Reload this Page >
~~SIG Brotherhood ~~
Old 05-08-2017, 07:38 AM
  #2526
FlyerInOKC
FlyerInOKC's Avatar
Looking good guys!
Old 05-09-2017, 09:17 AM
  #2527
SrTelemaster150
SrTelemaster150's Avatar
Photo test.
Old 05-09-2017, 09:21 AM
  #2528
FlyerInOKC
FlyerInOKC's Avatar
Picture worked!
Old 05-09-2017, 04:36 PM
  #2529
Pork Chop
Pork Chop's Avatar
Talking
Thanks guys for the comments and Dave you should pick up a Sig glider for your next build (Better than a whipping)
Old 05-10-2017, 05:51 PM
  #2530
Captcrunch44
Well I started to cove fuse tonight. Wow I don't think i got enough covering. I bought two 25' rolls and just used 16' on the fuse. Its ok i am just use to covering 60 size planes. Ha ha.
Thanks to some good advice from my sig brothers. This is the best cover job i have ever done. Still will take awhile to catch up to acdii.
Old 05-11-2017, 04:52 AM
  #2531
acdii
Considering the fuse is done, and half the stab is done, I would say so. Hoping to have the other side done tonight, and get the elevator started. It's Crunch time! Well for me that is, only have 2 1/2 weeks left to get this airborne if I want to have it at the flyin, otherwise I have to do a rush job on the other planes to have them ready.
Old 05-11-2017, 06:48 AM
  #2532
FlyerInOKC
FlyerInOKC's Avatar
I am impressed by the rate you guys are building, you are an inspiration!
Old 05-11-2017, 11:36 AM
  #2533
acdii
Well after many tries at an in cowl exhaust for the DA 100, I finally gave in and just ordered the stock ones for a DLE111 from TH. Guess I will have to cut up the cowl after all to make them work. Wanted an in cowl system, but could not find the correct flex pipes, the ones I did find were offset, one would work, and the third one I ordered that could work doesn't have enough flex in it to bend down 90*.
Old 05-11-2017, 11:44 AM
  #2534
FlyerInOKC
FlyerInOKC's Avatar
Unhappy
It's a plot! A vast anti-R/C conspiracy!
Old 05-11-2017, 01:05 PM
  #2535
acdii
If I could find the materials easy enough I could make when I need. The flange is easy enough, I have metal, its the tubing I can't find.
Old 05-11-2017, 02:16 PM
  #2536
Super08
Super08's Avatar
Aircraft International sells all the parts should you need for building your own headers. MTW makes parts as well including the exhaust flanges to fit DA.
http://www.aircraftinternational.com...aderParts.aspx
Old 05-12-2017, 04:38 AM
  #2537
FlyerInOKC
FlyerInOKC's Avatar
I once made a flex pipe out of some stainless steel tubing I took out of a discarded hot water tank my neighbor threw out. See if you can find a local plumber with one and see if the tubing might will work.
Old 05-12-2017, 05:19 AM
  #2538
acdii
KS Custom Header Parts
I'll keep this one in mind for later. I can always get a spare cowl later on and make a customer exhaust when I have more time. Right now I want to have the plane flying by the end of the month, so ordered a pair of proper mufflers for the DA. They may look ugly sticking out the cowl, but better than not having them at all.
Old 05-15-2017, 04:09 AM
  #2539
Captcrunch44
Well a hole weekend of covering and this is all i got done. And still have the top side of the wing to go.
ID:	2215284   Click image for larger version
Old 05-15-2017, 04:54 AM
  #2540
acdii
Well if we both get ours done in time and flown, then it will be a contest to who has the best looking one, and I think yours is going to win.
Old 05-15-2017, 06:30 AM
  #2541
FlyerInOKC
FlyerInOKC's Avatar
Watch him Capt, I think he is trying to lull you into a false sense of superiority so he can blow pass you!
Old 05-15-2017, 07:00 AM
  #2542
Captcrunch44
His already looks way better then mine. My cover and build skills are mediocre at best
Old 05-15-2017, 08:21 AM
  #2543
acdii
It will all come down to what they look like in the sun. Artificial light can hide a LOT.
Old 05-16-2017, 03:44 AM
  #2544
Captcrunch44
Is there a song theat goes this is the way we cover a plane cover a plan cover a plane. I'm starting to go nuts I think.
Worked on covering last night and only got half of the center section done.
Old 05-16-2017, 04:53 AM
  #2545
acdii
LOL, its the same one used when we glue our fingers to the plane. It's just not appropriate for the forum(or children). I still have to finish the center section before I can even think about covering. Got both flaps done and hinged, still have the leading edges to do, but need to finish the ailerons so that I can get the contours correct. One aileron left to build.
Old 05-16-2017, 06:30 AM
  #2546
FlyerInOKC
FlyerInOKC's Avatar
Talking
The skin you lose when you glue your fingers to the airplane is just another way of leaving your personal touch!
Old 05-16-2017, 11:34 AM
  #2547
acdii
My skin is too tough, I left wood on my fingers instead. It is difficult to unlock the phone though when you have CA on your thumb.
Old 05-16-2017, 12:25 PM
  #2548
FlyerInOKC
FlyerInOKC's Avatar
Lol!
Old 05-17-2017, 03:40 PM
  #2549
Captcrunch44
So here how far we are now. We will see how much we get done tonight
ID:	2215810   Click image for larger version
Old 05-17-2017, 03:47 PM
  #2550
acdii
I can't wait to see that bird out in the sun!
