First Build need help!
Reply
Old 01-30-2013, 07:36 PM
Dhide371@mac.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default First Build need help!
Finished building this t6 Texan from house of balsa. The build was great and up until covering this damn wing I was feeling pretty good! Here are some pictures any help? I'm using econocoat. The wing just won't shrink when heat is applied it seems to make it saggier.
ID:	1846276   Click image for larger version
Dhide371@mac.com is offline
Old 01-30-2013, 07:45 PM
eddieC
eddieC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: First Build need help!
No pics. Use the 'Post reply' just below the text box, not 'quick reply'.
You may need to get it hotter, but be careful.
eddieC is offline
Old 01-30-2013, 08:05 PM
Dhide371@mac.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok I'm going to try high heat tomorrow! Thanks need to get the heat gun out girlfriends blow dryer not cutting it!
Old 01-31-2013, 12:30 AM
GaryHarris
GaryHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Welcome to RCU. I assume your using Monokote and the included instructions are pretty good, so follow them. Your going to have to do as much stretching, pulling and cussing as possible before trying to shrink everything down. Do like the instructions say as far as tacking the covering down and pull the covering as tight as you can at the next tack spot. Don't rely on heat to do the shrinking for you. Heat is only a small part of the tightening of the skin. You gotta pull, use 3 hands, your knee, your forehead and cuss alot before tacking corner to corner. Do the best you can to get all the wrinkles out as you stretch the covering before tacking down and don't count on heat to take the wrinkles out for you.
Edit: Econokote. Just noticed. Humm, I dunno. Probably the same procedure with even more cussing. And BTW, I don't know how much experience you have as far as flying goes, but I assume that you are new. Covering a T6 is much easier than flying one. Jus sayin.
GaryHarris is offline
Old 01-31-2013, 02:43 AM
CHassan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah your girlfriends blow dryer won't cut it.
The key is not to rely on the shrink of the covering to get the wrinkles out. Yes it does in many cases, but trying to get it tacked on with as as little extra covering as you can. Then you won't have as much work to do trying to shrink the covering. Tack a corner, then pull and tack the opposite corner. Pull and tack the remaining corners. Now you can tack down the remaining lengths, but always pull the covering snug.
With what you have there now I'd be surprised if they all came out.
Keep the heat gun moving. I just blew big holes in mine the other night because I hesitated with the gun a little to close.
CHassan is offline
Old 01-31-2013, 03:15 AM
gene6029
gene6029's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The key here is to apply the econokote with as few wrinkels as possible.( sounds easy) Try sealing just the leading edge first, then pulling towards the trailing edge & sealing it. Next seal the ends of the wing pulling it as tight as you can without distorting the wing. After you have all the edges sealed either go over the center section with an iron & or use the hot air gun. Econocote melts faster that Monokote so becarefull. Remember, try and get as much of the loose covering pulled out before you try & shrink the center. I also noticed in your photos that there isnt much if any covering on the trailing edge. ( unles you allready trimmed itoff), but if thats not the case, you need to leave more around the edges to be able to grab hold of & pull with when applying the covering. That will help you get those wrinkels out from the start....Gene
gene6029 is offline
Old 01-31-2013, 04:39 AM
airbusdrvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This info is not to get a covering brand war started. If you do another build, try Ultracote. It will be much easier to install and shrink than some of the cheaper coverings.
airbusdrvr is offline
Old 01-31-2013, 04:45 AM
CHassan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Watch these videos by our departed friend Minnflyer.
http://www.rcuniverse.com/magazine/a...article_id=726
CHassan is offline
Old 01-31-2013, 05:08 AM
eagle 01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi:I didn't like that term Departed Friend!Did something happen to him?May not have been on here much lately but now as I think of it haven't seen any Minn Flyeer posts lately!Hope he is ok!!!
eagle 01 is offline
Old 01-31-2013, 05:21 AM
goirish
goirish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: eagle 01
NOPE! MinnFlyer is now flying higher than you and I. A tremendous loss for RCU and his family. I miss is insight a great deal. RIP
goirish is offline
Old 01-31-2013, 06:04 AM
TCampbell
TCampbell's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I find covering to be made easier when you have good temperature control. The heat gun will work, but there's no precise way to ensure the temperature you're using is correct, you'll have to really keep an eye on the film and as soon as you see it start to tighten, back the gun off. These plastic films have an adhesion temperature where the glue activates and starts sticking and then a higher shrink temperature. The packaging likely gives you the ranges, but from my notes Econokote adheres at 220 F and shrinks at 275 F (but definitely check the packaging). A covering iron and an infrared temperature gauge to ensure proper temperature will really help as you get started covering.
