If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 178
  1. #101
    Join Date
    May 2009
    steamboat springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Balsa USA 1/6 Scale Thomas-Morse S-4C Scout Build Thread
    Thanks, Mike! I'm using Elmer's Wood Glue Max, 5 and 30 minute epoxy, and medium and a little thin CA. Trying to move from CA to wood glue mostly.
    I hope you'll share your Nieuport with us. Engine or motor?
    The roofing went on the cabin yesterday. This weekend we're forecast to get a foot of snow. It's coming down!
  2. #102
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've jumped ahead of the instructions again and am forming the cowl cheeks. Lightweight aluminum sheet is provided for these. It's really thin and seems a bit brittle. It's shiny on one side and primered a blue-green color on the other for your choice of finishes. I laid out the angles and scratched the cuts into the sheet with an awl then cut deeper with a single edged razor blade. Then the sheet snapped easily along a steel ruler. A baseball bat was chucked into a vise and the triangular shapes formed to the curvature required. The bat worked nicely. The pieces were clamped between two wood blocks aligned on the bend lines to create the screw flanges. These slight bends were made nice and straight but it's going to take more adjusting to get a flat flange along the edge of the conical cheek shape.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1686164   Click image for larger version.
ID:	1686165   Click image for larger version.
  3. #103
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The cheek material looks like developed lithoplate. That stuff is handy for all kinds of things.
  4. #104
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The fuselage servo installation is made of liteply and popsicle sticks. A servo tray was cut from the kit's die cut sheets. Popsicle sticks are glued onto the tray for servo rails. They run across the fuselage to provide stiffness and good screw anchors. Small liteply pieces are glued to the fuselage sides. They locate the tray at the proper height and are keyed for it to lock onto. After the tray is glued into these pieces some balsa will be glued to both the top of the tray and the fuselage sides to lock everything together. This should be fairly lightweight and locate the servos at the very front of the area above the bottom wing. There will be just enough clearance for a Sullivan 8 ounce tank to slide in past the servos. The tank will be at the bottom of the fuselage while the servos are located at its top and mounted upside down.
    Balsa USA sent the replacement cowl. It's the same size as the original. Therefore I'll try cutting it down. Some fiberglass and epoxy can strengthen the joint.
ID:	1687194   Click image for larger version.
ID:	1687195   Click image for larger version.
ID:	1687196   Click image for larger version.
  5. #105
    Join Date
    Oct 2002
    Cincinnati, OH,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Don't know if you have tried this process, but I used it on the ABS cowl of my DR-1 (and several other ABS parts on other kits). Reinforce the inside of the cowl with fiberglass cloth applied with PVC pipe cement. Epoxy doesn't stick very well to ABS. One does have to be careful not to use a lot of the PVC cement as it will soften and distort the plastic.
    Chuck
  6. #106
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How much 'too big' is the cowl? You might be able to wax the inside of your ABS cowl a few times, spray PVA release into it a couple of times then glass the inside of the ABS cowl for a slightly smaller duplicate. If it is still too big it is easier IMHO to cut the glass one and smooth the joint than to do the same on the ABS one. I really like the popsickle stick idea 'cause I'm a very frugal personage. LOL
  7. #107
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ARUP, your cowl suggestion is sounding very good, not only resizing but getting the better 'glass unit to boot. I've got the ABS cowl drilled and screwed to the top 5 mounting blocks. It's gapped at the other two about 1/8". I don't know anything about wax or PVA release. Car wax? I've got automotive repair glass cloth in coarse and fine weaves, polyester resin, and 30 minute epoxy.
  8. #108
    Join Date
    Jan 2003
    Ithaca, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you do that, check the size of the opening on the cowl. The hole on the BUSA cowl is too big, so if you're going to do a glass cowl it would be a good chance to correct it. It's a pretty distinctive feature of the Scout.
    The cheeks on the fuse side really look good. I'm impressed that BUSA uses thin sheet metal for that. You did a nice job of forming them.
    Jim
  9. #109
    Join Date
    Feb 2010
    boaz, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a few pics of my Tommy.
ID:	1687565   Click image for larger version.
ID:	1687566   Click image for larger version.
ID:	1687567   Click image for larger version.
  10. #110
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Get 'Bondo' brand (polyester) resin and hardener (MEKP- don't get it in your eyes!) from auto parts store ~$20, cheap acid brushes, acetone to clean up, roll of toilet tissue, toothpicks as mixing sticks, graduated mixing cups, 4oz cloth ~ 3 layers in cowl, Sig used to sell small cans of parting wax (no silicone content) and PVA (polyvinyl alcohol) mold release- inquire locally at auto paint shops, Fibre Glast, Inc. etc. Wax and buff the inside of your cowl a few times. Spray (preferred) or brush PVA (it is water soluble) 2 or 3 times, let dry between each application. Now, mix 10 drops of hardener to 1 ounce of resin- a little more hardener if cool- do a test batch and let harden in cup. As you mix it you will see color change from pinkish clear to dark and 'not so clear'. Put pre-cut strips of cloth in cowl and stiple the resin into it. This stuff stinks but needs warm temps (70 and up) for best cure although it will cure when cold. If the resin starts setting up then clean your brush with acetone and mix another batch in another cup and continue adding glass. I always leave a little resin in bottom of cup so that when it hardens it is easier to pop out and re-use cup! You can use epoxy resins but they are more expensive and health hazardous. You will have enough resin left over for many projects! Once the resin has cured you should be able to tease the part out. Curing times depend on temps and the amount of catalyst or hardener you add. The more hardener you add the hotter the mixing cup gets!
