Reload this Page >
First Time Kit Builder: Project GP Super Decathalon
Old 05-18-2014, 06:31 PM
  #51
Avistarpilot
Avistarpilot's Avatar
Epoxied the tail feathers and the under stabilizer support on tonight. Had a swamped weekend so didn't get as much done as I could but it's getting to the point of fitting in my radio equipment and engine and start routing pushrod & sleeve locations. Need to sand the wing to fuse filler blocks yet as well.
Old 05-18-2014, 06:44 PM
  #52
thailazer
thailazer's Avatar
Great looking project! Welcome to kit building and will be here lurking. Not building anything at the moment and enjoy seeing your photos.
Old 05-22-2014, 10:37 PM
  #53
Avistarpilot
Nothing extremely new to report, been a bit busy lately and my weekends are a going to be booked solid for the next few weeks. I literally have 2 weddings in a row to go to. How dare them cramp into my build time! Anyway, got a few goodies in the mail yesterday that should help the build along. Sounds like one of the said weddings will be down in the "big city" where there's a nice sized hobby shop that I like to go to. They usually have everything one would need. I'm essentially to the point of covering the model once I get the pushrod tubes installed and the wing servo located and cut out in the wing so I'm planning on getting all my covering while I'm there. I'm also in need of getting all my radio equipment so I can get my servos installed ugh....$$$$
Old 05-23-2014, 04:16 AM
  #54
daytonarc
I found that where the tri-stock meets the turtle deck sheathing got very thin when sanded to make it blend in well. Applied a fillet of epoxy and microballoons on the inside of the sheathing where it meets the tri-stock to reinforce.
Old 05-25-2014, 08:02 PM
  #55
Avistarpilot
Thanks for the tip, I'll be sure to double check the sheeting before I go to cover it while I'm giving everything a good final sanding.
Right not I'm fabbing up my throttle and fuel tube routing. At the same time while the engine is installed I'm trying to cut the cowling around the engine. Is there a trick to this or is it just a matter of trail fitting the cowl little by little and trimming the cowl each time around the engine head?
Old 05-26-2014, 08:31 AM
  #56
daytonarc
Are you mounting the engine sideways? I mounted mine inverted with a remote glow connection to avoid cutting the side of the cowl.
Old 05-26-2014, 03:11 PM
  #57
Avistarpilot
Yep it's out the RH side. I've got a hole drilled where the center rocker arm hold down is located...or should be. Guess I'll just work my way around slowly to contour the head and clear everything.
Old 05-28-2014, 06:11 AM
  #58
daytonarc
Put a refedrence mark on the fuselage and the cowl. Remove the cowl and tape a clear report cover to the side of the fuselage and transfer the reference mark to the clear plastic. Mark the cut out on the clear plastis then cut it out and make sure the fit is good. Tape the clear plastic to the cowl, ligning up reference marks then mark cowl cut out.
Old 05-28-2014, 08:16 AM
  #59
Avistarpilot
I'll give that method a go. I tried using a cardboard template but cardboard seemed a bit soft and would rip/tear in places where I didn't want it to. I'll scrounge around the house and see if I can find a piece of clear plastic to use for a template.
Old 05-29-2014, 01:18 PM
  #60
Avistarpilot
Holy cow! Using the clear plastic sheet method took all the guesswork out of cutting into the cowl. I was a bit apprehensive about cutting into it since you essentially only have one shot. I think I'm still going to trim another 1/16th or so around the engine just to be safe but overall I'm extremely happy with how it turned out...other than the fact the rocker cover and hsn have to be removed to install it but I'm hoping once it's on it won't be coming off unless I have a problem. Now I can yank the engine out and get started on break in.
Here are a few pics:
Old 05-29-2014, 03:22 PM
  #61
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
For future reference manila folders make a great material for doing templates for cutting cowls like you did here. I always make sure I keep some around in my shop for just such purposes.
Ken
Old 05-30-2014, 12:18 PM
  #62
daytonarc
Looking good!
Ken
I prefer the clear report cover so you can put it over the engine and mark where cuts need to be by seeing the engine and needle valve.
Old 05-30-2014, 12:48 PM
  #63
LesUyeda
Banned
I don't know what the rest of it looks like, but, I would block off the left side air inlet, so that only the one over the engine is open, then cut a large hole in the bottom of the cowling (where it won't usually show) for air exit. You would like two to three times the area for goesouta as you have goesinta. The idea is that you don't want to "pack" air, where the air does not flow, so the outlet greater than inlet will create a vacuum in the cowling, and suck air in. This method has been used in scale, where the only inlet was hidden behind the spinner backplate.
