If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 126 to 150 of 271
  1. #126
    TonyBuilder's Avatar
    Join Date
    Mar 2010
    Austin , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Intrested? I'm Bashing a Tiger60
    Here is the link
    $19.99
    TB
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1852673   Click image for larger version.
ID:	1852674   Click image for larger version.
    Spectrum convert, DX18-2 AR12120 12ch
    Kingtech K120, T-one, Demon Cortex
    Meister P-47 on the table!!!
    Scale builder
    Turbine rookie!
  2. #127
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TonyBuilder
    Â*
    There is an after market stand off kit for the DLE20, so you have that option too.
    Â*
    TB
    At first I thought you were refering to some kind of muffler stand off, thats what my last referance was but yes, that engine mount shure would make it easier to adjust the carb., wish I knew of it before hand, I might have used it but all along I was thinking it had to be rail mounted.
    Thanks for the web site, Leroy
  3. #128
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Prior to starting the covering I had cut 3 different sets of patterns for the fuselage and settled for one I hope will set the plane off nicely. Really hard finding one that hasn't been used before, there are so many. I have the fuselage about 80% done and should finish it and get the cowling and gear painted come the first of the week and show you what I have been doing. Learning to use the iron and heat gun has been quiet the learning experience, so far I have not had to pull any covering so I must be doing something right.
    Wings are sheeted and that will be another challenge preventing air pockets, I still have more to learn. Ultracote seams to go on very nice the way it shrinks but those large wing pannels are something I've never done. I'll do my best and hope for the best as there is no turning back now.
    Stay tuned, Leroy
  4. #129
    Join Date
    Mar 2010
    Austin , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    UltrCote is by far the best iron on covering to work with. I have done a few sheeted wings and depending on the scheme you are doing it should be easy to do. If I am doing a multiple color wing top one color and bottom another I do the bottom the standard way. I start with the LE and cut a piece that is the right shape of the wing. Then I tack the LE pull back to the TE niche and tight. Then I tack the center section and work the tip. I have found that a heat gun and a glove work best. I pull the covering over the tip and heat it with the gun until I get a perfect tip.
    Then I use the gun to heat the field while I push the air out towards the center of the wing. So I work from tip to cent. The center is only tacked and not sealed all the way. That way the air can get out. If you are doing multiple color then I start from the center and work to the tip. Start with the LE and work each piece back to the TE then trim the end and overlay the next piece. Overlaying is the hardest part and that is where you get the bubbles. I have tried every way I can and it all comes down to heat. To much and it bubbles, not enough it comes of later. I have had great success with Ultracote and once you get the right heat it works great. Some have made a pin wheel that they roll over the overlay areas. It makes little tinny holes and lets the air out, self seals and you cant see it unless you get your face right on the plane. Good luck.
    TB
ID:	1855264   Click image for larger version.
ID:	1855265   Click image for larger version.
ID:	1855266   Click image for larger version.
ID:	1855267   Click image for larger version.
ID:	1855269   Click image for larger version.
    Scale builder
    Turbine rookie!
  5. #130
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Tony the information you mentioned is so true as I'm finding out. You do very nice work and those pictures do help. Temp is the key to success as you stated, learning how to use it is the other.
    So far so good and the fuselage is nearly done, pict's will come shortly.
  6. #131
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ay long last I have a finished (nearly) fuselage, could not match the urethane paint on cowling and even took a sample of covering along. White has to be the hardest color to match, problem is if I redo it I probably will still be off color. Striping was cut from the covering and the darts on stableizers will probably get the same treatment. Canopy will be trimmed with polished Flite Metal and should look pretty good, I tried to tint it with Rite dye but it didn't take well, water was 140 degrees so I don't know why it didn't work. Need to get a pilot now, maybe a tiger, don't know what else would look good in there. Bottom of stablizers has red and white checkers on them and the bottom of wings will have same.
    Wings are next and if I screw up that will be where I do. This is pretty new stuff to me so it's a learn as you go process for me. Wish I had a couple more planes under me with covering, as I said before I'm a painter.
    I just painted the gear today and it was'nt dry enough to mount the gear with the wheels and pants on it so I couldn't get it on the plane, guess I will see how they look tomorrow.
    More to come later,
ID:	1856347   Click image for larger version.
ID:	1856348   Click image for larger version.
  7. #132
    Join Date
    May 2002
    Locust, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    subscribed.
  8. #133
    Join Date
    Mar 2010
    Austin , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking really good Leroy, how about this pilot He is on a micro servo mixed with ruder and switched too.
    TB
    Scale builder
    Turbine rookie!
  9. #134
    sensei's Avatar
    Join Date
    Jul 2002
    SAN ANTONIO, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very nice Leroy, this one is going to be great!
    Bob
    Fly It Like You Stole It!!!
  10. #135
    GaryHarris's Avatar
    Join Date
    Sep 2008
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow! [8D]
    Sig Kadet Brotherhood #1
    Ultra Sport Brotherhood #105
  11. #136
    Join Date
    Jan 2011
    SorrentoBritish Columbia, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Leroy you have done a fantastic job...Congratulations...
