Reload this Page >
Top Flite GS P-47 sports scale; diary of a build
Old 04-24-2015, 06:01 AM
  #2051
TonyBuilder
TonyBuilder's Avatar
Thanks Bob, yes this does help. I'm not glass so I will be tight to the fuselage on both C2 and F5 I have the carbon fiber end plates I will glue to E5 and C2 as I will be using foil to cover the belly. 1/64 ply is a good spacer for the gap.
TB
Old 04-24-2015, 06:09 AM
  #2052
willig10
Tony:
Did you see my PM?
Glenn
Old 04-24-2015, 09:48 AM
  #2053
FlyerInOKC
FlyerInOKC's Avatar
TB I still think your sports scale is more scale than a lot of straight scale airplanes.
Old 04-24-2015, 12:24 PM
  #2054
TonyBuilder
Originally Posted by willig10
Tony:
Did you see my PM?
Glenn
Glenn, yes I did, sorry been busy, I left them in Hourshoe Bay and haven't been back for a week or so. I am back on Monday and will ship them out.
TB
Old 04-24-2015, 12:25 PM
  #2055
TonyBuilder
Thanks, just the way I build
TB
Old 04-24-2015, 12:47 PM
  #2056
TonyBuilder
I have the wheel wells pretty much done short of a few details.
Im getting them ready to paint.
There are very slight diferances between the left and the right being the right was done over a year ago and I don't think anyone will notice.
Mainly it is different as the way I built them but the end result should be very close.
Once I have the wells painted I will install the gear and the air cylinders for the inner door and rout the hoes lines as they need to be strapped into the wheel well.
I think the best way to do the gear doors is to first install the gear, get it to where I want it. Then cut the carbon fiber bottom skin. Once that is all trimmed and looking good I will glue it in. Then I can cover with 1/16" balsa, sand and fill to get the wing ready to cover then cut the balsa to fit the gear.
So I will work on that next.
TB
ID:	2091602   Click image for larger version
ID:	2091604   Click image for larger version
ID:	2091605   Click image for larger version
ID:	2091609   Click image for larger version
ID:	2091610   Click image for larger version
ID:	2091611   Click image for larger version
ID:	2091612   Click image for larger version
ID:	2091614   Click image for larger version
ID:	2091616   Click image for larger version
ID:	2091618   Click image for larger version
Old 04-27-2015, 02:56 PM
  #2057
TonyBuilder
The wheel wells are done and I cut the carbon fiber bottom skins for the gear.
I make a templet of the gear doors to trim and adjust it to fit my wheel, gear and wheel well.
I trace ace it over the CF skin and leave about a 1/16" in so I create the lip for the gear doors.
Cutting the the skin is much easier then after it is glued in, I use my scroll saw. Once fixed the skins gets glued in.
The wells are done and ready for paint.
One thing ink new I am trying is using a bumper to badge the way the gear sits in the well. I want the gear to close all the way and be tight but don't want it slamming into the lip for the gear doors so the bumper is on the I- beam. The gear will always be Coles as the air pressure will be positive on the gear.
The gear is mounted and wells are ready for paint. The gear doors flush out with the top and there is plenty of room in the well still.
With the wells ready and the skins cut I painted the wells yellow crome.
With the wells painted and once they dry I can install the air cylinders for the inner doors, the gear and cut the doors.
I did not detail the left side as much as the right but who will know
Yellow really looks good and once the aluminum is on it will pop.
