Intrested? I'm Bashing a Tiger60
RE: Intrested? I'm Bashing a Tiger60
Culver Cadet slots in LE. Help to get airflow over ailerons in high angle of attack (stalled or near stalled) conditions to help maintain aileron effectiveness.
Your welcome Derrick, be glad to have you and thanks.
Biker-Ken, Stevenmax60 is probably intrested in what you know about retracts in this bird. Personally I think the wing is to thin to get a full retract, plane just wasn't built for them.
I gota say the slide on wings are really cool, they came out just beautiful and they make me feel real good about what I'v done so far. I will post picts. tomorrow some time. The flaps issue bugs me, yes or no ? there easy enough to do but do I need them ? Several have put 120-4's spinning a 14" prop in this plane and said they didn't need flaps because it slowed down just fine and a couple had flaps but said they didn't use them. I just don't want to be sorry and kick myself in the butt if I don't put some on.
"So", whats your thoughts on flaps, keep in mind that my prop 15"x10 or 16"x 8 is going to move alot more air than a 14"x8 even at idle RPM's. Ya think it will slow down to land ?.
ORIGINAL: ARUP
Is that pict. of the real plane wing ?
At one time Goldberg brought out a kit called the Tiger Deluxe ..It had retracts...Trike retracts no less...This was a 60 size plane..I believe they were robart mechanical...The Tiger does not lend itself well to retracts in my opinion..You can do it but I just felt that they were more trouble than they were worth but that is just my opinion...
#32
Leroy.. This is great! Tigers can come out tail heavy so with this engine, you might just have the solution to that.
Thinking back, I had both a Tiger 60 and a Tiger 120. The Tiger 60 was my second plane. The 120 came a few years later. Yeah, I know they are ARFs - but I am not a good builder, but enjoy watching these types of threads. I put the Tiger 120 together with an OS 1.20 AX up front. It needed - wait for it - over a pound of added nose weight to make it balance [:'(] . But, it flew just fine with the added weight, but what a waste. The 120 pulled that beast around real well. The DLE20 was not out yet and that was the power of choice in two stroke glow. But, it still needed the added nose weight.
I tried everything I knew to try to get weight out of the tail, but to no avail. It still needed the pound of lead up front.
I'll be watching this thread with sincere interest!!
Thanks.
CGr.
edit: Well, I take it back. The OS 1.20 is slightly heavier than the DLE20. Oh well, I guess I have to keep the weight up front for now.
Thanks.
CGr.
#34
Just turning on the internet and finding todays tragic event sorta curbed some of the joy of the day. Trying to figure out what in the hell drives someone to kill little children or anyone for that matter, I have no answer, only sorrow in my heart for whats happening to our country and so many innocent victims. Hard to find the words to explain reasons for these terrible events, I just don't get it.
#35
Ok, life goes on
Finished the secureing of the sleeves, wings were measured from trailing tips to tail and all went well including equal dihedral which is 1% or 1/2" per wing side. Will start working on finishing hatches on upper foward deck and lower behind cowl, all in preperation for making a plug to make the fiberglass cowl from. Thats another thing I haven't done but I think I can do it. I have fiberglass experience which should help, just never made a mold. "First time for everything they say.
Cockpit / canopy turned out nicely, I shortened canopy 4 1/2" and I like the looks of profile better than the stock one. All in all I'm getting what I wanted from the start and I'm happy with it all.
I'm going to half to make a decision on flaps so I can order the servos, maybe someone can eloberate on how well flaperons work or am I better off with the flaps. I'd really like to hear some other views on this, Thanks in advance.
Server error, picts will come later
#38
ORIGINAL: bikerbc
Seems like the slots dont line up with the ailerons..Wierd ?
bikerbc, yeah- they're misaligned somewhat. Full scale Cadet pic. Keeps airflow from spilling off tips which keeps ailerons effective longer. I imagine an 'air fence' in lieu of a physical one. Would be fun to see wind tunnel on this.
#39
Leroy, nice job on your build. I am anxious to see how this turns out. I see Tower and others still sell the kit so I am considering this for a future build thanks to your bash thread.
I have enjoyed so far, keep up the good work....Brian
#40
ORIGINAL: CGRetired
Thanks.
CGr.
Thanks.
CGr.
Brian thanks, I'm working on it and it bashes real well, flies great too and I'll not change that trait.
Ed I'm kinda in the same boat as you, won't fly till spring. Gonna be a long weight, bummer.
And 4570jackjack thank you and your welcome.
#41
I didn't tell you the wings are getting sheathed, I think some more strength is in my favor. That little extra weight isn't going to hurt any, I'm hoping to keep it under 10 lbs. Sheeting was bowed enough that straighting it up it was to narrow to get to spar on leading edge so I just glued some strips together and I'm done tonight working on it.
Going to look for sport planes with nice schemes to get ideas for mine.
#42
Leroy, you knew I would be here! Rather than flaps, how about a speed brake? I put one on a Tiger-like bird years ago and it worked remarkably well. It actually had about 4 inches of flap and a faired section went under the fuse. (Zero dehederal wing) The speed brake was about 4-5 inches long and came down about 60 degrees. Added plenty of drag and all the turbulence stayed under the tail.
#43
Leroy I have read where it has been advised against the use of flaperons, I believe it was the late Minn Flyer whos advice is held in high regard..I have never used them myself so can not comment from experience..I can however comment on flaps..If you know how to use flaps properly they work great..It really helps to program in some down elevator with the flaps because the plane tends to pitch up when they are deployed.With the DLE20 I think I would seriously consider adding flaps...You do not have to use them if you dont want to... I guess it partly depends on what you have left after building your ailerons..As for the use of flaperons you can decide on their use anytime ...Program them in ,if you like them leave them , and if you dont like them just program them back out..
#44
ORIGINAL: thailazer
With all my building skills their are still many things I don't know and have never done, thats one of the great things about RCU, the answer is always out there.
#45
Biker Ken, I see you have been promoting my build, what a great guy you are. Minn Flyer's passing is a big loss to us all but he left alot behind. He had an answer for every thing. Ken you have accumulated a good lot yourself and it's great having you and the many who contribute so much for us all. I like your practical answers I see all over the universe. Alot is common sence. many lack that so thanks.
#46
Thank you for your kind words Leroy..Nothing like a pat on the back to aid in recovery..I feel better ,like I am still worthwile..
#48
ORIGINAL: hairy46
No not interested in a tiger 60 build, I will only be looking in because I am building something totaly diffrent a tiger 60.
