Glass and Foam Spacewalker II
Reply
Old 10-19-2012, 07:03 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Glass and Foam Spacewalker II
I have not done a kit build thread in quite a while, so I thought I would post this build here. Not going to be a detailed build thread, just a few highlights, & some of the stuff that is peculiar to this kit. here's my progress so far.
Got this kit in a recent trade, and thought it would be a rather nice electric conversion. It looks to be a splash of the SIG Spacewalker II. In fact, I picked up a few scale details, and landing gear wire from SIG. It has a glass fuse, cowl, and wingtips, with foam foam wing cores. Wingspan is 84" & expected final weight will be around 11 lbs.
Been working on for a couple of weeks and here's a few pics of my progress so far. The tail feathers are scratched fron 3/8" x 1/2" balsa, with some 3/8" sheet. Cores are sheeted with 3/32" sheet and strips. Plan to power it with a Turnigy 6354-250kv on a 6s 5000mah pack.
ID:	1812873   Click image for larger version
ID:	1812874   Click image for larger version
ID:	1812875   Click image for larger version
ID:	1812876   Click image for larger version
TLH101 is offline
Old 10-19-2012, 07:05 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Glass and Foam Spacewalker II
Some more pics
ID:	1812878   Click image for larger version
ID:	1812879   Click image for larger version
ID:	1812880   Click image for larger version
ID:	1812881   Click image for larger version
TLH101 is offline
Old 10-19-2012, 07:06 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A few more bits and pieces done so far. I have finished sheeting both wing halves now. I made a tool to grove the tip of the wing so the fiberglass cap will fit flush.
ID:	1812884   Click image for larger version
ID:	1812885   Click image for larger version
TLH101 is offline
Old 10-19-2012, 07:08 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have also started on the motor and battery mount. I will be able to access the battery thru the front cockpit. Lots of room to get in and secure or remove battery. I built a tray that will be held in with a thumbscrew, and the battery will be velcroed to the plate. Saw this in a thread on RCG. Works slick in this set-up.
ID:	1812887   Click image for larger version
ID:	1812888   Click image for larger version
ID:	1812889   Click image for larger version
ID:	1812890   Click image for larger version
ID:	1812892   Click image for larger version
ID:	1812893   Click image for larger version
TLH101 is offline
Old 10-19-2012, 10:25 PM
CK1
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Terry , Nice work.
Who produced the kit ?
CK1 is offline
Old 10-20-2012, 03:54 AM
VIRGINIA MODEL BUILDERS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day Terry,
Who produced the fiberglass fuselage?
VIRGINIA MODEL BUILDERS is offline
Old 10-20-2012, 04:13 AM
soarrich
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like you little sanding tool, very slick.
soarrich is offline
Old 10-20-2012, 05:26 AM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am not positive who produced the kit, as I trded for it, but I think, it may be from Qualls Aviation; http://www.ucrcs.com/qualls_aviation.htm
There is 1/4 scale Spacewalker listed on their site that seems to match this kit. The glasswork seems real nice so far. The fuse halve have a very "tight" seam, that will require very little work. Not having put any primer on yet, I can't tell about pinholes.
TLH101 is offline
Old 10-20-2012, 09:05 AM
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What glue have you used for the bracing formers inside the fuse? I have had some problems getting different glues to stick well. I did wash the fuse inside and out but sometimes the glue still didn't want to stick to the glass.
I agree, this is a very nice looking kit.
Gray Beard is offline
Old 10-20-2012, 12:48 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I usually just use 30 min epoxy that is thickened with micro balloons or flocking. I sand the joint area and clean it with acetone or alcohol before glueing.
TLH101 is offline
Old 10-20-2012, 04:14 PM
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I haven't tried using micro balloons mixed in it yet. I'll give it a shot.
Old 10-20-2012, 06:42 PM
soarrich
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Gray Beard
The flocking is a better chose of the two.
soarrich is offline
Old 10-21-2012, 08:35 AM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, mount is glued to firewall and pinned with 1/8" dowels. I then made a cowl mount bulkhead, and the glued that into the cowl at the correct location. Three screw will hold the cowl on, and will accessed thru air intake openings on the cowl.
ID:	1813329   Click image for larger version
ID:	1813330   Click image for larger version
ID:	1813331   Click image for larger version
ID:	1813332   Click image for larger version
ID:	1813334   Click image for larger version
TLH101 is offline
Old 10-26-2012, 05:13 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cut the ailerons from the wing and hinged them. They, and the wing cutout were faced with 1/4" and 1/8" balsa. I'm using large nylon hinges.