TB
ID:	2092628   Click image for larger version
ID:	2092629   Click image for larger version
ID:	2092630   Click image for larger version
ID:	2092631   Click image for larger version
ID:	2092632   Click image for larger version
ID:	2092633   Click image for larger version
ID:	2092635   Click image for larger version
ID:	2092637   Click image for larger version
ID:	2092638   Click image for larger version
ID:	2092641   Click image for larger version
ID:	2092642   Click image for larger version
ID:	2092643   Click image for larger version
ID:	2092644   Click image for larger version
ID:	2092645   Click image for larger version
ID:	2092647   Click image for larger version
ID:	2092648   Click image for larger version
ID:	2092649   Click image for larger version
ID:	2092651   Click image for larger version
ID:	2092652   Click image for larger version
ID:	2092653   Click image for larger version
ID:	2092655   Click image for larger version
ID:	2092658   Click image for larger version
ID:	2092659   Click image for larger version
ID:	2092660   Click image for larger version
ID:	2092664   Click image for larger version
ID:	2092668   Click image for larger version
ID:	2092669   Click image for larger version
ID:	2092670   Click image for larger version
ID:	2092672   Click image for larger version
ID:	2092673   Click image for larger version
ID:	2092674   Click image for larger version
ID:	2092675   Click image for larger version
Old 04-27-2015, 07:19 PM
  #2058
rt3232
T/B
Look great, keep on trucken
Cheers Bob T
Old 04-28-2015, 02:12 AM
  #2059
TonyBuilder
Thanks Bob, I'm getting close. Once I get the bottom balsa in at the gear I will sand the wing and prep it for the belly.
TB
Old 04-28-2015, 07:27 AM
  #2060
FlyerInOKC
FlyerInOKC's Avatar
Nice TB!
Old 04-28-2015, 02:18 PM
  #2061
TonyBuilder
Getting some progress on the right wing gear doors.
I plumbed the gear and the inner gear door cylinder. I rougted the house for the inner door threw the gear bay and back along the main well back wall.
Getting all the houses in was not to bad as I planed for it so I pre drilled holes in walls and detailed panels before I painted.
Nest at I fine tuned the CF skin.
The gear goes in without hitting the skin so we are good.
Getting the geomitry for the inner gear door cylinder takes time. All I care is that the door is open 90* when open and that it is closed tights so with air you can have the cylinder not close all the way, this way it keeps pressure the door without draining a battery or burning a servo if you use a servo for the doors. I prefer air all the way.
I first cut the gear doors from the templet, then start fitting them to the wing.
I use 4 carbon fieber lay ups to do the bottom, and the gear doors.
The balsa skin is cut from 1/16" balsa and cut and fitted around the gear door, then glued it in with epoxy. This method is much better then cutting the gear from a finishe covered wing. I will do this on the Meister build.
The carbon skin works as the lip stop for the gear doors.
Now that the doors are cut into three pieces I will bolt the lower door to the main gear. As planed I sanded the gear stop block so the gear will sit lower and the doors are flush now with plenty of room. I will detail the doors as I have the room to do so.
The doors will get 3/32 birch ply glued to the top of the CF doors, this will flush them out and I can cover them with covering. Once both wings are fired I will sand it all as a whole.
Next I will hing the inner door and the upper door.
TB
ID:	2092852   Click image for larger version
ID:	2092853   Click image for larger version
ID:	2092854   Click image for larger version
ID:	2092855   Click image for larger version
ID:	2092856   Click image for larger version
ID:	2092857   Click image for larger version
ID:	2092858   Click image for larger version
ID:	2092861   Click image for larger version
ID:	2092862   Click image for larger version
ID:	2092863   Click image for larger version
ID:	2092864   Click image for larger version
ID:	2092865   Click image for larger version
ID:	2092866   Click image for larger version
ID:	2092867   Click image for larger version
ID:	2092870   Click image for larger version
ID:	2092872   Click image for larger version
ID:	2092873   Click image for larger version
ID:	2092874   Click image for larger version
ID:	2092875   Click image for larger version
ID:	2092876   Click image for larger version
ID:	2092877   Click image for larger version
ID:	2092882   Click image for larger version
Old 04-28-2015, 05:51 PM
  #2062
rt3232
T/B
Nice progress
Cheers Bob T
Old 04-29-2015, 05:31 AM
  #2063
TonyBuilder
Default Inner gear door
I finally got the inner gear door installed. I tried a couple hinging and ended up with a piano hinge. It is not scale but very functional. The full scale looks to have an offset hinge so I will do that on the Meister.
The air cylinder is correctly placed so the door is open at ninety degrees and closes tight so it is still pulling on the door when closed for a tight fitting.
The wheel clears the cylinder with a little wiggle room.
Next I will work on the upper door.
