Ultracote, monokote or other?
Hi,
I will get a four star fourty kit and was wondering if people prefer monokote or ultracote and why?
What suggestions do you have for covering the four-star?
The best to all!
The best to all!
MA
RE: Ultracote, monokote or other?
Ultra is much easer it work with
Mono has more color choices,
Mono has the pigment in the adhesive,
Ultra had the pigment in the film
Each one has pro and con
Mono is with a doubt more difficult to work with,
I personally use mono because I have been working with it for a while and I love the color opacity
I can pretty good with it.
Some people use a ultra base with a mono trim
Because you can use the windex method over a nice base
My Feedback: (243)
Monokote is more durable (Mylar), retains color and gloss longer due to color being in the adhesive. Requires more heat to mold around curves and shrink tight. Bonds well at overlap.
Ultracote less durable (Polyester), colors fade and becomes dull over time, although waxing from the start minimizes this. Less heat for bonding and shrinking, easier to mold around curves. Does not always bond well at overlap.
Monokote has more colors to choose from.
Both suffer from application issues if stock 1 to 2 or more years old. Fresh stock has a noticable aroma. Store unused in plastic bags to preserve freshness.
My Feedback: (-1)
^ what Steve said. This is an old debate so if you do a search you will find hundreds of pages about Mono VS Ultra. I used Mono for years but about 15 years ago Mono changed the formulation and sometimes it will shrink and sometimes not at all. I changed over to Ultra and if I have a choice I never use Mono. I do keep Mono on hand for trim. I like using Windex with ammonia to put the trim on. Ammonia activates the adhesive on Mono but doesn't do it on Ultra. Ultra is a bunch easier to work with. There aren't as many colors to choose from but Ultra works very well almost every time. Only color I have ever had a problem with is there aluminum once. The Tex cloth coverings are perhaps the best covering I have ever worked with and will look great on a 4*.
Ultracote it is then.
I have used it on an extra 300 10 years ago, and don't remember any issues. Just getting back into the hobby after 10 years hiatus.
I will check out the tex cloth.
FL
I have been working with mono for the last 20+ yrs. Great stuff and very wide color selection. One of the things that I like is that it matches so well to after market paint such as testors and tamyia paints. I personnally use model master from testors, matches very well to most of the mono that I use.
Hobby King covering works good. I've used it twice and love it. Never used Ultra but have a roll I'm going to try on my next model. Haven't used Mono in years.
My Feedback: (-1)
^ I'm going to buy some of the HK covering soon and give it a try. I have been told it works as well as Ultra and the price is sure right if it is out of the US warehouse and the shipping is cheaper then if it comes from China? I have a big electric plane to cover right now and will give some of the new light weight covering a try too. I want to try the cloth type you can see through. Looks like it could be a fun covering to use.
I saw that ultracote has parklite (for indoor types) and lite that is semi-translucent?
If you want to save weight but keep some strength what would you guys use?
Thanks!
Thanks!
My Feedback: (-1)
Going to give Coverite Microlite a try on the plane I'm almost ready to cover. On a old plane that has a bit of oil in the wood I may give it a light spray of lacquer hair spray over the wood but other then that all I do is take a tack cloth and wipe the frame down. Ultra sticks to wood perfectly as long as it has been cleaned of dust. If you use anything over the wood before covering it does stick well but when you want to remove the covering for repairs and a recovering job it tends to stick and not come off.
ORIGINAL: Dick T.
The fundamental difference between the two types of color is that MK has the color in the adhesive while UK has the color mixed into the plastic film. UK is slightly thicker and hence heavier than MK. It gives MK the edge on color choices but as far as stability, it's hard to beat a color mixed into the plastic. But both need stabilizers for UV, Oxygen and Ozone attack....ASALWAYS, YMMV!!
