If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 29 of 90 FirstFirst ... 1927282930313979 ... LastLast
Results 701 to 725 of 2243
  1. #701
    Join Date
    Jan 2005
    Billings, MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Top Flite Giant P-47 Build
    Jimbo here a technique I use on my controls surfaces. It makes a really sharp corner and keeps the dings to a minimum. Glue a piece of 1/64 ply to each end of the control surface.
    Makes a really sharp tough edge.
    Ron
    Ronald W. Horton
    P-47 Brotherhood #63
  2. #702
    redbiscuits's Avatar
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't know what was worse, building the flaps or adjusting the linkages and the radio for the flaps. After 3 evenings of fiddling around with it I finally got the radio and the linkages all adjusted and working properly, the flaps coming down and going up evenly, all without any slop or servo buzz.
    Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
  3. #703
    Join Date
    Feb 2002
    Leander, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lucky you. I'm still battling my flaps on the B-25.
    Edwin
  4. #704
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Doesn't look like any flying will be done here this weekend.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #705
    Doomking's Avatar
    Join Date
    Nov 2002
    North Ridgeville, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hear a chant........Rivets!......Rivets!......Rivets!....
  6. #706
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was thinking the same thing!
  7. #707
    Doomking's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well thanks to my forever friend Gary, I can now proceed forward.
    Ailerons are done and I am waiting for the filler to dry so that I can separate them and cut the hinge holes.
    One question....actually two.
    Is it sufficient for the flaps to be glued to the balsa LE just applying glue to the little ribs and the flap skins?
    Seems to me that just a 3/32 " gluing surface is insufficient. But then again what do I know?
    Also once you shape the flaps, is it possible to put enough glue around the flap horn or it's going to get squeezed out the slot you cut in the balsa once you insert it in?
    How did you guy handle that?
    Once again Gary.....thanks!!!
  8. #708
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey, no problem buddy. Glad it showed up so soon.
    I followed the instructions but I used Titebond II wood glue for the leading edges of both. For the flap-horn, I used epoxy and then filled the rest of the gap with epoxy mixed with micro balloons once it set up.
  9. #709
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can't remember if I glued in the flap-horn first and then glued the leading edge around it or not, but that kinda sticks out in my mind.
    *edit*
    It couldn't have been that way, the leading edge is already shaped by that time. Told you I had a bad memory!
  10. #710
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think most of you guys are doing the razor back version. If ya'll need these files I can send them to you. I also have the P47D 3 views as well.
ID:	1818855   Click image for larger version.
ID:	1818856   Click image for larger version.
ID:	1818857   Click image for larger version.
  11. #711
    Join Date
    Jan 2008
    newport, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That would be awesome Gary
    yates55@ec.rr.com
    Yates
  12. #712
    Join Date
    Jan 2008
    newport, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got em, going to print shop now to get blown up a bit
    Thanks Gary
    you are the man
    yates
  13. #713
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: RWHorton
    Ron
    Ron,
    that's a real good idea and one I think I will use, thanks for the tip..........
    Hello gang,
    been out of town working all week so not much progress on my bird.. Yard work in the morning, suppose to be 72 but30mph winds,good day to send my neighbor his leafs back...lol
    I'm looking forward to getting down in the shop over the weekend and getting the flaps knocked out.. Got good news at work, besides being busy which is always a good thing, the boss told me it was ok to build my plane rack for my shop.. I got full access to all the good stuff, gonna build a real nice mobile rolling rack with all the bells.....
    Jimbo
    Ultra Sport Brotherhood #92
  14. #714
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: redbiscuits
    Oh yeah baby, that will help a bunch when I do my P.L. and hatches..........
    nwood10@yahoo.com
    Thanks Gary.....
  15. #715
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Let the riveting begin!
    There is a little bit of a learning curve to using the finish set that I bought. The transfer tape that is provided is good for one row of rivets, "maybe" two. I found it best just to use it once. I use a fresh piece, as it looses its tack quickly and fails to pick-up every rivet or screw. No big deal, as Mirce provided a lot of the tape.
    I also found it best to use a tongue depressor to help in the transfer to the tape and to peel the tape back on itself while applying them, using the stick to help them release from the tape as well.
    As I said, there is a little bit of a learning curve, but it's getting better as I go.
    It's starting to look pretty sweet!
ID:	1819092   Click image for larger version.
ID:	1819093   Click image for larger version.
ID:	1819094   Click image for larger version.
ID:	1819095   Click image for larger version.
  16. #716
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Few more...
ID:	1819154   Click image for larger version.
ID:	1819155   Click image for larger version.
  17. #717
    cannonball200's Avatar
    Join Date
    Aug 2002
    Oklahoma City, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow!!!!!!!!!!!!!!!!!!!!!!! GaryThat is awesome!! I have followed your build with intent to build one for myself soon. The rivet detail is a necessity I think.
    Good luck on the final finish, we will be watching...
    Eddie of OKC
    cannonball200
    Waco\" Brother #191 @ Cub Brother #122
  18. #718
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gary,
    they look great, very nice.. i was thinking about buying them from him and you really got me thinking I will now, awesome... Thank you for the 3 views as well, got them this morning.
    Jimbo
  19. #719
    Doomking's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gary looks great.
    Compared to the iron method, would you say it's a bit faster and easier?
    Are the rivets going to stick permanently or lift under the paint eventually?
    I am seriously considering it as well if the application time vs my iron is cut down considerably.
    On another note, Gary you were right about the flaps......what a pain in the &@"$@$;:.
    I am having an issue with mine since they both developed a slight twist on the TE and it's very difficult to align both sides to the fuse and aileron at the same time.
    I might have to just split the difference unless you guys have a solution to the twist.
    Maybe soacking the flap TE in water and let them dry on a flat surface with some wight on?
    Pictures to follow.
  20. #720
    Join Date
    May 2010
    maple hts, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great Gary. I haven't done much on mine in the last few weeks I got a new 100cc bird I been working on.
  21. #721
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the kind words guys!
    Fabio, I think it is faster. It was kind of slow going at first, but once I developed a method that works for me I'm moving right along. It definitely isn't as monotonous as ironing 15,000 rivets, been there done that! I would say once I have paint and clear coat over it they aren't going anywhere, but right now I have to be kind of careful.
    I had the same problem with one of my flaps. What I did is soak it with Windex and then weighted it down with sand bags for a couple days. That took most of the twist out of it and it's not noticeable now.
  22. #722
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    At this point I think it would be easy to "overdue" things. The P47 has flush rivets and I think if I just keep adding rivets it might take away from the look rather than enhance it. I don't like the overdone look, so I think I will try and find a happy medium while capturing the most noticeable details. Some of the panels are a little mis-placed, too late to change it now, I'm done doing bodywork.
    What do you guys think?
ID:	1819334   Click image for larger version.
ID:	1819335   Click image for larger version.
ID:	1819336   Click image for larger version.
  23. #723
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think your a very talented builder and it's coming out great, that's what me thinks...
    I haven't had any warping problems in my flaps, but I haven't glued on the LE yet.. I am going to use a slow dry wood glue and weight them down flat on the bench while it sets.. I'm wondering if the LE being glued on in two pieces is causing this, there is not much to keep it from happening.. I think I might keep a scrap in the control horn gap while it all dries....
  24. #724
    Join Date
    Mar 2009
    CEDAR CREEK, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mustangman40
    That's probably what is happening.
    Heading to the hobby shop to see if I can pickup some stuff to simulate the sliding mechanism.
  25. #725
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gary,
    do you remember who's Fiberglass cloth you used and how much you ended up using? I was going to get mine ordered today at my LHS...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
