***CUB BROTHERHOOD***
Reply
Old 12-07-2011, 08:52 AM
  #376
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ***CUB BROTHERHOOD***
That is what I do to my bolts. I cant see in there and the rounded ends help guide it. I start it with my fingers first, then get with it using the ball driver. Aligning the wing is important. I usually use my bigger tool box to hold the wing, when someone isnt there to help. I'm gonna build a stand to hold the wing at the right height and angle for next year.
Edwin
Edwin is offline
Old 12-07-2011, 09:01 AM
  #377
rafeeki
rafeeki's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had on my Bud Nosen cub two short dowels that would align the wing in place, putting in the bolts after that was a cinch although a helper had to suport the wing panel before I could add the strut.
Now that I crashed the plane and totally had to rebuild the cabin I am going with an aluminumwing tube, this will provide more suport and make assembly much easier.
Hope this helps.
rafeeki is offline
Old 12-07-2011, 09:11 AM
  #378
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw exactly what you are talking about 2 weeks ago at our field. He painted his black so it wasnt that obvious. Good idea. The busa has dowels for alignment too.
Edwin
Edwin is offline
Old 12-08-2011, 08:33 AM
  #379
jrb1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some photos that might be of interest:
ID:	1697070   Click image for larger version
ID:	1697071   Click image for larger version
ID:	1697072   Click image for larger version
ID:	1697073   Click image for larger version
ID:	1697074   Click image for larger version
ID:	1697075   Click image for larger version
ID:	1697076   Click image for larger version
ID:	1697078   Click image for larger version
ID:	1697079   Click image for larger version
ID:	1697080   Click image for larger version
jrb1 is offline
Old 12-08-2011, 09:44 AM
  #380
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For those of you who want the ultimate Cub here ya go http://team-aeroscale.com/
acerc is offline
Old 12-08-2011, 10:34 AM
  #381
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahhhhh... Nice!  A little pricy for a "model" aircraft, but very nice!  I like it!
Cub Flyer Fresno is offline
Old 12-10-2011, 12:33 AM
  #382
spudandcat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day fellas, just found this thread,
I have a WM 1\4 CW with a ASP 1.60 twin and old faithful WM 48 CW with a ASP .52
Can I be in to? Love my Clipped wing Cubs
thanks
Spud
spudandcat is offline
Old 12-10-2011, 01:03 AM
  #383
crash bandicoute
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JRB1, what size cub is that you have? i only ask because of the heli you have inside for your pilot. looks nice.
crash bandicoute is offline
Old 12-10-2011, 08:06 PM
  #384
crash bandicoute
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just slightly off topic, but what size floats would be about the right size for the 1/5 scale cub from Sig? i have a pair of .40 GP floats for my GP .40 size cub, but i'm pretty sure it's not 1/5 scale since the Sig anniversary kitis a little bigger. should i get the bigger set for the Sig kit? or would these still be about right? sorry for posting here, i didn't want to start a new thread just for a question.
these are the .40 size:
SPECS: Length: 34.5"
For planes weighing: 5 - 9.5lbs
From tip to step: 17.75"
these are the .60 size:
SPECS: Length: 41"
For planes weighing: 8 - 15lbs
From tip to step: 20"
i'm not sure if the .40 size would be sufficient and don't want it to sit too low in the water or have issues getting up on plane and rotating.
Old 12-11-2011, 10:07 AM
  #385
Jaybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe the rule of thumb on float length is 75% of the fuselage length - prop hub to rudder hinge line (not including the moving surface). There are a lot of great float threads out there if you need more help. To answer your question we'd need that dimension.
I have the Hangar 9 Cub (80" span) that is 44" from prop hub to the rudder hinge on a set of Great Planes floats that are 34 1/4" long.
I think they work great and float the plane with ease. I have a Saito 56 four-stroke for power which is pleanty but it sometimes can require lifting one float up to break free of flat calm water...just like the full size.
Here is a video link - http://www.youtube.com/watch?v=4iRgreIs30Y
Jaybird
ID:	1698567   Click image for larger version
ID:	1698568   Click image for larger version
Jaybird is offline
Old 12-12-2011, 08:35 PM
  #386
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
... more pedal plane J-3 Cub progress! Airframe and wings 'mudded' and will apply orbital sander tomorrow. Sanding sealer will get put on then sanding. You can see some parts pre-painted.
ARUP is offline
Old 12-13-2011, 08:14 AM
  #387
crash bandicoute
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ARUP, that's so awesome. what are the overall deminsions goingto be?
Old 12-13-2011, 08:38 AM
  #388
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Crash Bandicute- this pedal plane is big enough for 2-5 year old kids. ~3' span and ~4' long. I was thinking of putting a Hazel Sig clipped wing scheme on it but then decided to stick with yellow for the overall visual impact of that color. If I was a kid getting this I would go 'ape' with glee, that's for sure! Isn't the little wooden engine and PVC pipe intake and exhaust idea cool? Marv at Aviation Products sure had great ideas designing these! The plans are really detailed.
