~~SIG Brotherhood ~~
#1876
I don't remember any strange crashes. But i have flown in some strange place. Like a place sarounded by trees, you had to take off and land from the same hole in the trees, no go arounds. Flew out of a spot were u had to take of and land in a semi circle and i guess the best was the field were you had to chass the cows off the runway before u landed.
#1877
MO
SKYLARY FLYER
I AM 87 STILL FLING 72 MHG KRAFT RADIOS & FUTABA XMITTERS.
I WAS A KRAFT RPAIRMAN FOR A NUMBER OF YEARS. SOME MODELERS ARE CONVERTING THEM TO 2.4 GIGS, BUT I PLAN TO DO THAT ON ONE OF MY 6 KRAFT XMITTERS & SELL THE REST.
STEEL PUSH RODS FOR RUDDER & elevator have been proved at our flying site to be a bad idea. golden rod outer & inner are fine. you can use some carbon fiber push rods as well they dont need an outer tube.
i have run my antenna thru a plastic tube along the bottom of my fuse for years on 72 mhg. yes steel rods can & do act as a reflector or absorber on 72 mhg. you dont need to anchor the push rod tubebut just one place not far from the servo. allow for servo arm swing and rod swing. this is the point to glue the outer tube. the inniner & outer tube have different expansion rates & compensate for temp changes when glued this way. please dont use steel push ros TRAINERMASTER80.
#1878
#1879
He was peeved at me for weeks, but he never tried to jump the fence again.
#1880
OKC
The field with the cows was in San Antonio Texas were i was flying my ace extra 230 doing a nice low level knife edge down the runway when it went crazy and balled itself up on the runway. After I pick up the pieces and got back to the pit area, someone ask what channel i was on and I said 36 why. He said (o no) I said what is this o no s*%# stuff. He said ( we don't fly on 36 round here do to interference issues) I said thanks for telling me now.
I am not blaming anyone I should've done a more thorough radio check before i took off, the funny thing about it, it was intermittent problem.
#1881
OKC
#1882
OKC
#1883
That is true lucky for Me i always carry an extra RC&TX cristal with me. I just switch it out on my 4*60 and the flew the wing off and had great weekend
#1884
SKYLARY FLYER
OMG, you guys are FUNNY! If I tried some of your stunts my other half would put ME in a dog collar and push the button to see what would happen (knowing full well what would happen). You remind me of a story/joke I saw on the web some time back. Pretty sure I saved it to the 'puter - might just have to copy it for here. I laughed until I couldn't see the screen anymore. Yeah, gonna have to look for it.
The Belgian/QH thing - if I did that to my arabian, he'd probably plant it back down my throat (or up my rump). OMG, funny!!!!!
Understood about the Ch-36 thing. My own field has an issue with ch-44, but only in one spot, about 100'x100' and ground to about 40' high. Directly between the town garage and town offices - GOTTA assume it's a microwave antenna beam I'm getting near. Learned a long time ago to do my approach over this area (when the wind demands it) a bit higher and drop after I clear it. Only one plane's effected by it - my 1967-era DeBolt Champ Mk-II. When I got into the area (always on landing approach) the plane would go to full throttle and pull up sharply. She'd climb like a homesick angel to about 40-50' and then settle back into her approach. Happened 6-7 times before I got smart.
#1885
Off topic - only a guy would do this
Found it!!!
OK guys, this is an example of my totally strange sense of humor (or what my wife calls "my wierdness"). And, let me apologize first, before you even read it. SORRY...
Only A Guy Would Do This
A man goes to the store to buy his lovely wife a "pocket Taser" for their anniversary.
Last weekend I saw something at Larry's Pistol & Pawn Shop that sparked my interest. The occasion was our 22nd anniversary and I was looking for a little something extra for my wife Toni. What I came across was a 100,000-volt, pocket/purse-sized taser. The effects of the taser were supposed to be short lived, with no long-term adverse affect on your assailant, allowing her adequate time to retreat to safety.... WAY TOO COOL!
Long story short, I bought the device and brought it home. I loaded two triple-a batteries in the darn thing and pushed the button. Nothing! I was disappointed. I learned, however, that if I pushed the button AND pressed it against a metal surface at the same time; I'd get the blue arch of electricity darting back and forth between the prongs. Awesome!!! Unfortunately, I have yet to explain to Toni what that burn spot is on the face of her microwave.
