Goldberg Tiger Club
#576
RE: Goldberg Tiger Club
psmith36, I'm building a Tiger 2 from plans right now to mount the Evo 10cc gas engine on. I'm thinking it will be a good match. Making a few changes to the airplane though, mostly stuff I've learned about from reading this thread. Hope to have it finished in 2-3 weeks. RS
#577
My Feedback: (540)
ORIGINAL: jkr_1100
It would probably be great. I don't have any experience with this engine. If it runs well I bet the Tiger 2 would fly very well with it.
I have a lead on a Tiger 120. I am trying to get the airframe, I think I have an engine that will go on it and fly it well.
I have a turbine that would make it fly like a missile !
#578
Thought I'd list my Tiger 2 mods as I think I missed a couple earlier:
-Reduced dehederal.
-Dual aileron servos. (Had severe flutter problem with the long aileron torque arms.)
-Built-up wing tips. (Kit came sans balsa blocks)
-Wing tip skids. (Helps out on those "not-so-expert" flights!)
-Swept back main gear. (Solves the design problem with the gear being too far forward and the plane sits on its tail.)
-Detachable Mooney style tail.
-Nyrod Tail skid. (I like aggressive take offs and landings.)
Had a good day flying yesterday and getting used to the Tiger again after being away from it for a while. Forgot how slow this thing can fly on the approach.
-Reduced dehederal.
#580
ORIGINAL: jkr_1100
tell us about your spotter. He seems to be ever present while flying.
#581
Tovio nice looking dog, last one I saw here just ate someons plans. What beautiful weather your having, what is it summer there,? and it's so green, pretty country as I see it. Must be nice being able to fly, wish I could.
Later, Leroy
Later, Leroy
#582
My Feedback: (15)
ORIGINAL: thailazer
That's Stormy the airport security dog. He likes to have his nose in everything I do, but I usually put him in the house when I fly. When I am in the shop, he seems to have an opinion on anything I am doing and luckily hasn't developed an appetite for balsa, although he will chew on anything else. He is only 5 months old, rescued from the mountains, but is already a devoted little chunk. The Tiger is his favorite airplane.
ORIGINAL: jkr_1100
He is a very noble looking dog. He seems to be trying to tell us something.
#583
My Feedback: (86)
I mentioned some months ago that my brother and I were planning to build a couple of Tigers that are specifically designed for 30cc gas engines particularly the Syssa 180. Well, after weeks of calcutations and cussing and discussing, we settled on a 92inch design. We've got the planes framed up and are ready to start installing equipment. They should be ready for first flights sometime around the end of February. Any one interested in pictures?
#586
My Feedback: (15)
ORIGINAL: Red Raider
positively, the more the better. this is awesome. that would make my day
I am trying to get my hands on a Tiger 120 currently.
#587
ORIGINAL: Leroy Gardner
Later, Leroy
Later, Leroy
Also... Would love to see some photos of big Tigers. Super Tigers? Jumbo Tigers? Monster Tigers? Whatever it is it sounds like a great idea for a gasser. Leroy's ship is looking beautiful with that DLE up front.
#588
"Thank you Toivo", for some of you who don't venture from here you should at least see it, I don't expect someone to comment on it thow and thats ok. A larger version of this bird would be intresting and I'm sure others would build it.
Mine is in the finishing stages and covering has been ordered along with wheel pants, wing tips is whats left to build. You will see it when it's finished here too.
For those intrested in cowling see it here: www.rcuniverse.com/forum/m_11366450/tm.htm The build: www.rcuniverse.com/forum/m_11326847/tm.htm
#591
My Feedback: (86)
I'll post some others of the frame work this evening. It's going together pretty well, but as I stated in an earlier post, the plans and the parts don't match. It isn't a problem except that we've had to redraw and re-cut some of the pieces. Also, there's no pre-cut aileron blanks the size we needed so we had to laminate pieces together and sand off everything that doesn't look like an aileron. Lot of work, and takes a lot of time to get them symmetrical. BUT, should start installing equipment tonight and order the carbon control rods later this evening.
