AMR Air Tractor 402-B 22% with Wren 44 Turboprop
Reply
Old 09-13-2011, 06:17 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AMR Air Tractor 402-B 22% with Wren 44 Turboprop
My father John and I have embarked on building the AMR 402-B 22% kit. Our plans are to install the Wren 44 Turboprop engine. AMR has performed some preliminary sizing modeling and it appears the Wrenn 44 will fit quite well with very minor modification (You can see it the printout in top of box). The kit arrived a few weeks ago. Two boxes. One box contains a very nice 2-piece cowl and the second, larger box contains a very large amount of wood. There is quite a bit of laser cut wood, both balsa and plywood. I am currenlty working on the vertical stab. I will post to this forum as building progress dictates. We will hold off on Turboprop purchase until fuselage nears completion so as not to start the engine warranty too pre-maturely.
ID:	1662013   Click image for larger version
ID:	1662014   Click image for larger version
bberan is offline
Old 09-15-2011, 04:57 AM
dragonbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AMR Air Tractor 402-B 22% with Wren 44 Turboprop
Hi there.AMR? Where can I find this kit?
dragonbuilder is offline
Old 09-15-2011, 06:17 AM
Revy
Revy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aircraft Modelers Research, awesome guys to deal with!
Revy is offline
Old 09-15-2011, 06:08 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
www.amr-rc.com They are located in Canada.
Bob
bberan is offline
Old 10-04-2011, 09:39 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vertical Stab and Rudder complete. Hinging will wait until fuselage fit is verified. Both the vertical stab and rudder turned out very strong. Have now started on horizontal stab and elevator. The kit includes a nice jig that holds all the ribs so that the sheeting can be applied in a simple fashion. The one photo on the stab shows my method of ensuring that the sheeting stayed pulled down firmly to the ribs while the glue dried. Weight at the rear of the sheeting and wide masking tape at the front eliminated the needs for pins which may not have held the sheeting as well near the front where the curviture is greatest. My father John is working on the fuselage and we will post some pictures of that as well. Hoping to purchase the Wrenn 44 Turbo-prop before years end as I suspect we will be ready to finalize installation design with the help of AMR. I have also been researching 3-bladed propellor size and availability for the engine/aircraft combination. Xoar looks to have the right selection of wood props (Recommended by Wren) in the range I am considering. The Wren manual indicates a 22-12 as a choice, but I would like to go to a lower pitch (10 or 8) as I suspect the Air Tractor will be a fairly slow flying airplane. Ground clearance will likely dictate whether I use a 23-10 or possible a 24-8 (Which seems kinda big to me). I am working with the USA Wren distributor on propeller selection.
ID:	1669880   Click image for larger version
ID:	1669881   Click image for larger version
bberan is offline
Old 10-23-2011, 06:53 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been working on the horizontal stab/elevator. The stab and elevator are built on a jig and cut apart later. In the photos, I have yet to cut them apart. I made a few minor changes that are personal preference only. One of those changes involves the elevator horn attachement. I chose to use a slightly different Dubro product than supplied in the kit. The one I used has two pieces than can tilt relative to one another for installing a horn on an angled surface. The other change I made was to glue in the tubes for the aluminum spars prior to sheeting the bottom of the horizontal stab. Normally this step is performed much later as part of the fuselage contruction. I did this because I wanted to ensure the tube/rib joints actually got glue on them. Also, I thought it would be easier to ensure that both stabs matched one another (No twist between them) if the tubes were glued in while both stabs where lying on the same flat surface. I also took advantage of the jig interface cutouts in the ribs. I bought a 1/4" square piece of steel from a hardware store ($5.00) and placed it in the rib cutouts to help reinforce straightness while the expoy for the tubes was drying. I also installed an additional piece of hardwood that interfaces with the aft aluminum spar tube for the purpose of locking the aluminum spar with a screw. My dad is working on the fuselage, which has made progress, I just need to get some photos.
ID:	1677794   Click image for larger version
ID:	1677795   Click image for larger version
ID:	1677796   Click image for larger version
bberan is offline
Old 12-31-2011, 11:42 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some more photo's of completed stab/elevator. I did a few things a little different. I used a thin sheet of fiberglass for the servo cover instead of the supplied plywood piece. Nothing wrong with the plywood, just personnel preference. Also, for the elevator/stab gap filling strips, I used a piece of 1/16" basswood instead of the suggested 3/32" balsa. I was concerned the edge of the balsa might get beat up. Also, because I used basswood, I was able to sand a bevel in the aft edge for a thinner gap. I also beefed up the joint with some small triangular stock. I also drilled tiny holes directly above each hinge set screw so I can seperate the elevator from the stab if neccessary. I have also included a photo of the Wren 44 Turboprop. The propellor is Xoar 22 X 8, 3 bladed. I am keeping the pitch low as the Air Tractor is not a hot rod.
ID:	1707715   Click image for larger version
ID:	1707716   Click image for larger version
ID:	1707717   Click image for larger version
ID:	1707718   Click image for larger version
ID:	1707719   Click image for larger version
bberan is offline
Old 02-20-2012, 01:23 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Work on th airplane continues. Here are a few photo's of the fuselage and wings. I am using two servos for rudder and tail wheel. I prefer this as it allows me to use mixing. I can have one servo behavior for the rudder and a different servo behavior fot the tailwheel. It is nice because the tailwheel will only move when the rudder moves based on a rudder stick input. The tailwheel will not move as a function of rudder/aileron mixing (Which is what I want). In addition, I can have the tailwheel movement stop altogether as a function of throttle. I usually set this feature to somewhere above half throttle so that for flying around, the tailwheel doesn't move at all. We have now run the Wren 44 Turbo prop several times. The engine runs very well and seems as though it will have plenty of power. I have located a place http://www.sacmidwest.com/index.php that makes scale instrument panels. I am having them make a scale panel from a photo I received from Air Tractor of the 402's instrument panel. Will post a photo when it arrives.
