Balsa USA 1/6 Scale Thomas-Morse S-4C Scout Build Thread
Reply
Old 11-24-2012, 07:59 AM
  #151
debspersonaldogwalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA 1/6 Scale Thomas-Morse S-4C Scout Build Thread
I did some sanding to the firewall also for the same reason.
debspersonaldogwalker is offline
Old 12-12-2012, 06:41 PM
  #152
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Argg!!! What’s wrong with this picture?
Total rookie mistake. I glued the forward block for the cabane strut in the wrong place. It wouldn’t have been so bad but I glued the ply over it before I realized the mistake. I guess I will open up the ply, groove and cut a new block, then slide it in. I have read this part of the instructions ten times to. Oh well.......
Wagon1 is offline
Old 12-16-2012, 04:57 PM
  #153
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is coming along. I made a new block for the forward cabane strut and slide it up against the proper former. I forgot how much I hate to solder. I have a 75 watt gun that never gets the metal hot enough to get the solder to flow. I ended up going with a torch. The solder work is ugly, but strong. My pilot is coming from Santa and I will start playing around with the cockpit and a gun. I bought the 1/6 Lewis which of coarse is not appropriate, but sure looks cool. Some of the cockpits I have seen on this site are amazing. Mine will pretty basic.
Have you thought about a dummy engine? Not much out there that I could find.....
Wagon1 is offline
Old 12-24-2012, 03:05 PM
  #154
w0ace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm thinking of building one of these this winter. I have to go back and start reading from page 1, but I love being able to see the frame work and know what's ahead of me. They all look great guys!!
w0ace is offline
Old 01-16-2013, 05:09 PM
  #155
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found some photos online of the Marlin machine gun that was used occasionally on the S-4C. I built it using balsa and a plastic sheet. The barrels are also plastic. I think I might have built it a bit to big, but it looks okay on the plane. It went together quickly and I have enough stuff left over I could build a smaller one if I need to. The ammo belt is made of toothpicks. I'm not real happy with the way this one came out, but I was just screwing around to see if it would work. I will make another one and will be more careful with the lengths.
Wagon1 is offline
Old 01-16-2013, 09:38 PM
  #156
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good! Great idea with the toothpicks, too! From what is the ammo belt made?
ARUP is offline
Old 01-17-2013, 04:07 PM
  #157
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks ARUP! I used that white cloth tape you use for splints and bandages. Gotta remember to put it back in the first aid kit or my wife will kill me. She still yells when she can't find the wax paper.
Wagon1 is offline
Old 01-20-2013, 05:23 AM
  #158
rockinron7
rockinron7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys ., great thread...... I am currently building the BUSA Tommy wings and tail section are built and will be starting fuse soon my question is engine size I have a choice of a saito - 45, 50, or 56 so far it looks like it is going to be a light build, so wich one do you think will be good. I like scale flying but like a little extra power to get out of trouble ...... Ronnie
rockinron7 is offline
Old 01-20-2013, 06:11 AM
  #159
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fly a VK Nieuport 17 on a PAW 40 diesel swinging a 13x6 at about 7000 rpm. The plane weighs 5 lbs 6 ozs and has the same span as the Tommy but wing area is less due to the small bottom wing, and the airfoil is thinner. It has plenty of power and can loop from level flight, which I don't believe the original could. It looks fabulous in the air.
If your plane is reasonably light you don't need much power and I would not hesitate to use the 45 four stroke with a 12x4 prop. I would make my decision based on the final weight. The full scale plane needed a pretty lengthy run to get off the ground, it looked very slow in the air and its climb was very slow. Any sport plane is a rocket in comparison so don't use that as your benchmark if you want realism in flight.
Jim
buzzard bait is offline
Old 01-20-2013, 06:34 AM
  #160
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
X2 w Buzzard Bait
ARUP is offline
Old 01-21-2013, 06:03 PM
  #161
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the really cool parts of this model is the sheet metal cheeks behind the cowl. You can see DPDW's a few pages back. I totally ruined mine. I cut them okay, but really trashed the metal trying to get the shape right. I was going to pick up another sheet a at the LHS, but decided to just punt. I carved cheek out of built up balsa. They came out okay, but I think my model will just end up looking like a big Guillows kit.
Wagon1 is offline
Old 01-21-2013, 06:04 PM
  #162
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can only upload one pic at a time....here is the cheek after sanding.....
Wagon1 is offline
Old 01-21-2013, 06:16 PM
  #163
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built a box to hold the battery in front of the firewall, thinking I would need all the help I could get to get her to balance properly. I have not put in any of the radio gear yet, but she balances fine with the battery behind the firewall. I am using an OS 52 I got from a friend, so I guess the extra weight of the engine helped. The servos and receiver will go behind the CG, so I guess I will go ahead and use the battery box anyway.
So far I am between 4 and 5 lbs so I may end up a bit heavy.
