My 1st Kit Progress
Reply
Old 10-07-2012, 10:01 AM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My 1st Kit Progress
Here's a few pics of the Sig Kadet Mark II I've been working on... Pretty fun, I've been kinda nursing the build so I have something to work on...LOL
ID:	1808940   Click image for larger version
ID:	1808941   Click image for larger version
ID:	1808942   Click image for larger version
ID:	1808943   Click image for larger version
BillinIndiana is offline
Old 10-07-2012, 11:18 AM
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My 1st Kit Progress
Bill at the rate you are going you will need another kit before winter is over.
OldScaleGuy is offline
Old 10-07-2012, 11:26 AM
outdoorhunting
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good !! What did you do to reinforce the wing halves? By looking, it seems to be epoxy? You could make the joint a LOT stronger by using a light-wieght fiberglass cloth with either epoxy or my favorite ( cause it's easier to sand) fiberglass resin. You more than likey won't need it on the "trainer" type plane.but when you get into sport flying you'll be glad you have the extra stength. Goog luck !!
outdoorhunting is offline
Old 10-07-2012, 11:36 AM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ODH look closer at the pics. Looks like a two inch strip of glass right down the middle. Pic #2 and #3 shows it best. Use the enlargement button, it's very visible.
acerc is offline
Old 10-07-2012, 11:55 AM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep the reinforced cloth is on there.. I haven't really sanded it down yet.. What's in the pics has just been squeegee'd off..
Old 10-07-2012, 12:26 PM
huck1199
huck1199's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may want to consider making the bottom front panel removeable for access to the fuel tank.  I did so with mine - a couple of screw in front and the landing gear bolts hold down the rear.
huck1199 is offline
Old 10-07-2012, 01:00 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: huck1199
Yeah I cut the Lite-Ply on the bottom front of the fuselage about an 1/2" short of reaching the 1st cabin former. I then glued a small straight scrap piece to the removable piece to slide under the permanent rear portion of the Lite-Ply. I also set up some triangular hardwood blocks to put two screws in the front corners of the fuse, right behind the firewall.
Old 10-07-2012, 01:18 PM
huck1199
huck1199's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didn't reduce the dihedral on mine - wish I had.  Yours look like full dihedral.  I hear they are still great trainers with leas dihedral - more responsive.
huck1199 is offline
Old 10-07-2012, 02:32 PM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If there is no slipping or skidding the dihedral does not make much difference.
It does give better roll stability in turbulent air.
It obviously does not change the pitch and yaw characteristics.
Zor
Edited to change I to It at the beginning of the second line.
End
Zor is offline
Old 10-07-2012, 02:43 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Being I'm New to flying I just went with what the plan showed.. I've read about others taking some or even all the Dihedral out, but I figured I'd play it save till I learn.
What I did do was trace all parts to the wings ( tip, ribs and tip gauges etc.) .. This way I can build a flatter wing if I want instead of build a whole different plane... Building is Fun though so I'll more than likely build another anyways, but I have options with the way I've tried to set myself up.
Old 10-07-2012, 03:04 PM
outdoorhunting
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, yeah. Sorry, I didn't look close enough !! Nevermind !!!
Old 10-07-2012, 03:17 PM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BillinIndiana
You have done the proper thing "BillinIndiana".
I also have read about the reduction or removal of the dihedral angle (obviously).
I think it is a matter of "faith" more than "reality".
Some fliers are very religious .
They will repeat what they read without experiencing it themselves or they will see it because it is what they expect even though it is not happening.
Zor
Zor is offline
Old 10-07-2012, 04:50 PM
5skyhawk172
5skyhawk172's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good job Bill. I built one back in 1980 first  version still have it .Back in 2002 while at the NATS in Muncie I met the guy who designed the plane.  His name was Claude McCulluch. I had the Kadet wing with me and he signed it for me.  His AMA number was 10.  Will never forget it. Keith
5skyhawk172 is offline
Old 10-07-2012, 04:58 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 5skyhawk172
Good job Bill. I built one back in 1980 first version still have it .Back in 2002 while at theNATS in Muncie I met the guy who designed the plane. His name was Claude McCulluch. I had the Kadet wing with me and he signed it for me. His AMA number was 10. Will never forget it. Keith
Thanks Keith, I should have it ready to fly by spring..LOL..Ppretty cool you got your wing signed.. Did you go out to the field today? looked pretty breezy out there
Old 10-07-2012, 05:04 PM
5skyhawk172
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea it was a little too windy for me.  Stayed home and watched the Colts kick the packers you know what!
Old 10-07-2012, 05:05 PM
thepamster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Bill. You build fast. Slow down and take it all in.
Keep up the good work.
thepamster is offline
Old 10-07-2012, 05:11 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I actually thought I was building pretty slow..? I even used quite a bit of Tite Bond, just so I would have to wait till it dried before I could continue..LOL
Old 10-07-2012, 05:25 PM
thepamster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sig kits build relatively easy and can go fast. I built a Sig Kadet Jr. for my first multi-channel trainer back in the 80's. An excellent first r/c build.
Not flying it 'till spring? What, you goin' on vacation. LOL.
Old 10-07-2012, 07:54 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hell, it'll take me till spring to pick out a color scheme..!
Old 10-07-2012, 10:12 PM
AlmondRancher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill,
The plane looks good. What engine have you decided to use?
- Allan B
AlmondRancher is offline
Old 10-08-2012, 12:28 AM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Jr was my first plane as well. Built mine back in 1986 with an OS 25FP for power. Unfortunately, the plane was destroyed before it ever got covered due to moving. I'm presently building another from the kit's plans but, this time around, it's been changed. I've added 6" to the wingspan, three bay wide 25% chord ailerons and removed the dihedral to increase the lift as this one is going to be set up so I can fly with floats. Due to the added drag and weight, I may be going up to an OS 35 or so and either a larger or a three blade prop, jury's still out on that one
Hydro Junkie is offline
Old 10-08-2012, 07:30 AM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Allan.B
Bill,
- Allan B
I have the Thunder Tiger GP 42
I'm having a tough time picking my covering colors.. I know .. I know... It's just a Trainer and might have a short life-span, but I want it to look original and the best I can for however long it last
Old 10-08-2012, 07:38 AM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really need to watch some more videos on covering.. I've watch one from Hobby Lobby where the guy does a Red and White wing.. Thing is I bought a combo iron/heat gun and I'm not sure what to use the heat gun on? I see the Ultracote has a tack temp of 220 and a shrink temp of 300.. What do I do with the heat gun? Is it for open bay of the wings, if the model has them like the MK II does?
Old 10-08-2012, 08:47 AM
mikegordon10
mikegordon10's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use Ultra and I put it on with a trim iron and then use the heat gun to shrink it up while using a soft rag to put a little pressure on the sheeted areas to bond the covering to the wood. I have 2 covering irons, a Top Flight and a Century 21 but I use them very, very little.
You do have to be careful with the heat gun around the perimeter or the Ultra will shrink up pulling the edge where you don't want.
I use a piece of card stock to shield the covering around the perimeter to stop this.
Works great.
Your doing a bang up job for a newbie, welcome to the best part of RC.
mikegordon10 is offline
Old 10-08-2012, 09:06 AM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Hydro Junkie
Hydro Junkie.
Do you have any idea how much more lift you will have due to removing the dihedral ?
Zor
Zor is offline
Reply
Display Modes
