Reload this Page >
Top Flite Giant P-47 Build
Old 02-19-2013, 09:58 AM
  #1301
redbiscuits
redbiscuits's Avatar
Default RE: Top Flite Giant P-47 Build
ORIGINAL: yates55
Looking Great Gary, cant wait to see cowl on plane ''sweet''
Yates
I think I will get the black on tonight after work, we'll see it in another day or so. The good, the bad, and the ugly....I'm hoping for more good than bad and ugly.
Old 02-21-2013, 06:38 PM
  #1302
EJWash1
EJWash1's Avatar
Gary,
Questions on the liquid mask, please. Did you spray it on (as suggested by the manufacturer) or brush it on? What tool did you score it with to remove the squares? Looks like you removed the unwanted squares in the pic in post #1294.
I bought some liquid mask about two years ago and tried it on a test set-up I made with plastic window material. My first concern was how to remove the mask after I paint. What I ended-up doing was making folded-over tabs out of 3M Safe-Realease painters masking tape. I placed a couple of the tabs on the window surface and then sprayed-on the liquid mask. After painting, I was able to pull the tabs away from the window and worked the liquid mask off from the inside of the window area outward instead of the other way around. This way I did not have to pick at the outside edges of the painted area and risk chipping the paint. Worked well. Just another approach.
Can't wait to see your results with the cowl.
Old 02-21-2013, 07:24 PM
  #1303
redbiscuits
I brushed it on in several coats and ended up using the whole bottle. I cut the mask with a good X-acto knife and lightly picked the edge up with a dull one.
Let me tell ya'll what is going on over here, I know you're wondering what's taking so long. The liquid mask is very thin and rubbery. I started on the bottom of the cowl removing the mask and the paint didn't want to leave a clean edge. Not sure what the problem is, the only thing that is different from the other masking and painting on the plane is the liquid mask. It has turned into a freakin rescue mission.[:@]
So, as I move around the cowl from bottom to top, I have figured out that I have to score the paint with a sharp blade to break the tension between the masked area and the unmasked area, it's also helping if I wet sand around the masked area before trying to remove the mask. HUGE PITA going on over here I'm sorry to report.
Since I'm going for that "in service look" I think it will be okay, if this was an aerobatic scale or sport plane, I would have scrapped it already.
Give me a couple more days and I'll let ya'll be the judge.
Old 02-22-2013, 03:12 AM
  #1304
WacoNut
WacoNut's Avatar
Thats a bummer Gary,
I am sure it will come out just fine. That is one of the down sides to letting the paint fully set before removing the mask. The tension of the paint is more than the tension of the mask.
Can't wait to see the unvailing.
Anthony
Old 02-22-2013, 03:29 AM
  #1305
TonyBuilder
TonyBuilder's Avatar
Gary, I too am going for the “In Use” look and I want imperfections, my plane is beat up and heavily weathered. . These are birds of war not Red Bull show planes. I think it will turn out perfect in the end, chin up buddy.
TB
Old 02-22-2013, 08:27 AM
  #1306
redbiscuits
Well, I have all the mask off, the more I went, the better it got. Tell you the truth it's kind of growing on me. Should look okay with a little touch-ups here and there, then closing one eye and standing ten feet away.
Without a doubt the hardest, most nerve racking thing I had to do on this build.
So, without further adieu.....................
ID:	1854920   Click image for larger version
ID:	1854921   Click image for larger version
ID:	1854922   Click image for larger version
ID:	1854923   Click image for larger version
ID:	1854924   Click image for larger version
ID:	1854925   Click image for larger version
Old 02-22-2013, 08:31 AM
  #1307
TonyBuilder
Looks like a winner to me, lets go flying
TB
Old 02-22-2013, 11:38 AM
  #1308
yates55
Super awesome Gary be proud cuz it sure is awesome, hard work paid off well for you
Did I tell you it looks Awesome hehe
yates
Old 02-22-2013, 12:53 PM
  #1309
redbiscuits
Thanks, I was going for that "painted with a broom in the middle of a dusty airfield with 1940's paint technology" kind of look.
Old 02-22-2013, 03:38 PM
  #1310
redbiscuits
Getting the radial installed. Next up, finish the canopy. Still waiting on my pilot's jacket to get here too...
I think I need a break, might head to the field tomorrow and bore some holes through the sky. Sunday I'll get on the canopy.
ID:	1855077   Click image for larger version
Old 02-22-2013, 06:50 PM
  #1311
WacoNut
WacoNut's Avatar
Looks really good!!!
Old 02-23-2013, 12:27 AM
  #1312
EJWash1
EJWash1's Avatar
Outstanding results on the cowl! Outstanding. Trust me, this is a great representation of "in service" which means "authentic". If it came out with perfect, and I mean *perfect* lines (crisp, sharp) it would have been in conflict with the panel lines and rivets.
Its a combat horse, not a prancing dressage horse.