ARUP is offline
Old 12-13-2011, 09:18 AM
  #389
Cub Flyer Fresno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ARUP,
You might want to check your wing loading.  Especially with two 5 year olds in there and this thing being pedal powered, I doubt they'll ever get off the ground!  [X(]
But in all seriouness, that's an awsome toy!!!  Oh to be a kid again!!!
Take care,
David
Old 12-13-2011, 09:20 AM
  #390
rafeeki
rafeeki's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whats the wingspan????
rafeeki is offline
Old 12-13-2011, 01:04 PM
  #391
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey David- that's funny! What's really funny is that I took some folks I work with to dinner and was telling them about project. One lady was believing it all when I told her it was an airplane for 2y/o to get in and really fly! She wasn't blonde, either. Everyone, including her, had a good laugh!
rafeeki- it has a span of ~3 feet maybe 4. It's a clipped winged Cub!
ARUP is offline
Old 12-13-2011, 01:06 PM
  #392
rafeeki
rafeeki's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am sure he will be using it both in/ outdoor. My suggestion is to make it pass through the smallest door opening in your house)
rafeeki is offline
Old 12-13-2011, 01:13 PM
  #393
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi rafeeki- very excellent point! It's for my neighbor's grandson. I'm trying to 'plant the airplane bug' in the little tyke! Sneaky- aren't I! Plus- it's a yellow Cub to boot!
ARUP is offline
Old 12-15-2011, 07:38 AM
  #394
jrb1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: crash bandicoute
JRB1, what size cub is that you have? i only ask because of the heli you have inside for your pilot. [img][/img] looks nice.
H9's 1/4 scale Cub.
Someone asked if flew my mCX w/A123s (they know they're my fav battery); I said sure Dan said the posting made him laugh and blow beer out his nose.
I do the Cub w/A123-10S2P for 18minutes of flying and 18minutes to recharge!
jrb1 is offline
Old 12-15-2011, 01:15 PM
  #395
SCOTT42
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I want in, this is a carl goldberg kit im not sure of the scale size but has a wingspan of 68" and is a cliped wing version. It is powered by a saito .91 and it has floats aswell. Oh what number would I be now? This plane is about 10 years old or older, build by a good freind of mine.He wanted me to have it and was going to give it to me but his wife threw a fit and told him he needed to sell it, so he sold it to me for a doller. I love this plane.
ID:	1700392   Click image for larger version
ID:	1700393   Click image for larger version
SCOTT42 is offline
Old 12-20-2011, 03:38 PM
  #396
crash bandicoute
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so i have a question about the scale type cub landing gear. i've seen on some peoples planes that the i guess compression braces, that the bungees go on are sometimes straight so the bungees are parallel with each other, but the set i got from robart for the 1/5 scale, are 90 degrees from each other, so the bungees more or less twist, from one 'post' to the other. actually, this is the only time i've seen them twist like that. is that right or wrong, or doesn't matter? i've seen on actual aircraft they twist like that, but...
Old 12-20-2011, 08:07 PM
  #397
5blue
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
want to be a cub brother - hangar 9 cub
ID:	1702849   Click image for larger version
5blue is offline
Old 12-21-2011, 09:04 AM
  #398
crazystick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like to get on the GOOD things going on here. Had a Goldberg Anniversary Cub,need to repair Sig 1/4 scale Clip Wing,need to finish a Balsa USA L-4,am repairing a Dave Patrick Super Cub and I am flying a Hanger 9 1/4 scale J-3 powered with a CRRC 26R.Its a blast to fly !
Crazystick
ID:	1703084   Click image for larger version
crazystick is offline
Old 12-23-2011, 03:04 PM
  #399
morganflyboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All
Just wanted to wish all of the CUB BROTHERHOOD members a VERY MERRY XMAS and a Happy New Year. Hope everyone gets that NEW CUB PROJECT they have been wanting for. I am hoping that SANTA brings me that Kavan 50cc engine for my Balsa USA 1/3 Scale Cub project this year.
Cub Brother # 33
morganflyboy is offline
Old 12-23-2011, 03:56 PM
  #400
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got fed up with the way I've been carrying my cubs around when I put them in and out of the trailer, or in and out of the garage. This simplifies it a lot and all the parts can be bought at the hardware store. The wing nut screws onto one of those wood/machine screw combos. The J-3 needed a little engine maintenance yesterday and the NE-1 got moved in and out of the house to set the decals, too cold in the garage.
Edwin
ID:	1704209   Click image for larger version
Edwin is offline
Reply
Display Modes
