Reload this Page >
Top Flite Contender Kit Build
Old 12-14-2012, 02:14 PM
adreliable661
My Feedback: (12)
Default Top Flite Contender Kit Build
This is my first attempt to post a build log. Hope it goes well as I have enjoyed following along with others. This is actually my 2nd Contender. After flying the pants off my other I decided to strip it down and modify and recover but it was so fuel soaked that I just decided to start from scratch (kit - sorry for the "scratch" reference ). First will post my old contender and then a few of the pics starting the new wing. I hope not to duplicate pics, but initial try did not load. Maybe I tried too many. Will attempt to post old Contender 1st and then try some others.
ID:	1829968   Click image for larger version
Old 12-14-2012, 02:19 PM
adreliable661
My Feedback: (12)
Default RE: Top Flite Contender Kit Build
OK. That worked, now I will attempt a few more. By the way, I put an Evolution .61 on the old plane and had to add about 4 oz of counter weight toward the aft section of the fuse. I am planning on putting an Evolution .60 on the new one. If I recall it is about 4 oz lighter and hopefully will better ballance.
ID:	1829972   Click image for larger version
Old 12-14-2012, 03:18 PM
Wagon1
Wagon1's Avatar
Hi Grump. I'm looking forward to your build. I have outgrown my trainer but am not the pilot I need to be to fly the scale planes I would like. I always thought the Contender would be a good next bird.
Old 12-14-2012, 03:52 PM
adreliable661
My Feedback: (12)
What trainer have you been flying? Kit? ARF? I did my initial training on a Kadet SR ARF. Then built a Great Plains Stik 60 prior to the Contender. Both the Contender and the Stik are pretty straight forward builds. The Stk is a little more gentle progression. The contender is quick and fast. Need to stay on top of it in flight.
ID:	1829990   Click image for larger version
Old 12-14-2012, 04:09 PM
WacoNut
WacoNut's Avatar
I have around 100 flights on my Contender I built earlier this year and love the plane. It has an old OS .61 4-stroke. Required no additional weight for balance.
I modified the rudder slightly and added the upswept wing tips. I do not have the adverse yaw that many guys report with this plane. It i a real joy to fly. This has been my go to plane since the maiden flight. I am interested to see what you might change after having another Contender.
Later!!
Anthony
ID:	1829994   Click image for larger version
ID:	1829995   Click image for larger version
Old 12-14-2012, 04:40 PM
Wagon1
Wagon1's Avatar
I can build 'em....I just can't fly 'em. I am flying a Kadet Senior as well. VERY relaxing. It is a real joy to fly. I also scratch built a 1/2a kadet that flys just like the big one. Neither have ailerons. I rebuilt an old Aeromaster my brother built in the 70's and it scares the heck out of me. I'll leave her hanging from the ceiling until I get more confident.
Old 12-14-2012, 05:07 PM
adreliable661
My Feedback: (12)
Looks awesome! Thanks for the post WacoNut! Re any changes, primarily hope to have improved my building skills. Going to do the strainght tips like yours. this time I will build in some right torque in the firewall BEFORE I build the cowling. About the only thing I do not like about the plans is the virually useless hatch for the fuel tank. You cannot really get to and service the tank without having to cut out the support braces underneath. I am sill debating on the color scheme. I am thinking of doing the same that I had. Loved it. Since the picture files are too large to post at once I am going to keep posting 2 or 3 at a time in my replies.
ID:	1830024   Click image for larger version
Old 12-15-2012, 03:51 AM
OldScaleGuy
OldScaleGuy's Avatar
Nice work Grumpy. WacoNut did a good build thread on his, you might want to look that up for some reference. Love the way the Contenders fly. Touch and goes are a blast.
Old 12-15-2012, 06:45 AM
[email protected]
Thanks for doing the Build Log, Grump. I'll be following your progress and am looking forward to it.
Old 12-15-2012, 08:02 AM
adreliable661
My Feedback: (12)
Thanks OldScaleGuy. Where is the thread for WacoNut? One area that was very difficult on my first build of the Contender was trying to install per instructions the wing dowels. The instructions have you blindly drilling through the already installed and rounded leading edge. I decided to do the hole drilling and istallation of the wing dowels ahead of time for a perfect alignment and then install the leading edge. Worked great
ID:	1830189   Click image for larger version
ID:	1830190   Click image for larger version
ID:	1830191   Click image for larger version
Old 12-15-2012, 08:09 AM
adreliable661
My Feedback: (12)
Thanks. A couple of folow up pics for my comments on the wing dowels.
ID:	1830197   Click image for larger version
Old 12-16-2012, 10:10 AM
adreliable661
My Feedback: (12)
Anthony,
Just looking over your pics again and noticed what looked like a 'smoke' finish inside the canopy. If so, how did you achieve that?
