USTFA?!?
USTFA?!?
Unidentified Soon To Fly Airplane - Got this plane from a friend that got it from someone else. No plans. He thought is might be a D.S. Prime Cut +20, but after comparing this plane vs any docs I could find, we both agree it's most likely not a Prime Cut. At least, it doesn't look like any Prime Cut I've come across. This pic is at the just-about-done-covering stage (I got it partially built and uncovered), but before I go any further, I'd like to find out what plane it is. Yes, I could easily just treat it like a scratch build, but I'm just really curious as to what plane it is, anything I should know, yada yada. If I can't find anything, then sure, I can figure out the CG and all that, but
If anyone knows what this plane is, please let me know. So far, what I know, approximately:
Wingspan: 91"
Fuse Length 54"
Foam wing and feathers
Seems like after all said and done it would be a good 50+cc maybe?
From the looks of the plane, the size is like a 90-120 size glow, but with 10" added to the wingtips. Plus the fuse is a little fatter, and it sits a little taller.
Any ideas anyone?
Wingspan: 91"
Fuse Length 54"
Any ideas anyone?
RE: USTFA?!?
Yep, thats more like it, at least from what Icould tell from the picture, wish they had different angles. Howd you find that? Any idea where the specs/plans would be found? I checked around, but plans I found are for a prime cut version that's not the same.
Thanks for the heads up!
