***CUB BROTHERHOOD***
Reply
Old 11-05-2011, 04:53 PM
  #201
Steve
Steve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ***CUB BROTHERHOOD***
some of the detail.
Steve is offline
Old 11-06-2011, 03:07 AM
  #202
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JoeR
Quote:
ORIGINAL: WacoNut
When I use Koverall I use Polycrylic to fill the weave. I have never used Polyurethane.
With the PolyC I thin it about 15% with water and brush 4-5 light coats with a foam brush and lightly sanding between coats after the 2nd coat. Be very careful not to sand into the fabric especially at the sheeting edges or over ribs.
This will leave a bit of the weave showing which is what I think you are looking for. I also use tapes from Pink-It.net and these tapes are cut from Solartex and iron down over the rib stitching.
There are many ways of applying and finishing the fabric, I would do alot of research on the different methods and see which one you like best.
I am attaching a couple pics of my 33% Waco during the covering process. Polycrylic was used to fill the weave and the re-inforcement tapes are from Pink-it. I was able to cover the entire fuselage with one piece of fabric.
Later!!
Anthony
Anthony that looks fantastic! Would this be an appropriate or scale covering material/method for the Cub?
Also, how much more does this covering method weigh over standard coverings?
Before laying down the rib tapes from Pink-It.net you might consider some rib stitches from Ken Kasmenko in BC, Canada. Here's a pic of my PA-12 wing with stitches but before rib tapes. Cheers!
ARUP is offline
Old 11-06-2011, 04:39 AM
  #203
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ARUP
Quote:
ORIGINAL: JoeR
Quote:
ORIGINAL: WacoNut
Later!!
Anthony
JoeR,
This would be a scale application for the Cub. The Cub is all fabric covered and has reinforcement tapes over all the structure on the fuse and rib tapes over the rib stitching. I also use the rib stitching from Ken Kasmenko. He used to market it under the name Scale Rib Stitch. Not sure if he is still in business. I had enough tapes left over from my 33% Waco to do my 33% Cub. I lost most of the pictures of the building process of my 33% Cub due to a hard drive failure on my PC. I had my Waco backed up on CD and not the Cub[:@].
Later!!
Anthony
WacoNut is offline
Old 11-06-2011, 04:55 AM
  #204
heritageman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Waco Nut, how much of the stitching would I need for the 1/4 sig cub ?
heritageman is offline
Old 11-06-2011, 05:05 AM
  #205
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They come in 2" wide strips 11" long. They must be cut to the width that you will be using on the Cub. I believe the 1/4 Cub kits have 1/4" rib caps? can't quite remember. The Full scale Cub had 1/4" Rib caps so the models are way over built IMO. Anyhow just measure the rib from L/E Sheeting to the T/E and and the number of ribs and order enough to stitch the tail surfaces in the same manner. It doesn't take that much to do the stitching(maybe $20).
Later!!
Anthony
WacoNut is offline
Old 11-06-2011, 05:51 AM
  #206
roaddog2
roaddog2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sign me up! I've got a Dave Patrick Super Cub hangin' in my garage waitin' for me to heal enough to fly 'er.
RD
Montross, Va.
roaddog2 is offline
Old 11-06-2011, 05:59 AM
  #207
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also make them for next to nothing. Made this board with stuff I already had, stitches made of fishing line and medical tape. All of which I had.
acerc is offline
Old 11-06-2011, 06:05 AM
  #208
biam
biam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recently came across this thread, way cool, I have a eight year old goldberg cub with a .52 rfs magnum, has to be my favorite plane! Put me down as a member too!
biam is offline
Old 11-06-2011, 07:27 AM
  #209
JoeR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
Can you explain your process or link to a how-to? Thanks!
JoeR is offline
Old 11-06-2011, 08:06 AM
  #210
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The board is made of a piece of 1x8. I drilled holes 1/2' in from the edges and 1/4' apart.the green in the center is an old cutting mat cut to fit. In the photo's below first is the stitches in place. I used thread for visibility. The second is with the medical tape applied and marked for 1/4' strips. The third is with a strip cut. The board is also marked on both outside edges for measuring as needed. These stitches are placed at 1/2". And the two black lines runing parallel with the board are for aligning the tape. I can make stitches anywidth up to 6" and any lenght up to 3'. If you use thread a regular knife will do. But for fishing line the curved blades work best. IMHO
acerc is offline
Old 11-06-2011, 08:20 AM
  #211
CK1
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been using products from both "Pink -It" and "Scale Rib Stitch" , These are time saving products. I have used many different methods of stitch and tape and have found that to me it is worth the money to use these products for the ease and uniformity that they provide me.