ID:	1815105   Click image for larger version
ID:	1815106   Click image for larger version
ID:	1815107   Click image for larger version
ID:	1815108   Click image for larger version
ID:	1815110   Click image for larger version
TLH101 is offline
Old 10-26-2012, 05:52 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Landing gear is all soldered up too.
TLH101 is offline
Old 11-20-2012, 05:18 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still working on it, but mostly boring stuff, so I have not been posting. I am now starting to cover it, so I'll have more pics soon. Maybe this weekend. BTW, Coverite fabric goes right over fiberglass with no problem.
TLH101 is offline
Old 11-24-2012, 08:24 AM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now have the cowl ready for paint. Lots of pinholes, lots........ Prime fill pinholes, sand, prime, fill pinholes, sand, prime, fill pinholes, sand,etc. Did mention a lot of pinholes. Since I suspect the fuse had the same pinhole issue, I decided that I would see if, as I had read, you could cover glass with Coverite. The answer is, yes, with quite good results. Should finish covering the wing this weekend, and then on to finish work.
I think I will paint with a scheme I would use, if I had a full scale SpaceWalker. I really like the red/yellow scheme, but there are just too many done that way. I am going to use the same pattern, but I think I will use a cream base color, and a medium blue for trim. Maybe a green or orange pinstripe between colors. I am also going to checkerboard the bottom, I think.
ID:	1823326   Click image for larger version
ID:	1823327   Click image for larger version
ID:	1823328   Click image for larger version
TLH101 is offline
Old 11-26-2012, 07:22 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished covering the rest of the plane this weekend.
ID:	1823901   Click image for larger version
ID:	1823902   Click image for larger version
ID:	1823903   Click image for larger version
TLH101 is offline
Old 11-26-2012, 07:26 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided to do a bit of detail, so I am putting some rib stitching on. It's not exact scale, but the "look" is there. I put some chart tape on coverite , then cut 3/16 wide strip and iron it down on the rib. Next I cut 3/8" strips and ironed it over the first strip. It's not "pinked", but scale pinking would barely show anyhow.
ID:	1823917   Click image for larger version
ID:	1823918   Click image for larger version
ID:	1823919   Click image for larger version
TLH101 is offline
Old 01-26-2013, 01:45 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, it's been a while since I updated, but the weather has been so cold and windy, that I have not been able to paint. I have finally in the last couple of weeks, managed to get all the base color, Krylon Ivory, on the airframe. I spent a couple of evenings this week laying out the trim scheme on the wing and masking. I was able to paint the wing today with Rustolium Real Orange, and I am pretty happy with the way it turned out. I ponied up the bucks for some 1/8" 3-M Fineline tape to to mask the pattern. I used it for the straight lines, and cut circles of Frisket Paper for tight bends. The fine line tape leave a beautiful crisp line, and seal really well, as can be seen in the close-up of the paint on the rib-stitching.
ID:	1844584   Click image for larger version
ID:	1844585   Click image for larger version
ID:	1844586   Click image for larger version
ID:	1844587   Click image for larger version
TLH101 is offline
Old 01-26-2013, 03:54 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little contrasting stripe.
ID:	1844654   Click image for larger version
TLH101 is offline
Old 01-29-2013, 03:57 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Getting closer.
ID:	1845728   Click image for larger version
ID:	1845729   Click image for larger version
ID:	1845730   Click image for larger version
ID:	1845731   Click image for larger version
TLH101 is offline
Old 01-29-2013, 05:01 PM
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My kingdom to be able to paint worth a darn!!!!!!! What I did notice was when you covered the fuse I spotted that they molded in the stringers. Very high class!! I like the idea of going electric for a lot of reasons but being able to use the paint of your choice is one of the big ones!!!
Old 01-30-2013, 04:12 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually, anyone can paint. It's the masking that is a bi#ch. If you use the right masking materials (fineline tape, masking paper etc) and take you time (I usually don't), your paint job will turn out excellant. I spent about 4+ hours masking the fuse, and making sure that all areas not to be painted were covered, and vice-versa. Then making sure all the tape was down tight, so there was no over or under spray. Then you got to leave it alone until the paint won't fingerprint, before unmasking. That's the hardest part.
TLH101 is offline
Old 02-03-2013, 05:28 PM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, after another week of masking and painting, I think I have all the major paint work done. Just some detailing and touch-up left to go.
ID:	1847693   Click image for larger version
ID:	1847694   Click image for larger version
ID:	1847695   Click image for larger version
ID:	1847696   Click image for larger version
TLH101 is offline
Reply
Display Modes
