***CUB BROTHERHOOD***
#1601
Yes, that's a Sig 1/4 scale full wing, not clipped. The front tubing is 3/4" and the rear is 5/8", although the rear could have been 1/2" to be closer to scale. The ends were made from scrape aluminum I pick up at work and (before I bought my belt/disk sander) were made by hacksawing and filing to shape. That's the part that was A LOT OF WORK! And that's also the time I decided to invest in a belt/disk sander! Not that much money from Harbor Freight.
#1602
I would not use the KS aluminum streamline cross section (CS) tubing without internal stiffening. Hardwood dowels inserted the full length and epoxied at the ends will do the job. However, the FS J3 Cubs i have seen and the FS detail drawings I have seen on replacement parts listings show the struts not as streamline CS, but as rectangular CS with full radius edges. Were later J3 Cubs or maybe the Super Cubs fitted with streamline CS struts? Thanks.
#1604
Original Tear Drop (egg) Shaped Struts---- Full Size Cub
The J3 front strut has a 2.406 major axis x a 1.377 minor axis.
The J3 rear strut has a 1.780 major axis x a 1.060 minor axis
The jury struts are 1.473 major axis x a 0.492 minor axis.
The spreader tube is 0.500 od.
Sealed Replacement Streamline Struts---- Full Size Cub
The J3 front strut has a 3.938 major axis x a 1.375 minor axis.
The J3 rear strut has a 2.362 major axis x a 1.000 minor axis
The jury struts are 1.560 major axis x a 0.550 minor axis.
The H9 struts are 6061 aluminium t6 hard... they are stiff and strong on their own... the only issue I had was the ends were loose and I didn't like the soft aluminum clevis they provided to attach to strut end to the fuse... I saw a youtube video where one of the struts actually pulled off the fuse... luckily they managed to land it with only some minor damage... I ended up drilling out the pins that held the ends in, and reset the wing mount ends back in with some JB weld and a couple of 2/56 screws that passed all the way through the strut and inserts, then cut and ground the screws flush with the surface of the strut... then I totally re-worked the fuselage end of the struts and made all new hardware from some stainless steel bits I got from the hardware store.
John M,
#1605
My Feedback: (9)
NC
I built my struts out of K&S, so far so good. When you consider the tensile strength of them, I don't see a problem. They are just "pulled" and a little "pushed" but not folded sideways unless you plan to do maneuvers outside the envelope of a Cub. When I built mine I used aluminum plugs on the ends so I could get a scale appearance. They were JB Welded in and then pinned with a brass rod. It was a LOT of work but they came out real nice IMHO.
#1606
#1607
CO
Have you ever heard of “Paralysis by Analysis? “ Well that’s what I’ve experienced in my quest to modify this already built ¼ scale Sig Cub to have a working door/window. I read all of the threads, studied the plans, build manual and spent countless hours staring at the fuselage…and not really getting anywhere…“Paralysis by Analysis”. So Last night, I finally decided to just move forward and “get ‘er done”. So I cut out the door and that in itself was progress! I’ve come to the conclusion (Thanks John M and CFF) that the main wing loading is transferred to the fuselage through F5 and F7 and that the cabin top and the center stringer/fuse side, now removed, served to add rigidity to the fuselage. So I plan to replace that rigidity with a spruce stringer that runs beneath the bottom of the door cutout from F5 to F7 and make a plywood cabin top. I will keep the spruce cabin top and cut away the balsa that’s laminated to it. Of course I don’t want the entire top of the cabin to be a solid piece of ply so most of it will be cut out. Now, with the exception of the door cutout, all of this is theory…but I think it will work. I’ll post a photo or two when I’m making “real” progress.
M
M
#1609
Well done Muphey, you're one step ahead of me... I'm still planning it out as you have done... I'm way past the “Paralysis by Analysis”, I think insanity is setting in, LoL.... you are doing it the right way, just get in there and do it.... I'm going to do Cub Man's music wire re-enforcement, with couple of tabs added, made from some brass stock, silver soldered to the music wire right at F-5 (one either side) to tie the remainder of F-5 to the music wire / Cabane's... the tabs will be basically a piece of brass with a hole drilled the same size as the music wire and soldered in place, then attached to F-5 with a couple 4-40 Flathead screws / nuts (Flatheads facing the wing) ... the tabs will be hidden under the two cabin balsa blocks that are glued to the forward side of F-5... I'm going to leave F-7 along... take the long side pieces away from F-6... the music wire will be tied into the fuse at the bottom at F-6, run up the vertical window pillar at F-6 to the Cabane's; along the Cabane's past F-5 (but tied into F-5 with the brass tabs) and down the forward window stay and into the fuse... then remove the long sides form F-5.... I know I'm being anal, but it will make me feel it is secured with the tabs.