Old 12-16-2012, 10:22 AM
adreliable661
My Feedback: (12)
A few more pics on how the leading edge worked out with the pre-installed wing dowels
ID:	1830779   Click image for larger version
ID:	1830780   Click image for larger version
ID:	1830781   Click image for larger version
Old 12-17-2012, 02:48 PM
WacoNut
WacoNut's Avatar
Hi Grumpy,
Sorry about the delay I was gone hunting for a couple of days. I tinted the canopy using black RIT clothing dye. You can find it at most grocery stores. It is a simple process of just running hot water into a bucket/pot and mixing in the dye powder and soaking the canopy for approx 20 minutes. Do not use your better halfs good kitchen pot if you value your life
Here is a link to my build thread. [link=http://www.rcuniverse.com/forum/m_11166437/anchors_11166437/mpage_1/key_/anchor/tm.htm#11166437]Contender Build[/link]
I did do a few modifications but not many. The rudder was the biggest change. I did beef up the landing gear mounting as well.
Later!!
Anthony
Old 12-17-2012, 04:27 PM
adreliable661
My Feedback: (12)
Thanks WacoNut! I already painted so I wonder if I can just invert and make it a basin and poun in the dye?
Now for some pics of the control surfaces......oops, looks like I forgot the tail feathers.
ID:	1831281   Click image for larger version
ID:	1831282   Click image for larger version
ID:	1831283   Click image for larger version
ID:	1831284   Click image for larger version
Old 12-17-2012, 05:14 PM
WacoNut
WacoNut's Avatar
If you painted the outside of the canopy then you could just fill the inside. You would have to make sure the canopy is supported well and will fill up evenly.
Might be a bit tedious but should work. You could always paint over the framework if you get some die on the painted surfaces.
Good Luck!!
Anthony
Old 12-21-2012, 08:20 AM
flmlm
Looking Great...keep up the good work!
Regards
Mike
Old 12-22-2012, 07:11 AM
shepard62
My Feedback: (10)
Old 12-22-2012, 12:23 PM
oldtyme
ORIGINAL: shepard62
Some changes to my Sig Kadet.
mag hatch
What's that got to do with this Contender build?????
Old 12-23-2012, 08:28 AM
adreliable661
My Feedback: (12)
I guess someone hit the wrong button. Anyway, time for the wing tips and completed wing
ID:	1833072   Click image for larger version
ID:	1833073   Click image for larger version
ID:	1833074   Click image for larger version
ID:	1833075   Click image for larger version
ID:	1833076   Click image for larger version
Old 12-27-2012, 03:38 PM
flmlm
Thanks for starting this thread has motivated me to continue with my own Contender build [].
Regards
Mike
Old 12-29-2012, 08:06 AM
adreliable661
My Feedback: (12)
Look forward to seeing your progress. Now to start posting progress on the fuse
ID:	1834563   Click image for larger version
ID:	1834564   Click image for larger version
ID:	1834565   Click image for larger version
ID:	1834566   Click image for larger version
ID:	1834567   Click image for larger version
ID:	1834568   Click image for larger version
ID:	1834569   Click image for larger version
Old 01-10-2013, 04:32 PM
adreliable661
My Feedback: (12)
More progress on the fuse. I built in a little right thrust in mounting the firewall which explains the appearant gap.
ID:	1839000   Click image for larger version
ID:	1839001   Click image for larger version
ID:	1839002   Click image for larger version
ID:	1839003   Click image for larger version
ID:	1839004   Click image for larger version
Old 01-15-2013, 04:56 AM
adreliable661
My Feedback: (12)
Now for the fuel tank and top formers. One thing I do not like about this kit is that the hatch for servicing the fuel tank is on the bottom of the fuse, below the supports for the tank. The only way to service the tank is to cut out the supports, unless someone has another idea (I should have asked prior to moving forward). I thought about putting a hatch on top, but as you can see from the pics the tank would not be removable through that opening.
ID:	1840646   Click image for larger version
ID:	1840647   Click image for larger version
ID:	1840648   Click image for larger version
ID:	1840649   Click image for larger version
ID:	1840650   Click image for larger version
ID:	1840651   Click image for larger version
ID:	1840652   Click image for larger version
Old 02-07-2013, 04:14 AM
sevillious
Hi gang,
Just found this thread, and I too am building a contender. I am in the middle of the wing construction. Thanks ad661 for the tip on the
wing dowels. I did not want to drill into the LE. I will use your method. I am hoping to finish the wing in the next week or so.
I am not real fast!! Thanks to all for the helpful pics and posts.
More to come....