TB
ID:	2092968   Click image for larger version
ID:	2092969   Click image for larger version
ID:	2092973   Click image for larger version
ID:	2092974   Click image for larger version
ID:	2092975   Click image for larger version
ID:	2092976   Click image for larger version
ID:	2092977   Click image for larger version
Old 04-29-2015, 05:59 AM
  #2064
FlyerInOKC
FlyerInOKC's Avatar
Nice job TB!
Old 04-29-2015, 12:42 PM
  #2065
stevegauth30
stevegauth30's Avatar
Great progress TB. Youll be flying it in no time. Looks great too.
Old 05-03-2015, 04:08 AM
  #2066
TonyBuilder
ARCA had our warbird this weekend, it was a blast, over 100 planes and 53 pilots. Next year I will have Miss Fire in the mix.
Here is a video of the action.
https://youtu.be/y8fZ3vyNKMQ
Next year will be even bigger.
TB
ID:	2093680   Click image for larger version
ID:	2093681   Click image for larger version
ID:	2093682   Click image for larger version
Old 05-03-2015, 04:26 AM
  #2067
rt3232
Great pic's no wonder you stay so motivated
Cheers Bob T
Old 05-03-2015, 04:42 AM
  #2068
stevegauth30
Thoroughly enjoyed the video. Some really nice planes there.
Old 05-03-2015, 04:43 AM
  #2069
stevegauth30
Old 05-04-2015, 07:51 AM
  #2070
TonyBuilder
Those guys from RC Hobby shop really put on a show.
TB
Old 05-04-2015, 08:04 AM
  #2071
FlyerInOKC
FlyerInOKC's Avatar
That last photo with the three bombers should have a caption reading "Confederate Air Force eat your hearts out!".
Old 05-04-2015, 08:06 AM
  #2072
TonyBuilder
Getting some work in before I have to go back to real work.
The gear doors are done on the right wing and I used some of the parts from the prototype, as this will save having to make new ones and figuring what works.
The upper door is hinged with a single Robart hinge pin and is bolted with two screws threaded into the hinge.
The linkage holding the door is the same as on the prototype and works very well.
The doors close without binding. The higher you place the bracket the better as it lifts the upper door first. I have a slight gap as I don't want to redo the linkages as to move it higher. This works fine for this build.
The doors close tight and there is only a small gape at the upper door and the lower door. Plus a gap at the upper door where it meats the wing but this is mostly closed when the gear is down.
https://youtu.be/YVZyPIzS4Bg
Next I will do the left wing.
TB
ID:	2093837   Click image for larger version
ID:	2093838   Click image for larger version
ID:	2093839   Click image for larger version
ID:	2093840   Click image for larger version
ID:	2093841   Click image for larger version
ID:	2093842   Click image for larger version
ID:	2093843   Click image for larger version
ID:	2093849   Click image for larger version
ID:	2093850   Click image for larger version
Old 05-04-2015, 08:53 AM
  #2073
FlyerInOKC
FlyerInOKC's Avatar
Looking good TB very first rate!
Mike
Old 05-05-2015, 02:44 AM
  #2074
TonyBuilder
Here is a video of the three bombers flying with top cover at our event this weekend.
https://youtu.be/rlRK-n_MVxA TB
Old 05-05-2015, 04:44 AM
  #2075
TonyBuilder
Got the left wing gear doors cut and skinned.
The inner door is hinged and ready for the linkage to be installed.
I started to detail the upper door to see how that would work.
Almost got the gear all done. I am hoping to have the wing ready to cover next weekend.
The schedule for this year is creeping up on me. Bomber Field has there warbird on June 6th and then the next week is WBOT, or the Scale masters qualifier.
The next qualifier is in August at Bomber field and then the championship is also at Bomber field in October of this year.
Also thinking of going to Joe Nall next week so we will see.
TB
Name:	gear doors 001.JPG
ID:	2094045   Click image for larger version
Name:	gear doors 002.JPG
ID:	2094046   Click image for larger version
Name:	gear doors 003.JPG
ID:	2094047   Click image for larger version
Name:	gear doors 004.JPG
ID:	2094048   Click image for larger version
Name:	gear doors 005.JPG
ID:	2094049   Click image for larger version
Name:	gear doors 006.JPG
ID:	2094050   Click image for larger version
Name:	gear doors 007.JPG
ID:	2094051   Click image for larger version
Name:	gear doors 008.JPG
