aliphatic resin vs cyanoacrylic
Reply
Old 02-27-2012, 09:14 PM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: aliphatic resin vs cyanoacrylic
Quote:
ORIGINAL: ratshooter
I have tried all the mentioned glues myself. One that has not been mentioned is Weldbond. This is my "white glue" of choice. You use to be able to buy it a Lowes or Home Depot but not any more. I found it at Ace Hardware and bought a 16oz bottle.
Here is another glue that has not been mentioned.
Made by BERRY BROTHERS ( established1858 )
Ya ___Eighteen fifty eight ___no typing error.
In the days we were making models by the dozens.
The glue was bought in Imperial gallon cans.
I still have models that were all glued with this stuff.
The glue and the balsa still appear in excellent condition.
Just thought I would mention it.
The cup and salt and pepper shakers are to prove that it is not a small can. It really is one impeial gallon of glue. After posting I see that it is actually readable near the bottom of the can.
Zor
Zor is offline
Old 04-17-2012, 11:54 AM
lflf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use tite bond which I buy from Home Depot by the gallon. It works great. The only thing I don't use it for is attaching fins, stabilizers, etc., if they are not built into the fuselage with several layers of balsa holding them in. I use epoxy in that case. A tail surface only glued with tite bond will come loose from vibration because ia tite bond glue joint is very brittle. I also use a lot of masking tape to hold things together while drying, such as bent balsa in d-tube construction, etc. Once in a while I use CA for something, but not often. I don't like the smell of CA, and I think tite bond glues joints better as it doesn't have the tendency to soak in. It's also cheap.
lflf is offline
Reply
Display Modes