***Edited*** the music wire will be hidden inside the Piller's, Stay's and Cabane's
John M,
John M,
#1610
Something like this... I don't have a cad program, so I just drew it up in paint... the green dot is the music wire, its not to scale so it will be bigger, at least 5/32 - 3/16 wire.
John M,
John M,
#1611
Anyone know where one can purchase the side windows for the Anniversary Cub? I recieved this kit partially built and its missing the windows and Cowl. I'm going to purchase the fiberglass Cowl from FG Specialties.Thanks for your help.
#1613
NY
You will have to call Tower Hobbies. They still list the kit as being available, but no individual parts are listed.
Here are the part numbers from the Goldberg website, maybe they can help over the phone.
http://www.carlgoldbergproducts.com/.../gpma0963.html
I looked at the manual and it really doesn't say much about them. Are they preformed or flat sheet? if flat sheet, like the windshield, you can use any plastic from your LHS to replace them.
maybe post on one of the actuall Goldberg Anniversary cub threads for more info?
https://www.google.com/search?client...67.nZRZxc4K4CI
HTH,
Bill S.
HTH,
Bill S.
#1614
I have been using a FREE 2D Cad program that is compatible with ICad. It is called "intellicad" and was given free to entice users to buy their 3D cad software. I am not well versed in ICad but had no real problem using intellicad. I just kept pulling down the menu selections until I found the one I wanted. Give it a try. I have used it to dimension a scanned part like a firewall so I can add holes to use for a drilling template. Also good for getting an unshown dimension from a scaled drawing after scanning that drawing.
Enjoy!
#1615
Getting closer to Covering! Have both full wings assembled, just have to finish the ailerons and servo mounts! Have the left Clipped wing done too, with aileron and servo mounted. I should be able to knock out the aileron and servo mounts in an hour then move onto the struts. Eager to try out the Koverall.
#1616
Hi John,I have been using a FREE 2D Cad program that is compatible with ICad. It is called "intellicad" and was given free to entice users to buy their 3D cad software. I am not well versed in ICad but had no real problem using intellicad. I just kept pulling down the menu selections until I found the one I wanted. Give it a try. I have used it to dimension a scanned part like a firewall so I can add holes to use for a drilling template. Also good for getting an unshown dimension from a scaled drawing after scanning that drawing.Enjoy!
John M,
#1617
Richard (Mako17)
Here is a link to the parts list for a Goldberg: http://www.carlgoldbergproducts.com/...pma0963.html#1
The K-63 Side Window (set) is on the second line Part # 1611 and the retail price is $21.96. You can use this information to order from Tower Hobbies or any other Goldberg/Great Planes dealer.
#1622
My Feedback: (50)
Guys i'm sorry but a lot of the early cub den pages were after thoughts. I wish I had taken a bunch of photos to add to the pages. The wire setup in the open door and windows adds a lot of strength into the structure. I'm redoing the site, so if anyone has some good photos, send them to my email and they may be added to the update....
#1623
CO
I’ve made some progress! I cut out the door opening, installed a hardwood rail on the bottom of the opening and balsa on the aft side. Then I lined the opening with 1/32” ply. To reinforce the fuselage, hopefully making up for the loss of rigidity by cutting out the door, I first cut out the balsa laminated to the spruce cabin top then added the ply stiffeners to the cabin top. This will also replace the wing mooring blocks. ¼” blind nuts will be used instead of the threaded wood blocks. So with apologies to Cub-Man and the wire method, I think there is more than 1 way to skin a cat…or modify a Cub.
I’m also in the process of making a door…but slipped back into the “paralysis by analysis” mode because I would really like the working door latch but will most likely make a couple prototypes first…
M
M
#1624
I’ve made some progress! I cut out the door opening, installed a hardwood rail on the bottom of the opening and balsa on the aft side. Then I lined the opening with 1/32” ply. To reinforce the fuselage, hopefully making up for the loss of rigidity by cutting out the door, I first cut out the balsa laminated to the spruce cabin top then added the ply stiffeners to the cabin top. This will also replace the wing mooring blocks. ¼” blind nuts will be used instead of the threaded wood blocks. So with apologies to Cub-Man and the wire method, I think there is more than 1 way to skin a cat…or modify a Cub.I’m also in the process of making a door…but slipped back into the “paralysis by analysis” mode because I would really like the working door latch but will most likely make a couple prototypes first…M
Here's what I've done so far... I haven't cut the door out yet, but its marked and ready to go... got a bit of glare from the flash (old sucky camera)... 3/16 music wire... 3/8 x 1-3/4" .067 brass tabs... I will cut and bend the wire 90 degrees, and poke them through some holes drilled through the plywood sides on the fuse, and then set in epoxy.
John M
Last edited by John_M_; 02-22-2014 at 08:23 PM. Reason: Brass Tab length increased to 1-3/4" long
