Switch location for Uproar 40
I am in the final stages of framing my Uproar 40. I'll be installing a TT GP 42 engine and using a Flash 5x radio with the Hitec 555 receiver. I fly from a location at 4300 feet above sea level. The instructions don't cover where to install the on/off switch. Any suggestions? I want it out of the way of other components being installed.
Second, does anyone see any advantage in sheeting the ailerons and elevator? I noticed that the trailing edge of the wing is thicker than the leading edge of the ailerons. Won't that induce turbulents over the aileron? Induce Flutter? Trailing edges are squared off rather than rounded. Is the additional weight worth it?
How about the use of flapperons? It would be easy to set up. Other suggested modifications?
Thanks in advance.
Doug
Thanks in advance.
Doug
re: switch location
Doug,
I've built 3 uproars, and on all 3, I put the switch in the bottom
hatch cover. It will come off when you need to remove the hatch
but that isn't any problem. Also I just let the charge cord hang outside the same hatch, easy to test batteries and for charging.
as far as sheeting the control surfaces, I don't think its going to help anything, I would suggest that you make the rudder about a 1/2 inch wider for more control. just need to ad a 1/2" piece to the front of the rudder before you hinge it. Makes a big difference in control.
Good-Luck
Good-Luck
