Reload this Page >
Top Flite Giant P-47 Build
Old 11-17-2016, 08:21 AM
  #2226
mirce
I forgot to say, I have all sets on stock, so next day after payment parcel with sets will be sent.
After that I sent confirmation from our post office with tracking number...
Regards
Old 11-22-2016, 04:58 PM
  #2227
HoundDog
My Feedback: (49)
HoundDog's Avatar
Can any one tell me if the pilot head rest on the GS TarHeel Hal ARF is part of the seat or the Aft Bulkhead of the cockpit? Pic PLZ. If anyone has one from a wreck let me know.
Old 11-22-2016, 10:32 PM
  #2228
marksp
My Feedback: (9)
marksp's Avatar
Part of the cockpit trim (separate from seat).
Old 11-23-2016, 06:03 AM
  #2229
HoundDog
My Feedback: (49)
HoundDog's Avatar
Thanks they are all white plastic from the factory and U have to paint them right. U can tell I purchased my TARHEEL finished.
Another question My 12" pilot was too tall even with him sitting righr on the floor no seat or parachute. Had to remove the chute from my 10" pilot too. What have others done? OH anyone know the actual name of the red on the Cowl?
Old 11-23-2016, 06:33 AM
  #2230
marksp
My Feedback: (9)
marksp's Avatar
Here's a link to the manual. It shows the cockpit parts (seat, armored floor, turtle deck, back plate, etc), cockpit part color (olive) and covering colors (Missile Red - TOPQ0201).
http://www.top-flite.com/airplanes/topa0703.html
Old 11-23-2016, 06:38 AM
  #2231
HoundDog
My Feedback: (49)
HoundDog's Avatar
[QUOTE=marksp;12279771]Here's a link to the manual. It shows the cockpit parts (seat, armored floor, turtle deck, back plate, etc), cockpit part color (olive) and covering colors (Missile Red - TOPQ0201).
http://www.top-flite.com/airplanes/topa0703.html[
/QUOTE]
Thanks I see it know. OOps it 7:38 gota get to the field too get a good parking spot. Have an Awesome Day.
Old 11-23-2016, 07:21 AM
  #2232
marksp
My Feedback: (9)
marksp's Avatar
BTW, not certain which parts you need, but I have extra armored floor, side walls, seat and front dash panel. I don't have turtle deck or aft armor plate. Hobbico/Topflite does not have orderable replacements for these parts as I think they're included w/fuselage.
Let me know if you need any of these parts and I'll send them to you if you cover postage.
Cheers
Old 11-23-2016, 04:45 PM
  #2233
HoundDog
My Feedback: (49)
HoundDog's Avatar
Cheers
Thanks but it's the back bulk head armor plate behind the pilots head I need. Broke mine off and then lost it I'll have to fudge something to repair it ...
Old 12-25-2016, 03:03 PM
  #2234
J.V.
My Feedback: (56)
I'm assembling my new ARC P-47 now. I plan on using a G.P.88cc gas engine. My stock muffler will not fit without some modification to the engine box. Just wondering if those of you who used a DA 85 or DLE 85 could tell me what type of pitts muffler you used. Or if you have a picture could you post it.
Thanks.
Old 01-24-2017, 12:12 PM
  #2235
Prekin
My Feedback: (19)
Prekin's Avatar
Guys, what is the best diametter dummy engine for this TF kit? Now I´m working on gunsight and instrument panel for this warbird.
Old 01-24-2017, 12:13 PM
  #2236
Prekin
My Feedback: (19)
Prekin's Avatar
Guys, what is the best diameter dummy engine for this TF kit? Now I´m working on gunsight and instrument panel for this warbird.
Old 01-24-2017, 03:24 PM
  #2237
marksp
My Feedback: (9)
marksp's Avatar
The included dummy radial is 8"/203mm.
Not certain if that's "best" or not???
Old 01-25-2017, 12:17 AM
  #2238
Ricko1
Ricko1's Avatar
Hi All,
Am trying to figure out the best way to fit the fuel tank and need some inspiration as I have run out of ideas. I am fitting a 24 oz Rotoflow tank and want it to be able to be removed as I want access to the rear engine mount bolts.
At the moment I have a brain fade
Rick
Old 01-25-2017, 08:57 PM
  #2239
Ricko1
Ricko1's Avatar
Tank issues all fixed - just had to ask the right person
Old 01-27-2017, 07:41 AM
  #2240
Prekin
My Feedback: (19)
Prekin's Avatar
There are first shots of my resin gunsights for this warbird. The instrument panel will be ready during next weeks. Also I would like to prepare bigger dummy engine.