Wagon1 is offline
Old 03-17-2013, 05:26 PM
  #164
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Makin' some progress. I am a few weeks away from covering. I have some plumbing to do and that is about it. My pilot is from Aces if Iron. I have to work on his goggles, but I'm calling him done. I'm going to try to paint the insignia rather than use the vinyl from BUSA. This will be my first attempt at Solartex so we'll see. I have heard very good things about it. I loved my 20th Cenutry Fabric (used it on my Kadet), but it has not held up well and is very hard to clean up after a day of flying. How is everyone else coming? Anyone have any finished pics??
Wagon1 is offline
Old 06-15-2013, 03:52 AM
  #165
rockinron7
rockinron7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys I have finished my Tommy........ I have all the pictures of the build if anyone is interested, The question now is nose weight I needed a ton.. 1 pound the model comes in at 7.5 pounds I have a fifty saito in it. Now I am very nervous about flying it here are some pictures..... By the way Wagon also my first attempt at solar tex............... LOVEIT !!! I dont think I ever use monokote again nice to paint gose on effortlessly just hold the iron over any wrinkles.
ID:	1891804   Click image for larger version
ID:	1891805   Click image for larger version
Old 07-02-2013, 05:07 PM
  #166
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ron that looks sweet! I'll be at about 6 lbs I think. I'm at 5 with about everything but the engine and tank. I find myself slowing down with the build now that I'm getting closer to actually having to fly the darn thing. I think I'll have one of the "old" guys at the field take her up first.
Were did you get your dummy engine?
Wagon1 is offline
Old 09-29-2013, 02:32 AM
  #167
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally finished. I have had her to the field twice, but the wind has been a bit beyond my liking. I'm waiting for a really calm day....
ID:	1925795   Click image for larger version
ID:	1925796   Click image for larger version
Wagon1 is offline
Old 09-29-2013, 01:00 PM
  #168
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First flight today. She came home in one piece thanks to a lot of help i got at the field (thanks Robert!). She needed LOTS of nose down trim, and a boot full of right rudder. Once trimmed she was a joy and looked great doing laps. Thats really all i had the guts to do. Nosed over on landing, but no damage. 1/2 throttle with the os 52 4 stroke was all she needed most of the time.
Wagon1 is offline
Old 09-29-2013, 03:56 PM
  #169
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congratulations! Your plane looks really good and it's nice to see the olive color with the correct roundel size.
If you add a '38' or a '44' to the front of your '667' you will have a legitimate Army number, i.e., 38667 or 44667.
The full scale airplane needed so much down elevator in level flight that pilots used to use a bungee cord to put forward pressure on the stick to keep from wearing their arms out.
Nice job!
Jim
Old 09-29-2013, 06:09 PM
  #170
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Buzzard. My knees are just now starting to stop shacking. The 667 I painted was from a model my dad built when I was a kid. He built the Guillows Scout that hung from my ceiling until I went to college. It was 667.
Wagon1 is offline
Old 09-30-2013, 05:02 PM
  #171
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nostalgia is good reason for choosing markings. I had never noticed that about the Guillow kit before. Wonder how they came up with it. I've never seen the red and white checkerboard anywhere either, though there is a black and yellow one painted post-war on a Tommy on L.I. I know way too much trivia about this.
Jim
Old 05-02-2014, 03:51 PM
  #172
b206
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thought I would send a picture of my S4C. Saito 56 Monocote covered
b206 is offline
Old 09-17-2015, 02:29 PM
  #173
bettsmums
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New Build
I just got my kit on sale from Graves Hobby Shop. I started building it last Friday. The kit is going together really well and is fun to build. This is my first WW1 aircraft. I followed the instructions for about half of the top wing and then just continued while just glancing at the instructions. It did not take long to get in sync with how Balsa USA intended the kit to be built. The balsa wood selection in the kit is superb.
I am planning on making mine electric with a Tacon Bigfoot 32 and 4S 3300 LiPo. The speed control will below the motor in front of the firewall. The motor will easily swing a 15-6 prop which will really over power everything. I will only use partial throttle. The battery will fit in through the belly hatch and touch the back of the firewall at the top and the aft edge of the forward landing gear block at the bottom. I also made a new tail skid from 3/32 wire and will use pull-pull cables on both the elevator and rudder to reduce tail weight.
ID:	2120344   Click image for larger version
bettsmums is offline
Old 09-17-2015, 02:42 PM
  #174
Wagon1
Wagon1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wait....wait. you started building last Friday and it's framed up already? Holy cow bettsmum. It took me a year to get to that point. Lookin' good!
Wagon1 is offline
Old 09-17-2015, 03:25 PM
  #175
bettsmums
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Construction speeds up when you stop reading the instruction book. I hope that there won't be any left over parts and that it looks like a Scout when it is done. I just did a preliminary CG check and it is looking like it might be nose heavy. It balanced without the motor or speed control and no pull-pull cables and covering right at the marked CG.
Reply
Display Modes