ID:	1729427   Click image for larger version
ID:	1729428   Click image for larger version
ID:	1729429   Click image for larger version
ID:	1729430   Click image for larger version
bberan is offline
Old 02-26-2012, 06:29 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have started to fit the turboprop engine. here are a few photos.
ID:	1732568   Click image for larger version
ID:	1732569   Click image for larger version
bberan is offline
Old 03-06-2012, 10:05 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I received the new instrument panel for my Air Tractor. The instrument panel was made by http://www.sacmidwest.com/index.php. I had them work off of a photo I received from the Air Tractor company. It turned out pretty nice.
bberan is offline
Old 03-06-2012, 05:35 PM
brenthampton79
brenthampton79's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool wish I could turn loose the money to build one with a turbine
brenthampton79 is offline
Old 03-08-2012, 08:57 AM
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice!
Super08 is offline
Old 03-08-2012, 09:31 AM
DENTO
DENTO's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Super08
Very nice!
ADD TO THAT
REGARDS
DENTO is offline
Old 03-28-2012, 06:41 PM
c114
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought one of of these kits, should be here next week. I do believe I'm going to go the turbo prop road as well. Am really looking forward to how it flies, hope there is vidio.
Rolly
c114 is offline
Old 04-05-2012, 06:32 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will definitely provide video of model when complete and flying.
Bob
bberan is offline
Old 05-06-2012, 11:01 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few photos of the wing tube installation. As you can see, alot of space is required. Fuselage was set at 0 degrees both foward and aft and side to side. The wings were installed and only minor adjustment was required to get the same dihedral on both wings. Wing incendence was also checked to make sure it was equal on both sides. The design appears to be set for 4 degrees positive incidence. Both wings were right at 4 degrees without any adjustment. The phenolic tubes were taked in placed and then everything removed for a thorough gluing. Wing sheeting will be next.
ID:	1759546   Click image for larger version
ID:	1759547   Click image for larger version
ID:	1759548   Click image for larger version
ID:	1759549   Click image for larger version
bberan is offline
Old 05-07-2012, 10:53 PM
t6racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob
I have a wren turbo prop in a PC6 120 inch wingspan weight 28lbs 20x12 3 blade prop.
I have also this kit to build for the turbo prop, the porter is balistic on full throttle the skytractor should come in around 28 to 30 lbs I think. I fly the porter on below half throttle to half throttle it will will pull up at at 80 deg at full throttle & hit the moon if I don't get off the throttle, this motor is equal to a 100cc gas motor.
Great motor you will have a ball.
t6racer is offline
Old 08-25-2012, 11:46 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some photos of preliminary engine and cowl installation. More trimming is needed around exhaust to avoid burning the fiberglass. There are two additional pieces being used in addition to the modified firewall. There is a 3/4" spacer and a 3/16" spacer. This gets me to the right distance for the spinner to cowl interface. AMR provided me the modified firewall and the 3/4" spacer. They also provided me with a template for the 3/16" spacer. This spacer will serve two purposes. 1) it's a spacer and 2) a bulkhead of sorts that I using to better isolate the hot section from the intake. You need to avoid hot air from getting back to the intake as it will raise the overall engine operating temperature.
ID:	1795131   Click image for larger version
ID:	1795132   Click image for larger version
ID:	1795133   Click image for larger version
bberan is offline
Old 08-25-2012, 11:48 AM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some more photos. They all wouldn't fit in one post
ID:	1795135   Click image for larger version
ID:	1795136   Click image for larger version
ID:	1795137   Click image for larger version
bberan is offline
Old 08-28-2012, 06:27 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few photos of the inlet which is mounted to bottom of cowl. It is held on with 6 #2 sheet metal screws from the inside. Because of the turboprop, the inlet will be functional and provide a source of cool air to the engine, well away from the hot exhuast.
ID:	1796231   Click image for larger version
ID:	1796232   Click image for larger version
bberan is offline
Old 09-03-2012, 12:39 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few more photos after the exhaust have been permently installed and the cutouts enlarged to proper clearance.
ID:	1798025   Click image for larger version
ID:	1798026   Click image for larger version
ID:	1798027   Click image for larger version
ID:	1798028   Click image for larger version
bberan is offline
Old 09-03-2012, 04:20 PM
redbiscuits
redbiscuits's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very Nice!
redbiscuits is offline
Old 09-03-2012, 10:03 PM
Avistarpilot
Avistarpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow! What an awesome project. I've got the chance to work on these things in real life and seeing a model of it, and how everything is exact to the real thing to the last detail is just awesome! Love the turbo prop exhaust ducts. You don't realize how big these things are until your up close and personal to them. The Air Tractor 802's are insane!
Can't wait to see the finished project. Hopefully the wings don't crack like the full scale birds do!
Avistarpilot is offline
Old 09-04-2012, 06:23 AM
daveopam
Moderator
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fantastic work! Wish I had your patience.
david
daveopam is offline
Old 12-12-2012, 06:43 PM
bberan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Starting the finishing process. It will take awhile. Horizontal stab/Elevator is complete. Laying out lines on fuselage with paper templates. Photo on computer screen is the scheme I am going for.
ID:	1829417   Click image for larger version
ID:	1829418   Click image for larger version
ID:	1829419   Click image for larger version
bberan is offline
Reply
Display Modes