Les
Old 05-30-2014, 01:00 PM
  #64
daytonarc
Avistar, with the engine mounted sideways you may need some weight in the left wing to ballance laterally. If I were you I would get my gear, engine, electronics, etc where I want them and check latteral ballance before covering. That way if needed a small amount of weight could be added inside the tip of the left wing where the smallest amount of weight could correct any latteral ballance issue and it won't be seen when covered.
Old 05-30-2014, 01:09 PM
  #65
Avistarpilot
Yeah I figured I'd drill an exit hole somewhere in the bottom of the cowl. Has anyone ever used seaplane grommets? We used them when we recovered an Ag-Cat when I was still working as an aircraft mech at the airport. Come in various sizes and have a hood over the hole on the le and acts almost like a venturi effect to evacuate any moisture that would happen to get between the fabric. Probably not needed in small scale, any hole on the lower cowl skin should act like a venturi while in flight. Or could cut a "door" in the lwr cowl and bend it to open to the aft, should act like a cowl vent.
On a different note I'm planning on picking up my covering this weekend. Any rough estimates on how much I'll need? Planning on a yellow/white scheme. Planning on ultracote if they have it, which comes in 6.5ft rolls.
Old 05-31-2014, 04:42 AM
  #66
daytonarc
Drilling a hole for exit air will not provide a large enough opening. Ideally you want 3 times as much exit air as entering air. You should get by with 2 rolls of the main color and 1 roll of trim if you plan your cuts well.
Old 05-31-2014, 06:31 AM
  #67
LesUyeda
Banned
"Planning on ultracote if they have it, which comes in 6.5ft rolls."
Doesn't matter how much you get, you WILL end up 1 foot short:-)))))))))))))) Guess how I know.
Les
Old 05-31-2014, 07:29 AM
  #68
PatrickCurry
My Feedback: (20)
PatrickCurry's Avatar
The cowl looks awesome. I was going to suggest maybe using a molding transfer gauge to help: http://greeneprojects.files.wordpres...2-13-23-23.jpg Your method turned out great though.
Old 05-31-2014, 07:20 PM
  #69
dabigboy
Looking good so far...I will follow this one, as I have been wanting to build a Citabria or Decathlon. I am pretty much torn between the GP Decathlon (if I can find one) and the Sig Citabria.
I have about 10 wonderful fun hours of Decathlon time, so I would probably reduce dihedral and build the Sig Citabria (if I go that route) as a Decathlon, in my old flight school's paint scheme.
Matt
Old 06-01-2014, 08:17 AM
  #70
Avistarpilot
I'll be sure to check lateral cg before I cover. Thanks for the tip. Got my covering this weekend and picked up some lusterkote to paint the cowl. Still have some work to but getting excited to put the finishing touches on this thing.
Old 06-04-2014, 03:50 PM
  #71
FlyingPilgrim
My Feedback: (26)
FlyingPilgrim's Avatar
I had one years ago with a Saito .72 mounted inverted. Plenty of power, maybe too much torque on take off. I moved the location of the landing gear based on something I read about helping on paved strips (can't recall forward or rear), I also tried to make washout 2 degrees, but was only able to get one degree due to rigidity of wing after assembled. I loved the way the plane flew and landed, but take-offs were a PITA!! Thing would ground loop bad, and I could never quite master take-offs to look decent. I sold it due to ground handling problems. If you've ever flown a Cub, I would say it was worse on ground handling. Be ready to abort your take-offs as soon as it goes squirelly. I would also suggest reinforcing the balsa wing-tips at the rear where the ailerons are. One little bump will break the trailing edge balsa tips next to the ailerons. Put a piece of aircraft ply in there to give it some strength. Good luck!
Old 06-11-2014, 08:20 AM
  #72
Avistarpilot
Sorry for the stagnant thread boys, had a little mishap with my avistar last week and stalled on take off and cartwheeled into the weeds so I've been in the shop but not working on the Decathlon. Thinking the culprit was too tall of grass on the runway, wrong prop, grass buildup on said prop, and too small of wheels. No major damage but it knocked the firewall loose and pulled the front left fuse side out of position.
While it's down I'm stiffening up the tail feathers and converting it to a tail dragger with larger 3 1/2" wheels.