TCampbell is offline
Old 01-31-2013, 02:50 PM
RCKen
RCU Forum Manager/Admin
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: eagle 01
Unfortunately Minnflyer died last April. His death was unexpected and left a huge hole in a lot of lives, and especially here at RCU. I considered Mike one of my closest friends and even after all this time I still don't go a day that I don't miss him. Mike is definitely missed out of my life
Ken
RCKen is offline
Old 01-31-2013, 04:23 PM
aymodeler
aymodeler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a great tutorial from the "other site" that I found helpful: linky
It may take a few tries to get it right (I went through a whole role of covering when doing my first wing), but if you keep at it you'll get the hang of it.
aymodeler is offline
Old 01-31-2013, 05:51 PM
black dog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use Econokote on my first build many years ago. I did not have a heat gun,followed directions and used a house iron. It turned out excellent!!No one believed I used a house iron but, I had to buy my wife another iron.
black dog is offline
Old 01-31-2013, 06:31 PM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When using that heat gun, keep it in motion especially over open bay areas. If you concentrate the heat, it will burn through.
Don't let this covering issue discourage you from trying it again in the future, though. All of our first covering jobs came out like a 90-year old person (don't want to get sexist here). The next job will be remarkably better.
Along with that video, look on Amazon for some used books by Faye Stilley as well if you need some tips... He's a master.
Bob
N1EDM is offline
Old 01-31-2013, 06:39 PM
eddieC
eddieC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recall the old Monokote video where they cover a ball without leaving a discernible crease.  Gives one some confidence. [8D]
eddieC is offline
Old 02-01-2013, 04:31 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Use more heat!
I assume you use an iron (you should).
For your next build...use Oracover...It's much easier to use and much sturdier.
jaka is offline
Old 02-01-2013, 09:52 AM
Dhide371@mac.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, more heat and a taught and more carefully placed covering the econokoat went on without a hitch. Also my heat gun made my littler wrinkles disappear! My next build I will make sure all surfaces of the wing are sanded with no edges to poke the covering. Let me know what you guys think!
ID:	1846806   Click image for larger version
Old 02-01-2013, 11:39 AM
rafeeki
rafeeki's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great, hard to beleive u havent done this before))
I always wondered how a two colored wing is done (on the same surface) . e.g. half yellow, alf red. Is one cut and the other color is fused to it?? Excuse my ignorance.
Rafeek
rafeeki is offline
Old 02-01-2013, 01:49 PM
Dhide371@mac.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well since I kept messing up with the yellow I finally ran out of enough to cover both wings. So I had some red left over so this was the result haha. It worked tho! I think next time however I would like to have the covering wrap all the way around the leading edge. It just seems the airflow would be optimal that way. But we will see, I am nervous to fly this one tho after all the hours put into it! waiting on the Motor and the rest of the electronics from Tower. Will post when all put together.
Old 02-01-2013, 01:59 PM
vicman
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They fly pretty good but definitely not a trainer. Your covering looks really nice.
Something not mentioned yet but when I do mulitple colors and layers I try to stagger the edges so they trail off with airflow. You are less likely to have oil etc get in there and cause problems.
Funny you should post, I pulled a 80%built one off the shelf the other night and am getting it finished off to fly this spring.
vicman is offline
Old 02-01-2013, 02:08 PM
huck1199
huck1199's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will miss Mike's posts. How old was he?
huck1199 is offline
Old 02-01-2013, 04:04 PM
eddieC
eddieC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks great.
I use clear nail polish over all seams. It's a pain, but worth it in the long run.
What engine is going in it?
eddieC is offline
Old 02-01-2013, 04:31 PM
goirish
goirish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dhide371@mac.com
OH!! that looks terrible, I'm jealous. Nice job. Sending my wings to your house.
goirish is offline
Old 02-01-2013, 05:53 PM
Dhide371@mac.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm putting the recommended 400 long can in and will see from there. This being my first build I didn't want to stray from the directions, what do you think?
Reply
Display Modes
