How to rid CA fumes stains
HELP ive stained the clear canopy by aplying yellow zap on the edges and there are the fumes stains at the edges . is there any way of permanently removing them . cleaning with kerosene it goes away but comes back later albeit a bit lighter shade, any ideas ... thanks
RE: How to rid CA fumes stains
Experiment with judicious application of acetone and cotton swabs. Kerosene won't dissolve CA but just masks the hazing effects of cured CA blemishes due to optical effects. Once it evaporates you see the blemishes again. Kinda like the 'olden days' trick' of wicking mineral oil in a windshield crack just prior to automobile sale. Once the car is washed the crack shows up again!
ORIGINAL: ARUP
... Kerosene won't dissolve CA but just masks the hazing effects of cured CA blemishes due to optical effects. Once it evaporates you see the blemishes again. Kinda like the 'olden days' trick' of wicking mineral oil in a windshield crack just prior to automobile sale. Once the car is washed the crack shows up again!
