***CUB BROTHERHOOD***
#1905
I think I am getting the hang of covering with fabric now. Started on the tail last night using Stix-it and Koverall, then one coat of clear dope and it looks good.
Question on the tail fairing though, the plans and manual dont clarify the shape very well. What does the fin fairing look like? Does it taper back or does it have a curve towards the tail?
#1908
I just came across this thread and figured I should join. Up here in the frozen north we have lots of building time and I have just finished my 1/4 scale Sig Cub up to the paint part. I'm waiting for it to warm up so I can do a spray job in the garage. It's a full span Cub which I'm going to rig for glider air tow. Power is going to be an inverted Saito 180. I'm really happy with the plane which I picked up as a partially completed project at a local auction. It required some structural construction and covering which is completed in Solartex. There's lots of good information in this thread.
I'll post some pictures when I can get it outside.
Peter
Peter
#1909
I don't have any images of mine since I stripped the covering off, but I originally did the entire fuselage in 4 pieces... first I covered the bottom of the fuse, and then covered each side including the vertical fin and half the top /back section of the fuselage, and finally a small piece of covering on top of the nose.
Here's an image of the real cub tail, maybe it will help clarify it.
#1910
If I understand you correctly, the way I see it, the covering is attached to the vertical fin on all the structure down to lower stringer on the fin... then the covering is attached to the fuselage edges and to the center spine that runs down the top / back of the fuselage up to the vertical fin... then when the covering is shrunk, it forms the faring.
The SIG kit has a piece of balsa that glues in from the last former to the rear of the fin, but not enough detail or description to get it right. The picture helps a lot. It tapers towards the tail and is flush, and not curved like the plans suggest. Now I see exactly how it needs to be done.
Acdii, I'm using coverall for the first time, it's time consuming but I like the finished product, very strong!
My old pilot ok kit has a balsa block which needs to be sanded to shape, I don't think I got the right shape, as I got sick of sanding.
#1912
The SIG kit has a piece of balsa that glues in from the last former to the rear of the fin, but not enough detail or description to get it right. The picture helps a lot. It tapers towards the tail and is flush, and not curved like the plans suggest. Now I see exactly how it needs to be done. Thanks
In other words, those filler pieces just continue at the same angle as the last former; and then follow the same angle as the upper out side corners... so when you put a straight edge on either the fuse side or upper outer corner, the lines continue through the filler pieces.
John M,
#1913
Oh, those pieces (right & left) just continues at the same angle as the last former, and tapers back to nothing, or as thin as you can get it with out sanding through it.
John M,
John M,
Thanks, that fits with what I was thinking they would be. Next week I will have that part done, and hopefully get some of the fuse covered.
#1914
My Feedback: (50)
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 [email protected] –
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3[SUP]rd [/SUP]time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 – Robert
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#138 rc airplane nut
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#151 [email protected]
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#212 Horsepoweraviation
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#15 Saito18 –
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#24 Edwin – Edwin
#25 Lavell – Lavell
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#67 talob – Mike
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#113 SCOTT42
#114 5blue
#115 crazystick
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#1915
My Feedback: (50)
Guys I know i have seen alot of talk on what to replace the o rings on the robart gear with. After some thought I will stay with O rings from my local fastenall store. about 2.50 for 15 of them. Had thought of a bungey cord, but if it brakes, you have nothing. If one o ring brakes you are still good. unless you slam it in, dont think you will brake all 4 o rings at one time. I do replace mine every year.
#1916
Believe it or not, I just realized you're building the 1/5 sig cub, lol ... I have their 1/4 scale cub which had a slightly different approach regarding those filler pieces... originally it used a couple pieces of 1/8 balsa sheeting to fill in after the last former along side the base of the vertical fin... I didn't think much of that idea so I replaced it with a balsa block and just sanded it to shape (same as you)... you end up sanding a lot of it away to get the shape, so I really don't think the added weight is an issue, and being solid balsa there's no chance of any warpage occurring... when I start to recover it, I'm going to try to cover the top side of the fuse and both sides of the vehicle fin with one piece of covering... that way there won't be a seam down the middle of the spine.
John M,
#1917
John M,
#1919
I was disappointed with the original o-rings that came with the gear... they broke down within a few months just sitting on the build table... I came home from work one day and noticed the cub was slumped to one side... the o-rings had cracked and broken right at the radius where the o-rings bend around the pegs... not sure if its due to ozone in the air, or possibly fuel / oil residue or a combination of the elements.
I didn't like the gear action the o-rings provided anyways, so I went looking for an alternative... tried fuel tubing, but it didn't have enough elasticity... rubber bands worked better, but they suffered with the same problem as the o-rings... one of our flying buddies at our field has a cub with the robart landing gear, and I asked him if he had any issues with the o-rings... he showed me what he uses, which was some 3/16" black woven nylon covered bungee cord he got from the hardware store... he made one bungee per side; made loops at the ends and tied them off with some bail wire... he rapped the bungees around the four pegs starting at one of the lower pegs and then over the peg above; then crossed over to the next lower peg and then up over the top peg ; crossed back over and then terminated the bungee back at the starting peg... it really provides a nice cushion effect with very little tendency to rebound or bounce... because each bungee is one continuous length, as the gear moves and the bungees stretch, they roll around the pegs like pulleys, which provides a fair amount of travel... the woven black nylon helps to keep the elements away from the elastic, and helps eliminate any chaffing as the bungees move around the pegs... its a bit of a fiddle getting the length of the chord right; just have to keep adjusting the length until you get the correct pre-load to support the weight of the aircraft... when its set correctly, it reminds me of the suspension action of some of these RC cars, where you drop them on the ground, and they kinda stick to the ground without bouncing... I like it better than the o-rings... once we got the length of the chord right, we made several sets... my inlaw is still on the first set, which has to be a couple of seasons... and since we have the fishing wire as a strain relief, if the bungees were to break it couldn't drop down on its belly... and as I stated earlier, if you land hard enough to break the 200lb test fishing wire, its really not a normal or even a hard landing; its a controlled crash landing,
John M,
John M,
#1921
CO
Hey guys,
I would like to join this brotherhood. I have always had a cub of some size in my hanger. My latest is a Balsa USA 1/4 scale made into a AE-1. There is a pilot and patient in a stretcher. The Cub ways 16 pounds 9 oz. Power is DlE 30 gas
#1924
Allright; here I'm going to show my ignorance, so please bear with me.
Part of my CMP Cub build is going to be an ArduPilot (in hopes it can keep me from lawn-darting it in the first 90 seconds); critical to making it work right is having it leveled correctly with respect to the nominal flight attitude of the craft.
Am I correct in assuming that the dorsal centerline at level flight should be a line between the horizontal stab and the motor shaft?
Or am I oversimplifying, and that centerline is offset due to the high-wing geometry of the plane?
Yes, I do realize that this will vary with how close to nominal COG I am with my final setup.
mnem
mnem
#1925
I would think with the GMP cub, the center line would be referenced through the horizontal stab at level flight with the correct CG; whether the center line will follow through the motor shalt is unknown due to possible motor down thrust / placement.... I checked my Sig plans and the engine shaft center line is well below the center line of the horizontal stab, so assume the center line is offset.
John M,
John M,
