have a question about glassing the plane. i have seen people use deft lacquer sanding sealer on the wood to protect it.then they use minwax policrylic to lay the fiberglass cloth on the plane is this.does this give a nice finish or should i use z-poxy for the fiberglass and if so do i have to put something on the wood to protect it from absorbing the epoxy.this will be my first attemp at fiberglassing a plane. any advice would be very much appreciated.On an other note redbiscuits thank you for starting this thread i love it.
shrek514 is offline
Old 10-03-2012, 02:11 PM
  #487
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Welcome shrek,
I have the 60 size as well, I did the poly-c method and have mixed emotions about how it came out. I guess the only benefit of doing it that way is the cleanup, that's it! It takes WAY too many coats of poly to fill the weave and it's harder to sand. Since poly-c is water-based it will also want to swell the wood and may cause the sheeting to bubble up.
I read the thread on finishing with Deft and really seen no benefit, plus that stuff isn't cheap either.
I like the method of thinning the epoxy with alcohol to keep from putting on too much and getting it to flow out. I don't seal the wood with anything either, as I want the glass to have a good bond to the wood.
I'm also starting to think that I may come in under my 24# mark, we'll see...
Old 10-03-2012, 02:12 PM
  #488
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think if you use Redbiscuits recipe 1-1-1 of resin and alcohol it will lay really easy with the brush.
Also I like for the epoxy to get absorbed into the balsa since it makes for a very rigid surface.
Not to worry about glassing....easy process and you can't screw up!
Just follow biscuits directions in the pages before and you will do just fine.
Welcome to the thread!!
Doomking is offline
Old 10-03-2012, 02:43 PM
  #489
EJWash1
EJWash1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RE: The supercharger intake. When I ordered my Ziroli plans, I also ordered the engine cowl. I was disappointed that the cowl didn't have the supercharger intake at the bottom. I'm surprised that the TF kit doesn't either, or is it a separate piece?
EJWash1 is offline
Old 10-03-2012, 04:30 PM
  #490
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nope EJ, No supercharger intake. I'm assuming by that you are talking about the chin scoop correct?
Aerotech Scale Parts sold out and I don't know where to get one. I would have to buy the replacement cowl from the TF ARF to get the scoop. I wonder if I could get the scoop by itself from Top Flite if I called them?
Old 10-03-2012, 04:39 PM
  #491
EJWash1
EJWash1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, the chin scoop. Guess if you want one, you'll have to WAG it...
EJWash1 is offline
Old 10-03-2012, 04:47 PM
  #492
shrek514
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys for the info. Also what kind of epoxy do you use for the cloth and where can i purchase it. Is it the same epoxy that you would buy at the hobby shop. Like 30 min epoxy or 5 min epoxy or is it a special kind for cloth.
shrek514 is offline
Old 10-03-2012, 05:29 PM
  #493
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nop..
The correct one is Zpoxy and ready available at tower hobbies
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCX58&P=ML[/link]
just mix 1-1-1 ratio and apply.
Doomking is offline
Old 10-03-2012, 05:38 PM
  #494
Chad Veich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EJ,
I can provide you with a vacuum formed intake "splitter" for the larger Ziroli size Jug if that is the one you've got. (Assuming I can still find my plug!) Probably too big for the Top Flite kit I'm afraid. However, I've seen some guys use the top portion of a spare cowl to create the splitter in the TF model. Here's mine in Stephen Lucy's big Robart Jug.
http://images.rcuniverse.com/forum/u...38/ay74040.jpg
Chad Veich is offline
Old 10-03-2012, 05:45 PM
  #495
Doomking
Doomking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what's with the big picture??
By the way we made front page here on RCU
Doomking is offline
Old 10-03-2012, 08:55 PM
  #496
EJWash1
EJWash1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chad,
Thank you for the offer. I really appreciate it.
Yep, I have the 92" Ziroli Jug (short kit by Eureka Aircraft Company). I really want to learn how to make fiberglass molds. Now you've given me an idea. Since I have the engine cowl on-hand, I can make a female mold using the top outer half of the cowl.
EJWash1 is offline
Old 10-03-2012, 08:59 PM
  #497
EJWash1
EJWash1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Double post....
EJWash1 is offline
Old 10-04-2012, 08:33 AM
  #498
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ordered my paint, Ouch!
Order Number: xxxxxxxxxxxxxxxx
Date: Thu 4 Oct 2012 11:23:05 AM CDT
Cart Items: 8.0
Name Item No. Qty Price Total
Olive Drab Shade 41 KKAMCOD34087016 1 $31.95 $31.95
Sizes: 1 Pint
Insignia Blue - Shade 47 - FS 35044 KKAMCIB35044008 1 $18.95 $18.95
Sizes: 1/2 Pint
Insignia White - FS 17875 KKAMCIW17875008 1 $18.95 $18.95
Sizes: 1/2 Pint
Satin Catalyst #463 KKB463032 1 $36.95 $36.95
Sizes: 1 Quart
Flattener Additive KKF011028 1 $17.95 $17.95
Sizes: 1 Ounce
FS 36440 - Grey KKAMC36440G016 1 $31.95 $31.95
Sizes:: 1 pint
Satin Black #900 KKA900008 1 $15.50 $15.50
Sizes: 1/2 Pint
Satin Catalyst #463 KKB463016 1 $24.95 $24.95
Sizes: 1 Pint
Subtotal $197.15
Shipping Fee $16.95
Total $214.10
Old 10-04-2012, 10:47 AM
  #499
EJWash1
EJWash1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Ouch" is right, but at least you're spending it on FUN!
EJWash1 is offline
Old 10-04-2012, 06:18 PM
  #500
Ram360
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the progress I made on the wing so far.
[img]webkit-fake-url://FA568DAB-EF5D-44D5-B838-4D8ABA4FE472/imagejpeg[/img]
Ram360 is offline
Reply
Display Modes