CK1 is online now
Old 11-06-2011, 08:24 AM
  #212
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To each his own. I'm just offering up alternative's.
acerc is offline
Old 11-06-2011, 09:40 AM
  #213
JoeR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I appreciate the alternatives to pick from. Thanks!
JoeR is offline
Old 11-06-2011, 02:06 PM
  #214
rcpilotaviator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dont have a cub, but going to build one. You cub guys tell me what you think about this one, with a DLE 30.
Do you think it will fit ok or should I go with the DLE 20
http://ecsvr.com/abm/shopexd.asp?id=2
rcpilotaviator is offline
Old 11-06-2011, 02:13 PM
  #215
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You gonna build one or buy one? Either way a dle 30 will fit and have power to spare.
acerc is offline
Old 11-06-2011, 02:14 PM
  #216
G.Barber
G.Barber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rcpilotaviator-
I have the Wings Maker 1/4 scale Super Cub with a JC EVO 28 cc Gas engine in it. It's a great combination!
And I did a little more to the plane as well...
I do like all Cubs, but I LOVE Super Cubs!
G.Barber is offline
Old 11-06-2011, 03:25 PM
  #217
rafeeki
rafeeki's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will be underpowered with the 20
rafeeki is offline
Old 11-06-2011, 04:50 PM
  #218
rcguy56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
count me in also, great planes fabric covered 40 arf
rcguy56 is offline
  #219
cannonball200
cannonball200's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A DLE 20 is perfect for your 1/4 scale J-3 Cub. That is what I'm using in mine. I just built a 72" 14 1/2# Waco and installed a DLE 20 in it. The 20 flies it awesome with plenty of power and speed. I only use about 1/2 throttle or less on it.
Now, if you are wanting to hover the Cub or Waco, then it needs a larger engine for sure.
Cub brotherhood # 50
ID:	1683103   Click image for larger version
ID:	1683104   Click image for larger version
cannonball200 is offline
Old 11-06-2011, 05:12 PM
  #220
rcavi8or
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i want in h9 80inch and h9 1/4 scale (first version)
rcavi8or is offline
Old 11-06-2011, 05:45 PM
  #221
rcpilotaviator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cannonball200
Thanks for the pictures, I think I will go with the dle 30 for extra power. By the way nice full size cub in your gallery. Is that your and do you keep it at willy post airport?
Old 11-06-2011, 05:47 PM
  #222
GPutt33
GPutt33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I've been looking for a cool place to ask about other folks Cubs, and here it is
Here is my AW Super Cub before it's maiden flight and a quick shot of my cockpit and pilot
Hope you'll let me into the 'Cub Club' ............[8D]
ID:	1683116   Click image for larger version
ID:	1683117   Click image for larger version
GPutt33 is offline
Old 11-06-2011, 06:01 PM
  #223
rcpilotaviator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cannonball200
Old 11-06-2011, 06:08 PM
  #224
rcpilotaviator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Going to buy a cub arf, know time to build. Looks like airborne models has theirs at a good price. Would love to have the Aero works, but for that price I could buy two. Going to go with the DLE 30 even though the DL20 would power it pretty good.
Old 11-06-2011, 06:13 PM
  #225
actionjackson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Is there room for one more Cub fan? When I was a kid I used to ride my bike to a small local airfield. The staff there was nice enough to let me hang around and I fell in love with the Cubs. The first one I built was a 36” rubber powered Piper Super Cruiser kit from Sterling when I was about 14. My first RC Cub was the 1/6th Sig where I learned the hard way that those wing struts ARE functional. I currently have 2 1/6th Sigs, 2 Pilot PA- 18s a ¼ scale Pilot Cub and a little Guillows kit. Has anyone out there built the ¼ scale Pilot Cub? I was curious if the OS FT-1.20 that is shown in the plans was enough engine for it. Thanks for the great thread!
actionjackson is offline
Reply
Display Modes
