Hanger 9 UltraTrim
Hanger 9 UltraTrim
I want to put this out there. I covered the cub with the cub yellow UltraCote. I made the lighting stripe using Black UltraTrim and added it to the Cub. I noticed today that on one of the stripes it looks like the clear coating peeled away for the entire length of the stripe. Is there a CLEAR protective on the finish surface of this trim or is this finish now hosed?
RE: Hanger 9 UltraTrim
I've never heard of that type of failure.
I have pulled the top coat (color) off Ultra-Kote while removing a factory decal on an ARF. It was very tough to do, but I managed it.
The funny part is the Color is still down cleanly. It pulled up like it was clear protective film. It only did it on one peice and I cat get it to do it on he other pieces.
Ok then I take it it is not supposed to do that
i call horizon hobby and the guy I spoke with did not know a lot about covering. He asked a co worked and they said it may be protective covering. I wondering if they thought I was talking about the backing
icall horizon hobby and the guy I spoke with did not know a lot about covering. He asked a co worked and they said it may be protective covering. I wondering if they thought I was talking about the backing
I wasn't going to insult you and ask if it was the backing. [8D]
I suspect you got a bad batch.
My Feedback: (-1)
I just reread the post and noticed it was the trim sheet you used and not the covering. By chance did you try to iron on the trim? Just wondering because I haven't see it happen before, I also haven't used any trim sheet in a long time though but it is a sticky back type of covering.
Yes it was a sticky backed trim sheet . I did not iron it and it was applied using the soap and water method.once dried I wiped the trim using a paper towel with a little acetone.
I was not putting this out there as something new . I really wanted to know if it was supposed to do this
My Feedback: (19)
ORIGINAL: Taxus812
