Hostetler Lancair ES Build with retracts.
Reply
Old 07-30-2012, 03:29 PM
  #76
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hostetler Lancair ES Build with retracts.
I like to kit bash. I have the ES plans and am building around the larger wing. It is a fun project but the summer flying season and yard work season is upon us here.
I hope that the flaps offer some slowing down of the plane so that I can land it.
sebo is offline
Old 07-31-2012, 02:32 AM
  #77
chasrb
chasrb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with the flaps on this airframe, even though Hosteller says thay aren't needed. I know I'll be adding them on mine! How old are your plans? My plans came with both the ES and the IV build.
When I pickup my L-IV I got th fiberglass fuse, foam core wings and horz stab (obiechi wood), but since I have not tacked a foam core like this, I had a full wood kit cut so I can use the built up wing. I have begun to think about using "fliteskin" instead of balsa sheeting and then fiberglassing, the fliteskin looks like it'll do a nice job, plus if I decide to use the foam core it will work on those too.
I am looking to start this build hopefully soon. Need to get a 32x80 hollow core door to build this one ...
Thanks for posting your pics, they are helpful.
chasrb is offline
Old 07-31-2012, 05:22 PM
  #78
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My plans are so old that they are carved in stone....they must be among the first sold.....
I will keep on with the build but it is going to be slow.
Good luck with your build....why not start a thread on it so that other methods can be seen?
I am using a standard door for the build....it fits.
sebo is offline
Old 08-01-2012, 05:28 AM
  #79
chasrb
chasrb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I may just start a thread on my build. First need the 32x80 door to build on lol...
chasrb is offline
Old 08-02-2012, 07:54 AM
  #80
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe an 8 foot by 34 inch door would be easier to find. Try local hardware stores for damaged doors.....mine was only about 15 dollars and I have had it for 30 years. I guess they would cost more now.....better get one soon before the government outlaws them.
sebo is offline
Old 08-02-2012, 09:06 AM
  #81
chasrb
chasrb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, after a few hours of looking I found exactly the door I wanted to use! I found it at Stock Supply, its a 32"x80" exterior flush steel slab no drill door for $68.00. I did find one at HD but it was pre hung and in a sash for $116. I would have had to throw away the sash and to that was a big waste. I'll be picking the door up on Wed next week.
I am planning on using it as a large magnetic building board + I can use ceiling tile or other material on the other side should I want to build with pins and such.
This should end up pretty versatile
chasrb is offline
Old 08-02-2012, 07:04 PM
  #82
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds good!
sebo is offline
Old 08-04-2012, 11:36 PM
  #83
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another sleepless night in Jacksonville.
Since it is my first time with fowler flaps I sure was hesitant in cutting away the wing that looked so goodl
Measure and re-measure.......
Cut.......Came out ok; still have some shaping to do. Flap is just right on one end byt not thick enough on the other....Have to add some sheeting to the bottom to thicken it.
Here is what I did tonight.
This should be set number 3
ID:	1789228   Click image for larger version
ID:	1789229   Click image for larger version
ID:	1789230   Click image for larger version
sebo is offline
Old 08-04-2012, 11:39 PM
  #84
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are more pictures of tonights' progress.
This should be set number1
ID:	1789232   Click image for larger version
ID:	1789233   Click image for larger version
ID:	1789234   Click image for larger version
sebo is offline
Old 08-04-2012, 11:40 PM
  #85
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This should be set number 2
Yet More........sorry the pictures are out of sequence........too early on the morning to be doing this.
ID:	1789236   Click image for larger version
sebo is offline
Old 08-05-2012, 11:40 AM
  #86
chasrb
chasrb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good, Did your plans come with the detail to add flaps? Mine did not. We may want to trade photos of the plans we each have.
chasrb is offline
Old 08-05-2012, 07:13 PM
  #87
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No. Not on plans......I am just going along by instinct. I haven't drawn any plans for the flaps either.....just measure and cut.....
worked on it tonight too. nothing to show for this evening...just cut and shape. Using spackling to fill the gaps.
It is a fun project.
sebo is offline
Old 08-06-2012, 12:03 PM
  #88
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ultimate in Fowler Flaps.
sebo is offline
Old 08-21-2012, 10:51 PM
  #89
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It took a lot of thinking but I figured out how to put the flap mechanism into the flap.
It is probably easy for those of you who have done it before.
The following pictures will show my slow progression.
While I was doing this I was rebuilding 2 planes that I re-kitted this past month.
Have to keep them flying.
So, here goes.....
ID:	1794209   Click image for larger version
ID:	1794210   Click image for larger version
ID:	1794211   Click image for larger version
sebo is offline
Old 08-21-2012, 10:53 PM
  #90
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Continuing.........
The rectangular pieces are of 1/8 inch plywood to allow for a good solid hold.
I USED 30 MINUTE EPOXY TO SECURE THE PLYWOOD.
YES, THERE ARE GAPS BECAUSE I DIDN'T CUT THE PLYWOOD PERFECTLY.......THAT'S WHY THEY INVENTED SPACKLING COMPOUND.........'SPECIALLY FOR BUILDERS LIKE ME.
ID:	1794213   Click image for larger version
ID:	1794214   Click image for larger version
ID:	1794215   Click image for larger version
sebo is offline
Old 08-21-2012, 10:56 PM
  #91
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure there is room for the slide to move freely..
Next I will drill pilot holes for the 4 screws that hold the hinge in place.
The next one should be much quicker to install.
ID:	1794226   Click image for larger version
ID:	1794227   Click image for larger version
ID:	1794228   Click image for larger version
sebo is offline
Old 09-07-2012, 12:09 AM
  #92
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two hinges installed and one more to go......in the middle.
ID:	1799028   Click image for larger version
ID:	1799029   Click image for larger version
ID:	1799030   Click image for larger version
sebo is offline
Old 09-07-2012, 12:13 AM
  #93
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The reason that this thread is going so slow is because I am working on a Hostetler Cessna 150 at the same time as well as doing all the household chores and yard work...getting some flying in too....
sebo is offline
Old 09-09-2012, 05:16 PM
  #94
chasrb
chasrb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good Sebo. I have not had a chance to start my build yet. Where did you get the hinges?
chasrb is offline
Old 09-09-2012, 06:20 PM
  #95
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robart.
sebo is offline
Old 09-20-2012, 12:10 AM
  #96
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Planning to stasrt work on it again tomorrow.
sebo is offline
Old 09-22-2012, 05:03 AM
  #97
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Middle flap hinge completed.........If you go for 3 hinges, make sure that they are all in alignment so binding won't occur.
ID:	1803710   Click image for larger version
ID:	1803711   Click image for larger version
ID:	1803712   Click image for larger version
sebo is offline
Old 09-22-2012, 08:08 PM
  #98
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im watching! Ive got the urge to take one of these and either modify it into a lancair evolution, or a lancair Iv-P with a wren turboprop
invertmast is offline
Old 09-23-2012, 10:18 AM
  #99
sebo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you do, Youare welcome toadd your construction to this thread if you want.........I'd surely be interested in your mods and construction techniques..
sebo is offline
Old 09-23-2012, 04:40 PM
  #100
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will do.. right now i'm still in the debating stages. I've got so many other "large" models that my trailer has run out of room so convincing the wife to let me have another is kind of difficult.. specially since the trailer is full and one of the spare bedrooms has partially completed projects, kits, ARF's and a ton of plans and balsa wood sitting in it. lol
Reply
Display Modes