Okay, so I was home alone with this new toy, thinking to myself that it couldn't be all that bad with only two triple-a batteries, right?!!!
There I sat in my recliner, my cat Gracie looking on intently (trusting little soul) while I was reading the directions and thinking that I really needed to try this thing out on a flesh & blood moving target. I must admit I thought about zapping Gracie (for a fraction of a second) and thought better of it. She is such a sweet cat. But, if I was going to give this thing to my wife to protect her self against a mugger, I did want some assurance that it would work as advertised. Am I wrong?
So, there I sat in a pair of shorts and a tank top with my reading glasses perched delicately on the bridge of my nose, directions in one hand, taser in another. The directions said that a one-second burst would shock and disorient your assailant; a two-second burst was supposed to cause muscle spasms and a major loss of bodily control; a three-second burst would purportedly make your assailant flop on the ground like a fish out of water. Any burst longer than three seconds would be wasting the batteries.
All the while I'm looking at this little device measuring about 5" long, less than ¾ inch in circumference; pretty cute really and loaded with two itsy, bitsy triple-a batteries thinking to myself, "no possible way!"
What happened next is almost beyond description, but I'll do my best.....
I'm sitting there alone, Gracie looking on with her head cocked to one side as to say, "don't do it master," reasoning that a one-second burst from such a tiny little ole thing couldn't hurt all that bad. I decided to give myself a one-second burst just for the heck of it. I touched the prongs to my naked thigh, pushed the button, and HOLY MOTHER, WEAPONS OF MASS DESTRUCTION@!@$$!%!@*!!!
I'm pretty sure Jessie Ventura ran in through the side door, picked me up in the recliner, then body slammed us both on the carpet, over and over and over again. I vaguely recall waking up on my side in the fetal position, with tears in my eyes, body soaking wet, both nipples on fire, testicles nowhere to be found, with my left arm tucked under my body in the oddest position, and tingling in my legs. The cat was standing over me making meowing sounds I had never heard before, licking my face, undoubtedly thinking to herself, "do it again, do it again!"
Note: If you ever feel compelled to "mug" yourself with a taser, one note of caution: there is no such thing as a one-second burst when you zap yourself. You will not let go of that thing until it is dislodged from your hand by a violent thrashing about on the floor. A three second burst would be considered conservative.
SON-OF-A-.. that hurt like %$#@&!!! A minute or so later (I can't be sure, as time was a relative thing at that point), I collected my wits (what little I had left), sat up and surveyed the landscape. My bent reading glasses were on the mantel of the fireplace. How did they up get there??? My triceps, right thigh and both nipples were still twitching. My face felt like it had been shot up with Novocain, and my bottom lip weighed 88 lbs.
I'm still looking for my testicles? I'm offering a significant reward for their safe return.
Still in shock,
Still in shock,
#1886
Don't ever put something that funny on here again, took me 5 minutes to finish reading It, iwas laughing so hard. I haven't laughed that much in while. Took ten minutes to write this out had to stop and dry my eyes twice.
#1892
Hey Hydro - I'm betting a lot more than just his planes are grounded.
#1894
Only if she wants to have kids in the foreseeable future. If not, she may have fed them to a local dog as a snack or threw them in the trash if she didn't know what they were
#1896
Should be - probably actually somewhat of an overkill, but you'd always have MORE THAN ENOUGH power. Kit calls for 50-60cc.
#1900
[QUOTE=c-crunch;12259344]OKC
The field with the cows ..., someone ask what channel i was on and I said 36 why. .../QUOTE]
Must be the cows, A field i used to fly at had cows, and a problem with CH 36 (that I flew on). Another problem was that the cows were kept off the runway by an electric fence just about 50 feet parallel to the runway. If you landed (crashed) where the cows were, you had to very carefully climb over the energized fence to get the plane (pieces), The cows were not a problem, they kept away from the runway while we were flying.
Another field was built on a landfill, and aside from the runoff pond that would probably dissolve your engine and the planes finish, there was a resident llama, AND an ostrich, free to roam the field where we flew. The llama would pick at your hat and spit at you if you protested, and the ostrich would try to eat the rubber bands holding your wing on. The irregular field surface did, however, have, in the middle of the runway, a slope much like a jump jet ramp that could help you get airborne if the grass was too high (often), or, more likely, thrust your plane into the air before Vr
Two other fields opened up soon after those experiences
