Do You Prefer Wood Props or Nylon Props?
NC
Hello all,
Do you prefer wood props or nylon props? I am just about finished building my Great Planes Super Sportster 60, and I would like to know the pros and cons of both wood and nylon props.
Andrew Guazzerotti
Andrew Guazzerotti
My Feedback: (-1)
RE: Do You Prefer Wood Props or Nylon Props?
ORIGINAL: AndrewLG
Hello all,
Andrew Guazzerotti
Hello all,
Andrew Guazzerotti
Some wood props work better then others too, I like the Xoar wood props but the smallest one I have in my prop box is 20 inches. People can debate this but I think the best prop on the market is the carbon fiber. My pockets aren't deep enough to be using them so I stick with the APCs, Graupners and once in a while MAS props. In cheap wood props you can always try the Zingers. Test one out and see for yourself.
NC
Okay, thanks for the reply. I hear from some people that if you have a prop strike with a wood prop, it will simply break. But if you have a prop strike with a nylon or composite prop, it can damage your engine. Is this true?
I prefer the MasterAirscrew. They are far more rugged and stand up well the prop strikes. While you might get a little bit more with wood and apc props they tend to shatter on impact.
skeeter
skeeter
Wood is a lot less likely to amputate a finger. I love 'em.
Remember that those little dings that a nylon prop survivies may well leave a dent, put it out of line or unbalance it. Maybe better to just break.
Tom
Tom
I have had this discussion before,
About 15 yrs ago I made the major mistake of putting my hand into a 10x6 MasterAirscrw on a OS .40 at full throttle(don't ask). I almost lost my index finger on my right hand. After a nice trip to the ER they sewed everything back together.
Now here is my reasoning and this usually starts an argument:
Wood Props break easier on prop strikes therefore should cause less trauma to a hand if you pull the same trick I did.
Wood props generally weigh less so less mass spinning equals less damage( in theory but it's still going to do damage).
Nylon props last longer and hold up better to incidental damage and prop strikes. Never had a prop strike hurt an engine unless the plane hit the ground vertical.
I now strictly use wood props period. My reasoning may be wrong but it is my fingers. I feel more comfortable flying with wood props, used to feel comfortable with nylon props.
I now mainly fly gas with props ranging from 20" to 32" and engines from 30cc to 157cc. I don't think having a wood prop is going to help me much in these cases but I do have alot more respect for the props now.
Later!!
Anthony
Later!!
Anthony
I use APC props all the time for glow and electric motors, for sport and competition. They are accurate from prop to prop and very close to being balanced.
You all do balance your props don't you?
Ed s
Ed s
I tend to use wood or apc. I use whatever I need to balance the model. Tail heavy? slap an apc on there. Nose heavy? Move the battery back a bit and use a wood prop. I'd rather use an apc prop than start tucking lead in fuselage.
The other factor I take into consideration is how much carving of the spinner it would require. APCs usually require more carving of the spinner.
My Feedback: (15)
ORIGINAL: corch
How much difference in weight is there between the APC props and the wood props that you use?
Kurt
My Feedback: (-1)
ORIGINAL: Bozarth
Kurt
ORIGINAL: corch
Kurt
ORIGINAL: Bozarth
Kurt
Kurt
APC 3.70 ounces
Xoar 1.75 ounces
Both reamed and balanced, never flown.
My Feedback: (404)
Having run most props over the last 40+ years, I now use APC on anything .25 to 1.60. As mentioned above, they are consistantly strong, balanced and give overall best performance IMHO. I used to fly Quikee 500 type racing back in the 80's, we were all using TF racing props on Webra 40 engines (pic of some leftovers). When APC came out with their pylon props, everyone changed over. We used to lean the engines up to about 19,000 and richen back down to 18,700rpm at takeoff. Of course of you're flying a nice slow WWI biplane, a nice scale wood prop sure looks good.
From the APC website:
[link=http://www.apcprop.com/v/Research/research.html]http://www.apcprop.com/v/Research/research.html[/link]
ORIGINAL: Gene Margiotti
Funny question - I haven't used a ''nylon'' prop in 35 years. Where do you buy ''nylon'' props?
Gene
Gene
My Feedback: (26)
"APC" props can be liken to a surgical blade ready to amputate your fingers. On the other hand wood props can inflict damage but not to the same extent. All propellars are dangerous and the spinning arc must be treated with safety being paramount. That said I favor wood over plastic material. Wood props can be rated as; good, better and best. Always remember you pay for what you get. I use nothing but "VESS" props, yes they are costly when compared to "Zinger" but their efficiency negets the price.
ORIGINAL: Bozarth
Favoring one prop over another based on what kind of damage they will do to your hand is like picking what type of saw blade you want on your table saw!
Kurt
Kurt
The better combo is wood laminated with carbon sock and epoxy. Not for the average Sunday flier maybe but if you want performance and save a few ounces in nose weight, that's a good way to it. I use wood electric props, XOAR has a good variety, and laminate them for all my gas engines. Much lighter than woodies intended for gas and far stiffer and stronger. Much lighter than straight carbon such as Mezjlik or Falcon. Thinner too
BTW- there is a very good reason apc trailing edges are so sharp. Sharp TE's improve efficiency and quiet down the air rushing together back there. Remember when a prop is noisy, it takes power from the engine to generate the noise
i use apc props most often due to low price and thrust, however i like the look of wood. The prop arc of wood is also much easier to see and looks cool in flight
I have used APC, Evolution, Zinger, and MAS props. For sport flying all the above work fine for me no matter what engine I put with them. Right now I mostly fly evolution props, they only make these up to a 16x6 I think. When I get into bigger props I go with either a MAS or a Zinger. I only have one wood zinger prop now and it is on a Top Flite 1.60 Staggerwing.
My prop main decision is usually based on what looks better with the plane on the ground (all my planes are scale but 1), then I fly it with that prop and make my final decision based on the flight and landing. Other than that I really have no preference over the type of prop.
Every prop strike I have had with wood has been with a broken prop.
TX
ORIGINAL: AndrewLG