ID:	2198414   Click image for larger version
ID:	2198415   Click image for larger version
ID:	2198416   Click image for larger version
ID:	2198417   Click image for larger version
ID:	2198418   Click image for larger version
ID:	2198419   Click image for larger version
ID:	2198420   Click image for larger version
ID:	2198422   Click image for larger version
ID:	2198423   Click image for larger version
Old 01-31-2017, 08:54 AM
  #2241
Prekin
My Feedback: (19)
Prekin's Avatar
Some more gun sights for this Top Flite kit. Model of the scale instrument panel is almost done. I must add more screws and repair some holes.
ID:	2199139   Click image for larger version
ID:	2199140   Click image for larger version
ID:	2199141   Click image for larger version
ID:	2199142   Click image for larger version
Old 02-12-2017, 12:05 AM
  #2242
Ricko1
Ricko1's Avatar
After 15 months she finally has the first coat of paint
Old 02-12-2017, 02:39 AM
  #2243
redbiscuits
redbiscuits's Avatar
Very nice!
Old 03-11-2017, 01:38 AM
  #2244
Ricko1
Ricko1's Avatar
It's maiden time for my P47 and I'm after a bit of advice. High or low rates for the first flight ? The manual advises to use high rates for the initial flight but I would like to hear your thoughts on the matter. My plane came out at 24 lb and is powered by a DLE 61.
Rick
Old 03-11-2017, 03:09 AM
  #2245
redbiscuits
Rick,
I maidened mine on low rates on the elevator and ailerons. I always setup my planes to give as much rudder as I can get right off the get go. After the first couple of flights I dialed in more aileron as the low rate gives a VERY scale roll rate.
I fly off pavement mostly, so low rate on the elevator does fine, if you are flying off grass and a little nose heavy you might need a little more elevator to keep the plane from nosing over on takeoff and landing.
I've never ran out of elevator on my jug on landing, but I have seen plenty of people that have way to much throw when they flare. That tends to get people in bad situations pretty quick with a warbird ballooning and then stalling.
Are you flying off grass or hard surface? If pavement you will be fine, if grass then maybe dial in just a tad more elevator to keep the prop and gear from pulling her nose over too much.
Good luck on the maiden!
Gary
Old 03-11-2017, 04:42 AM
  #2246
chris923
My Feedback: (53)
Of coarse it is a matter of personal preference. I always maiden on high rate. The reason is, if the plane is unstable you might need all the throw possible to recover the plane. If you use only lower rates and you have an bad issue, you might be to busy trying to control the plane to hit the high rate switches. Remember, just because you have the plane on high rates doesn't mean you have to use all the "stick". If you need to use all the "stick" at least you have it. I have been present at to many maiden flights where the pilot "tamed" down the rates to the point where he didn't have enough throw. High rates on a elevator are especially needed on a dead stick landing when extra elevator is needed on a lower speed landing.
Old 03-11-2017, 05:46 AM
  #2247
TonyBuilder
TonyBuilder's Avatar
Thanks.
DLE85
only minimum cut outs in the cowl is needed.
TB
ID:	2204876   Click image for larger version
ID:	2204877   Click image for larger version
Old 03-11-2017, 07:35 PM
  #2248
Ricko1
Ricko1's Avatar
Thanks for the info guys. I fly off grass so high rates with some expo will do. The first flight is always a bit of a worry so thanks for the tips.
Rick
Old 03-12-2017, 06:37 AM
  #2249
HoundDog
My Feedback: (49)
HoundDog's Avatar
Rick
I've always wanted as much through on the surfaces as I can get for Maidens .... Plenty of Trim available too. JMHO Good Luck and have an Awsome day.
Old 04-19-2017, 10:16 PM
  #2250
Ricko1
Ricko1's Avatar
Hi All,<br />
Maiden my kit P47 yesterday and put a couple of more flights on her today. Overall very happy. One click of aileron but quiet a few clicks of down elevator. Used the recommended CG at first but found it a bit heavy in the tail for my liking. Moved the CG to the recommended forward position and she flew like she was on rails. She took up a bit of runway when landing at half flap but there was no way she was going to stall on me. We just had our grass strip cut so flew on mid rates. I thought the plane had a nice feel to it at those rates and was similar in handling to my ESM 72&quot; P47. The DLE 61 spinning a 23 X 10 was plenty but it is loud with that jam tin for a muffler. The plane finished up at 25 lb.
