NACA Vents Supplier Found
IA
First of all my appologies (SP) to the true kit builders. You guys would probably build your own vents instead of buy them. Im not that talented.
Im finishing up a Bird of Time ARF electric conversion and am looking for a suitable size Naca vent to install in the arf for cooling the ESC.
Anybody know a supplier for these?
Thanks in Advance for the Help
Rich
After doing some more research, I found a supplier for NACA vents. Park Flyer Plastics
7755 Noreast Drive
North Richland Hills TX
(817)233-1218
Rich
7755 Noreast Drive
(817)233-1218
RE: NACA Vents Supplier Found
If you do not hear from anybody,you can use a plastic spoon with the handle cut off and glue it to both sides of the fuselage lined - up with a hole on the fuselage side.
You'll really enjoy the electrified Bird of Time. Here are a few photos of mine.
I just left the rear hatch off allowing air to flow from the front scoop, thru the fuse, and out the rear.
I also modified the tail with a bellcrank, moving the elevator servo under the wing. The fuse was not wide enough for the tail to functions as the manual configures it.
Here is my build thread:
http://www.wattflyer.com/forums/showthread.php?t=46714
SunDevilPilot
SunDevilPilot