    Ken , Biker BC Cub Brother #6 Ultra Sport Brother # 100 Tiger Club # 7 Pulse Brother # 1 Sig Brother # 58 Top Flight Brother # 9
  12. #137
    thailazer's Avatar
    Join Date
    Mar 2008
    Liberty Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great! Where did the wing saddle go though? Don't see how the wing mounts on your ship.
    Tiger Flyer #49
  13. #138
    psmith36's Avatar
    Join Date
    May 2012
    Bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Love your trim scheme. Can't wait to see it all done.
  14. #139
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Â*
    Â*
    TB
    Thanks for nice comment Tony and LOL your pilot, thats outragious, don't know if I would want him in my plane he might just run it into the ground, "Thats suppose to be funny". Now a bobble head might be fun if I could find one that wouldn't lose his head and fly it into the ground.
    I'll come up with something.
  15. #140
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: thailazer
    Toivo how soon you forget, my wings are now plug in, I bashed everything on this ship, it's now a super Tiger 60, "well I hope it's super in the air". Will look better when the wings are covered. I have tried to do something no one else has done and I think I accomplished that.
  16. #141
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And for the rest of you, thanks for liking what I have done so far, it's nice to have that kind of support from you. I would like to see someone else bash this plane, it takes a bashing pretty well. Personally I think the plane looks alot better than a build straight from the box however it is still a really neat plane built from the plans. I dare someone to do what I have done, just trying to motivate ya all, ha ha.
    It's been fun and I have learned alot, next I get to fly it," oh boy, that will be fun".
  17. #142
    thailazer's Avatar
    Join Date
    Mar 2008
    Liberty Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh I remember that all right! You must have covered over your plug-in holes. Looks like you will be getting the shovels out to fly it soon.
    Tiger Flyer #49
  18. #143
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Went out today to find a pilot for my plane and found one, Ice Age Saber Tooth Tiger will fit nicely and I will try to make him look meaner with some art work. Also been laying out the patterns for the wings but I don't like the look so will lay out some more, I also did a couple of large piece coverings shrank on with the heat gun and I got no bubbles and never pulled an edge, getting better all the time and the more you do the better you get. Hope to get some on the plane tomorrow.
    When I get completly finished with the build I will get the engine broke in and install the electronics, everything is sitting there just waiting. I did the lateral balance also and added 10 grams to the left wing tip, now I can put the tips on which are plates designed to direct air flow over ailerons.
    Toivo we had snow on our runway and it went away but we got more which is almost gone, with spring right around the corner it won't be long before were all out flying and I plan on doing alot of it this year, yea, yea. gonna be a good year seeing I no longer work.
  19. #144
    Join Date
    Mar 2010
    Austin , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks good Leroy, you might want to check with PETA before you go chopping him up
    TB
    Scale builder
    Turbine rookie!
  20. #145
    Join Date
    Jan 2007
    Sinclair, WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is looking great!
    ORIGINAL: Leroy Gardner
    ORIGINAL: thailazer
    Toivo how soon you forget, my wings are now plug in, I bashed everything on this ship, it's now a super Tiger 60, ''well I hope it's super in the air''. Will look better when the wings are covered. I have tried to do something no one else has done and I think I accomplished that.
  21. #146
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks good Leroy, you might want to check with PETA before you go chopping him upÂ*[img][/img]
    Â*
    TBÂ*
    May have to cut a hole for his hind end to fit into, it's going to fit in there and look real good, mean too.
  22. #147
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Something is wrong with the web site, when I click on the upload images I lose the whole thing, did it twice last night[:@]
  23. #148
    Join Date
    Mar 2010
    Austin , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    They are waiting for the IT guy to get back from Cabo, haven't been able to post a pick for three days now!
    TB
    Scale builder
    Turbine rookie!
  24. #149
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Â*They are waiting for the IT guy to get back from Cabo, haven't been able to post a pick for three days now!Â*
    TB
    Thanks Tony, good to have a guy in the know on the site.
  25. #150
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just like all builds they come to a end and I have reached the build end of mine. Still have electronics to put in it and get the 20cc engine broke in. "Oh", I'm going to paint the cowling blue with trailing chevrons as soon as the white fully cures. and glue the canopy on. Other than that there isn't much left to do.
    I like the way the scheme came out, looks like a fast sport plane and it probably will be. With a saber tooth tiger for a pilot it should tear up the sky at our field. I hope it will flip, cartwheel, hover and knife edge as it will have the power to get serious, at least thats what I built it for.
    I would like to thank everyone that followed my build and would like to see some one else bash another one right here. I will post the fully finished plane as soon as it's complety finished
    I also think I will get some larger wheel pants and wheels, I think if I fly off grass those on there now could be a problem.
ID:	1858158   Click image for larger version.
ID:	1858159   Click image for larger version.
ID:	1858160   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