  11. #111
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's the cowl mounted with the cooling hole made. BUSA provides a half-round 4" diameter template for this. I scaled from some drawings and think I got a more scale look.
    The valve covers on the Saito are 1/8" from the ABS. I'm thinking about some of that thin aluminum sheet from the cowl cheek sheet spaced 1/16" off the cowl as a heat shield. The engine is completely within the cowl. I could remount it more vertically to solve the clearance issue.
    Because of the engine-to-cowl lack of clearance I may leave the cowl at its full diameter size. Cutting it to fit the fuselage better would have the engine touching it. There is still a 1/8" gap between the cowl and the bottom two mounting blocks which are located at the fuselage box bottom corners.
ID:	1688201   Click image for larger version.
ID:	1688202   Click image for larger version.
  12. #112
    Join Date
    Jan 2003
    Ithaca, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The full scale has another vent right about where your valve covers are. Might give you more air flow in that area and you could skip the heat sink...
  13. #113
    Join Date
    Jan 2003
    Ithaca, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Closer up...
  14. #114
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, BB, I've been thinking of that one for the glow driver. I want to put in the air inlets also.
  15. #115
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've made horns of 1/16" birch plywood and stained them with a Minwax Stain Marker. They space the connector holes 2" apart. Additional bracing was installed.
ID:	1692548   Click image for larger version.
  16. #116
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been busy since Thanksgiving. I make and serve pizza at 9100 feet elevation at Steamboat ski area. Warmest job in town! Good food, great people.
    Here's the rudder control setup. A metal threaded rod from the servo operates a tiller for the pull-pull cords. The cord is nylon coated kevlar. The tiller is 1/16" birch plywood. The cords cross and pass through a former for the straightest lines possible through the near-to-scale openings through the fuselage surface. There is an upward angle created as the cord goes through the fuselage surface and up to the scale horn location. Therefore the cord also puts a bending force on the rudder clevises and horn. I'm hoping that gentle flying will keep things together.
    Hmm...the horn could be angled downward to put it it the plane of the pull cord. All three tail horns could be adjusted this way. It wouldn't be perfect but maybe better. Those ball-in-socket horns Sullivan makes would be perfect.
ID:	1698917   Click image for larger version.
  17. #117
    Join Date
    Jan 2003
    Ithaca, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does the nylon coating prevent abrasion? I've heard kevlar is not very abrasion resistant, but maybe your material is. Nice control arrangement.
  18. #118
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, BB, I think this cord is very abrasion resistant compared to bare fiber. It's slick and shiny, a lot like electrical wire insulation, actually.
  19. #119
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello again. The Scout sat all winter while I skied and made pizza. I was stuck on the elevator linkage. I wanted another tiller bar like for the rudder but just couldn't see how to do it. This one needs to be vertical and handle four pull-pull cables, two to each elevator. Finally it just came together. The upright heavy piece of basswood carries the tiller and is angled so the plywood brace doesn't interfere with the tiller.
ID:	1761900   Click image for larger version.
  20. #120
    Join Date
    Jan 2003
    Ithaca, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice clear photos, thanks.
  21. #121
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yippee! I've got the tail surfaces operated by pull-pull cables. Two cables to the rudder and two to each elevator. Fuselage exits for the cables and the control horns are in scale locations. The lines will probably be Spectra kite line. The nylon-coated kevlar seems too sticky.
    Photos tomorrow. After being stuck all winter this is exciting.
  22. #122
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sullivan brass threaded couplers are crimped onto the Spectra line and used with nylon clevises. The sharp angle from the cable to the elevator cables required another fitting between clevis and horn and the clip part of small fishing swivels were used. It seems like it's going to work. Comments/criticism welcomed.
ID:	1766250   Click image for larger version.
  23. #123
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    cables need tightening and adjusting
ID:	1766266   Click image for larger version.
  24. #124
    Join Date
    May 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A quick video of the elevator movement
    http://www.youtube.com/watch?v=8POcN...ature=youtu.be
  25. #125
    Wagon1's Avatar
    Join Date
    Feb 2005
    Pensacola, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How is she coming? Looks great so far. I love your cable set up. This kit is on my "short" list so I have been following this thread closely. Please let us know how you are doing?
    \"Leave the gun, take the cannolis\"
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
