Reload this Page >
ZENOAH CARB LINK CONNECTION
Old 10-25-2012, 07:53 AM
BOLT
Default ZENOAH CARB LINK CONNECTION
First, I'm new to gas engines. I just got a brand new Zenoah G38 and noticed that the movement in the carb linkage is sideways. The problem is that servo connections are the push - pull type. How can you connect the carb to the servo when their movements are perpedicular to each other? I'm building a Dynaflyte Super Decathlon and this issue stop me on my tracks. Any suggestions?
Old 10-25-2012, 08:45 AM
Lowvoltage
Default RE: ZENOAH CARB LINK CONNECTION
You might try this:
http://www.bennettbuilt.com/shop/Eng...nkage_Kit.html
Old 10-25-2012, 08:58 AM
redbiscuits
redbiscuits's Avatar
Your going to need to do something like this. Well, as soon as it will upload a photo
Old 10-25-2012, 09:04 AM
Jacque
My Feedback: (22)
Go to Horion hobbies web site and buy an easy link carb adapter problems solved
Jacque Waco Brotherhood # 27
Old 10-25-2012, 09:32 AM
Gray Beard
My Feedback: (-1)
I have never seen the easy link but if there is an easy way to set up carb linkage then it's worth the price. Linkage is always a problem from plane to plane and each engine is different. With my Zenoha's and other brands I use a lot of different things like U-control bell cranks and make up my own system. My Brison came with a very nice system already made up and installed using hime joints and a type of turn buckle so you get a straight pull. That I can post photos of. Making up linkage is a brain twister but if you use wire you can get very creative.
Old 10-25-2012, 09:38 AM
BOLT
Lowvoltage:
Thanks for your help on this issue. I tried to enter the link you gave me but this is what I got from my computer
" The requested URL /shop/Engine_AccessoriesBB_Zenoah_G38_Choke_Throttle_Lin kage_Kit.html was not found on this server."
Can you help me here?
thanks
Bolt
Old 10-25-2012, 10:14 AM
redbiscuits
Try this, You will need to use the linkage as shown to get the correct angle using a bellcrank and some ball links. Also it is helpful if your radio has a throttle curve to help make the response more linear on the stick.
Old 10-25-2012, 12:30 PM
Lowvoltage
http://www.bennettbuilt.com/index.html
This should get you to the home page.
Old 10-25-2012, 01:44 PM
BOLT
To Redbiscuits and Lowvoltage:
Thanks a lot for your help. The picture and suggestion gave a better idea on what to look for and "how to do it". I've been a modeler for many years and a pure kit builder but never went for the "big ones". Guys like you make this website our top reference guide for anything R. C.
Bolt
Old 10-25-2012, 04:01 PM
Lowvoltage
I believe you can get a different spacer for the carb that will help move it in a little too. I don't have the g38, but people say it is the easiest to start gas engine they ever had. I do have a 62 and a 26.
Old 10-30-2012, 05:30 AM
Jacque
My Feedback: (22)
Graybeard I miss spelled Horizon in my early post they hav an easy link adapter for all there Zenoah eng. .they are great . it mounts the carb so you have a straight connection
Jacque waco Brotherhood # 27
Old 10-30-2012, 06:34 AM
CK1
My Feedback: (60)
CK1's Avatar
Use the easy link carb adapter to rotate the carb for a better linkage alignment .
http://www.ebay.com/itm/Zenoah-Easy-...item2571296626