#592
Sorry to hear they forgot to include the aileron blanks. Sounds like a good but dusty solution! Have fun.
#593
Here's some pictures before we actually started framing it up.
#594
My Feedback: (86)
I don't think the tabs aren't shown on the plans. They are a good tool for the kits and quite frankly would be good to use on the scratch build as well. But, we compensated for that by measuring and pinning a piece of straight balsa to the building board under the trailing end of the ribs. Then, with the spars in place, we weighted down the ribs so that they were all in contact with this piece. Holding them down, we glued the spars in place. You have to be careful to make sure the ends of the ribs line up correctly. Doing it this way, ours did. The other key to this step is make sure that the piece you're using for the trailing edge is straight. You cannot bend it and glue into position and expect it to stay straight. It will translate any curvature directly to the ribs.
#595
My Feedback: (86)
They're not terribly off. Mostly it's the size of the tabs and slots. The biggest issue was that with each adjustment that Goldberg did from the Tiger 2 up to the Tiger 120, they used the same ratios. So using their numbers, you come up with either a 96 or 98 inch wingspan (I don't remember exactly). Using my calculations and the data for a 30cc size engine, we needed to keep it down to 92 inches. That's an increase of 132% over the 60 size plans. When John took the numbers and plans to the copy shop, he also took a tape measure. Good thinking on his part!! At 132% the wingspan was off. He wound up at 127% on one sheet, and something slightly different on the other. He stayed there until they got it right. Wound up costing almost $70!! After that, it's really been pretty easy to make the adjustments. I'm pretty sure we kept an uncut copy of the plans. Would you like for me to see how much it would cost to another set made?
#596
My Feedback: (86)
Here's a copy of the 2 orders that I made to National Balsa for the wood. This is enough for 2 airplanes. Believe it or not, if you're using a scroll saw to cut out the pieces like I did, it's just as easy to cut 2 as it is to cut 1. Get with a buddy and share the work and the wood. It's great having my brother work with me. We have a blast and working together you have someone else to blame stuff on!!!
Total cost including shipping was $248.32.
Hope this helps.
2 of : 1/2x2x36 balsa wood
5 of : 1/2X2X48 TRAILING EDGE
2 of : 3/32x4x48 balsa wood
3 of : 3/4x1x48 balsa wood
1 of : 3/8 x 12 x 12 birch ply
8 of : 1/2 x 1/2 x 48 basswood stick
6 of : 1/2x3x24 balsa wood
6 of : 1/2x3x36 balsa wood
8 of : 1/8 x 12 x 48 lite ply
4 of : 2 x 2 x 18 balsa block (you only need 2 of these if you can cut them in half on a 45 degree angle)
8 of : 3/32x2x48 balsa wood
12 of : 3/32x3/8x48 balsa wood
12 of : 3/32x3x24 balsa wood
8 of : 3/32x4x48 balsa wood
5 of : 3/4x3/4x48 balsa wood
Hope this helps.
#597
MI
well for the most part, my boys plane is finished. I haven't installed the canopy as of yet becouse I need one for mine so I may need his as a mold. Still looking to find one for sale. anyway here are a couple of pics of it. He's been facinated with WWII airplanes of late so we decided on a bit of a flying tiger type design so here it is.
#598
ORIGINAL: grumman-cats
#599
Spent the late afternoon enjoying stellar blue sky and no wind by wringing out the Tiger. Snap rolls and wild yaw throws were the name of the game today. Flying was great but the landings seemed to kick up stones so a few minor holes to repair. The next Tiger will have a fully sheeted horizontal stab, fuse bottom, and wings. Stormy liked the wild snap rolls but at the end of the day he had seen enough.
#600
My Feedback: (15)
I would like to get two sets of these plans from you. Would you look into it to see how much it will cost?
