P-40E Warhawk - Advice
I'm getting towards the end of my build and need some advice.
Any build suggestions or advice would be appreciated.
As we don't know what plane you intend to have the OS 20cc engine in we have difficultiy giving advise.
The only advise I can give you is that is unvise for a newbie to start with a big 20cc fourstroke.!!!
Get a smaller .40-.60 high winged trainer and power it with a .40 or -.60 two stroke.
My advice for a "newbie" would be to shelve that plane for a while, get a trainer, and learn to fly it before tangling with that P-40E. That combination would be a nice one for an experienced pilot.
Warbirds are not for beginners. That engine is definitely not for a beginner regardless of if it is pumped or not.
You can build it, but, again, shelve it until you learn to fly RC.
CGr.
Go to your local club and get some ideas there for a starter plane from the members.
Something like a nitro NeXstar is very popular for learning to fly on.
My experience says NONE of the above. I've never needed a pumped engine. I am given to understand that it was to accomodate the flyer that insisted on having his fuel tank directly over cg; usually too far to draw fuel properly.
Monokote is lighter, less messy, and easier to fix mistakes on.
Les
Monokote vs Glass is a personal preference. I prefer glass as it's much easier to do detail work on. If this is your first covering job, then Monokote will do the job nicely and takes less time and effort than glass.
Ed S
– Thanks for the info.
The tank is located right behind the firewall; I’d say 6 to 10 inches of line (depending how it’s routed). I don’t think the pump will help in my situation, so I’ve decided to go without it.
Ed - Your plane looks great. I think glassing is the way to go. Monkote seems easier but I’m hoping to get that look. If you have more pics please post them. Close ups of joints & spacing’s of ailerons, cowlings & the canopy help me get a better idea of how they are supposed to fit. Pics inside the housing and wheel wells would also be appreciated.
Scott
They don't care how or where you mount them or the fuel tank. I like mounting my tanks over the CG of the plane so there is no in flight changes, sometimes the CG is a bit back too far for non pumped engines. At this time your tank is close to the engine but what about the next plane you use it in. Pumpers are just easier.
UNTIL!! OS service will not sell you just a new diaphragm if you need a replacement and you will in time! They have you send in the complete carb so they can replace it for you. Now that $2.00 diaphragm is going to cost you close to $50.00!! Then down the road if you require a new pump OS will dive into your pockets again! It is a one piece unit and it can't be repaired with a new diaphragm, it requires a complete new pump! Just about $100.00.
On top of it all the price of a new OS engine has gone beyond stupid! I gave up buying any new OS engines, mater of fact I gave up buying any brand of glow engines. I use YS and OS and have a lot of them but if a new engine is needed from 1.20 on I would be going gas. Take a look at the DLE 20cc. Gassers are pumped already, cheap to buy and operate. Once tuned they require no more needle dinking, set and forget.
In this day and age glow engines make very little sense except that we are used to using them. In my case I have so many high dollar YS and OS engines and they aren't worth spit on the used engine market I would loose too much money if I sold them.
Just something to think about. I would rather have two DLE 20s then one OS 1.20.
Use oracover, much better than Monokote and forget about glassing such a small plane if you want good performance! And use a .90 two or four stroke instead of that 1.20 four stroke! It will be too heavy!
Keeping a light wing loading is what you should aim for not choosing as big engines as possible. 1.20 four and gas engines weigh too much for that plane!
If you want to go the gas engine route choose a bigger plane (2m)!
A glassed model that size really looks a ton better than a shiny monokote version. (Yes, even with the "flat" colors)
But, it will add weight. Same basic problem with the retracts though, right?
Learn how to do it lightly and you will add little to no weight with glass compared to mono. Use 1/2 or 3/4 oz cloth, thin your epoxy 50-50 with alcohol and brush it on using as little as possible, fill the weave with a 50-50 mix of red bondo spot putty and acetone, sand that back to the cloth leaving just enough to fill the weave and any spots where two layers of glass meet. Spray your primer and sand that back taking almost all of it off, then paint your colors. It is easy and tempting to use too much paint which will add weight, but if you do it right it won't. Be especially careful behind the cg.
This is an Acroduster Too biplane I am building. It's ready for primer. It will get one coat, most of it will be removed, then color coats. At this point the glass and spot putty weigh almost nothing, by the time I'm done painting it will weigh about the same as monokote.
I have the Top Flite ARF of that bird, and they use two different colors of Monokote, to achieve that.
Les
A four stroke glow will fit completely inside the P-40 cowl, will a gas engine? Lots of planes just look like crap with their cowl hacked to pieces and a big gas engine ruining the scale shape. The Acroduster above is going to have a big ugly gas engine sticking out the bottom. Don't write off glow just because the trend is towards gas. For a 60 size plane like a P-40 that will not be your everyday flier glow still makes lots of sense. Smaller, fits in cowls better, and sounds much better than gas. If it's a plane that might get 10-20 flights a year does the cost of gas really matter?
''You can achieve a happy medium on the finish by covering with an iron on product and then painting the model. I think Top Flite even covers this technique in the instructions.''
Les
I been doing this for decades and glssing sure ads more weight than a plastic film covering. With more weight I mean 100-200g or more and for a pylon racer pilot like me that is much!
You will not regret using Oracover if you try it!
I could be painted if you wet sand it first like I did on my Marutaka DC-3
http://www.airfieldmodels.com/inform...nish/index.htm