Old 02-23-2013, 04:24 AM
  #1313
TonyBuilder
Gary, I see you are using cowl screws. I have a tip if you haven’t already done this (I know you really need more work to do). Take a piece of sheet tin and cut some small squares about the size of the cowl blocks. Glue them into the inside of the cowl with epoxy. Then drill them out from the holes you already have. This keeps the fiberglass or plastic from wallowing out. You can get the tin at Home Depot in the roofing department, the little round disks for roofing. See you later at the field.
TB
Old 02-23-2013, 04:40 AM
  #1314
redbiscuits
Good tip Tony, I have some K&S steel sheet that will work perfectly for that.
Old 02-23-2013, 04:55 AM
  #1315
redbiscuits
ORIGINAL: EJWash1
Outstanding results on the cowl! Outstanding. Trust me, this is a great representation of ''in service'' which means ''authentic''. If it came out with perfect, and I mean *perfect* lines (crisp, sharp) it would have been in conflict with the panel lines and rivets.
It's going to look good when everything is weathered up EJ, I'm not too concerned that some of the edges didn't come out perfect, you have to really get up close to even notice.
Quick story....
My step-daughters new boyfriend came over last night for dinner, and my hobby came up over dinner (as it usually does) I asked him if he has ever tried flying an rc airplane before, he said that he doesn't really play with "toys" anymore. After dinner I said "come on, let me show you my toy airplane"
His jaw about hit the floor, he said he would definitely like to play with a toy like that!
Old 02-24-2013, 12:04 PM
  #1316
Mustangman40
Gary,
looks great my friend, awesome job...........
My Retracts are in, my retracts are in, my retracts are in.....Only getting one day off this week, so no hobby shop today, I will pic them up next weekend and get them installed.. I also ordered my glass parts from Fiberglass Specialties today, got the cowl, supercharger and cooler doors.. My shipping came out to $16.25, isn't that what you paid for shipping the little chin block for the cowl...
Jimbo
Old 02-24-2013, 01:38 PM
  #1317
redbiscuits
Thanks buddy.
The canopy is being worked on as I type, my whining finally paid off, and wifey is doing the last rivets for me. YAY!
I guess I'll go cook dinner and fold some laundry.
Old 02-24-2013, 02:05 PM
  #1318
Zor
Banned
ORIGINAL: redbiscuits
Thanks buddy.
reddbiscuits,
Many modelers are envying you.
Not only you have talents to build a beauriful model but also the talent to have chosen a beautiful lady.
Now we have to see how much talent you have at cooking dinner and folding laundry LOL .
Thanks for a beautiful picture of a beautiful woman.
Zor
Old 02-24-2013, 04:34 PM
  #1319
Doomking
My Feedback: (38)
Doomking's Avatar
Great Job as usual Gary, wonder why I am not surprised anymore, you are a true modeler!
Little progress from here in eastern Siberia.
The weather the last couple of weeks hardly went above freezing. To shoot primer on the wing in my garage I had to borrow a torpedo heater from work. What a pain in the #$%^
Gary if you don't know what a torpedo heater is, since there is always 80 and sunny, I can send you some pictures....
Anyway I was able with a lot of cussing and patience to prime the wing and it is now ready for chart tape and lines.
Hopefully by the end of this week if the weather behaves I should have the lines all primed up.
Last evening I got bored from the lack of progress on my build that I decided to put together the TF cockpit.
No scale effort here, just some color and switches to keep the kids at the field looking at something.
Most of the cockpit work is always hidden so no sense in getting carried away.
Gary I will trade you my Robart wheels if you can send this way a couple of weeks of your weather.......
Reporting Live
Fabio
Siberia CH 19 news
ID:	1855850   Click image for larger version
ID:	1855851   Click image for larger version
ID:	1855852   Click image for larger version
ID:	1855853   Click image for larger version
Old 02-24-2013, 05:26 PM
  #1320
redbiscuits
ORIGINAL: Doomking
Fabio, you're WAY too modest, that is one of the best looking TF CP kits I've seen. Now, if you want to see what "no effort" is, I'll post some pics of mine!
BTW, I spent about 8 years in Ft. Wayne, Indiana in my late teens and 20's, We didn't have a torpedo, but we had a big ole kero heater.
Old 02-26-2013, 10:32 AM
  #1321
redbiscuits
Well, I thought we wasn't going to have a Warbird this year, but a few people resisted dropping it and it's a go. Hope we have a good turnout this year.
File Type: pdf
Old 02-26-2013, 11:46 AM
  #1322
TonyBuilder
Now we just need to have our warbirds ready to go by then.
TB
Old 02-26-2013, 02:05 PM
  #1323
shrek514
hello i have been following the tread for a couple of months and all i have to say is wow.i have a question for redbiscuits.what primer did you use on your plane before the panel line were applied and after the panel lines were aplied did you use klass kote primer before spraying the color.i am new at this and if anyone can help in the steps following the glassing i would much apreciate it Thanks
shrek
Old 02-26-2013, 02:53 PM
  #1324
TonyBuilder
He used an auto primer, read back threw the thread and he tells all about the primer and what he used before and after.
TB
Old 02-26-2013, 02:58 PM
  #1325
shrek514
ORIGINAL: TonyBuilder
TB
thanks for the info
