View Poll Results: A poll
Voters: 31. You may not vote on this poll
Which should I build next?
RE: Which should I build next?
Got a old school balsa usa cub 1/4 scale to build and it has about 3 pages of written instructions and no pictures! There is NO balsa usa 1/4 scale build log on rcuniverse that I have found, I have looked hard, I would love it if you done a build log with lots of pictures.
MN
Raydar check out rcscalebuilder.com there was a couple I saw on there. If I do the cub I would be doing the L-4 grasshopper version of it.
Jordan
Jordan
A flying buddy of mine here is building the Stuka at the moment. It looks like it will be an awesome plane when finished as he is making all of the moving bits on the wings to work (speed brakes etc). The build looks pretty straightforward also (as straightforward as any detailed build from plans can be).
ORIGINAL: cubcrasher
That 1/4 scale cub will seperate the men from the boys.
MN
Well thanks everyone for helping me figure out what to build next. I went with tthe Stuka, I just ordered the kits today probably 8 weeks before I see them though. I'll start a build thread when I start building it.
Jordan
Jordan
MN
I was going to go with the B version as that is what the plans and kit are designed around. The one with the cannons is aG version which has a longer fuselage and a wider wingspan. I do plan on doing a D version eventually, but this is the 2nd plane I've built so I'm still trying to stick to plans. I will probably do some modifications to make it more scale but it will be more or less the way Ziroli designed it.
Jordan
Jordan
