Reload this Page >
Balsa USA Stingray 120
Old 03-02-2014, 10:19 AM
bicyclemonkey
My Feedback: (7)
bicyclemonkey's Avatar
Default Balsa USA Stingray 120 Build
Which Hitec servos would you guys recommend for this kit? I've started building it and I'm close to mounting the servos. I've always used the cheap Hobby King servos in ARF's but since I've put so much time into a kit, I would feel a little more peace of mind using a "higher quality" servo.
Here are the specs...It's basically like a Sig Four Star 120 but is supposed to be a little lighter.
ID:	1981939   Click image for larger version
ID:	1981940   Click image for larger version
ID:	1981941   Click image for larger version
Old 03-02-2014, 10:25 AM
TLH101
My Feedback: (90)
TLH101's Avatar
I built one several (15+) years ago. Flew it with a Fox .78, and used HiTec HS-422 through out. Never a problem. It's a pretty slow flying model, so at the most you need hi-torque standard servos. This plane is a hoot to fly.
Old 03-02-2014, 10:41 AM
bicyclemonkey
My Feedback: (7)
Did you go with a single elevator servo or one for each elevator half? The dowel rod connecting the two halves seems kind of flimsy. I was thinking of going with a Saito 150.
Old 03-08-2014, 07:25 PM
bicyclemonkey
My Feedback: (7)
If anyone's interested I can post pics of my build progress. This is my first traditional kit. I've only built one other kit and it was a laser cut wing a tail kit for a Slow Stick so it wasn't even a full build.
Here's what it looks like inside the box.
Old 03-08-2014, 10:36 PM
bicyclemonkey
My Feedback: (7)
The wing taking shape.
ID:	1981965   Click image for larger version
Old 03-09-2014, 08:29 AM
bicyclemonkey
My Feedback: (7)
More wing pics
ID:	1981967   Click image for larger version
ID:	1981968   Click image for larger version
Old 03-09-2014, 08:36 AM
JRgraham
Looking good
Like TLH101 said, you shouldnt need much more than decent high torque standard servo's for this. Something like the futaba 3152's would be perfect, or whatever other brand similar in spec's. It does not have massive control surfaces, so you don't need monsters in it.
Old 03-09-2014, 09:10 AM
bicyclemonkey
My Feedback: (7)
I went with Hitec HS=425BB for everything except the rudder which is a HS-645MG.
I'm not sure about the elevator setup though. The dowel rod joiner seems kind of flimsy but that's what the plans called for. I've been thinking about cutting the dowel and using two servos for the elevator.
ID:	1981970   Click image for larger version
ID:	1981976   Click image for larger version
Old 03-09-2014, 09:35 AM
JRgraham
Or, you could stick with the single servo, and just use a Y on the elevator end of the pushrod.
Old 03-13-2014, 11:42 AM
bicyclemonkey
My Feedback: (7)
I think for now, I will go with a single elevator servo...Here's more progress.
I made a mess getting the wing halves glued together. Next will be sheeting the wings.
ID:	1981984   Click image for larger version
ID:	1981985   Click image for larger version
Old 03-16-2014, 04:04 PM
bicyclemonkey
My Feedback: (7)
Getting the wings sheeted.
ID:	1981987   Click image for larger version
ID:	1981988   Click image for larger version
ID:	1981989   Click image for larger version
ID:	1981990   Click image for larger version
Old 03-16-2014, 04:08 PM
bicyclemonkey
My Feedback: (7)
It wasn't in the manual but I added shear webbing on the spars for added strength.
ID:	1981992   Click image for larger version
Old 03-17-2014, 10:03 AM
JRgraham
Looking good!
Old 03-17-2014, 12:02 PM
bicyclemonkey
My Feedback: (7)
I'd like to thank Balsa USA for making me a better modeler by making me shape square stock for the leading edge instead of supplying me with a round/half circle piece.
ID:	1981994   Click image for larger version
Old 03-18-2014, 06:13 AM
JRgraham
They are just looking out for you!
Old 03-18-2014, 11:00 AM
bicyclemonkey
My Feedback: (7)
lol, lucky me..
Getting closer.
Old 03-18-2014, 12:40 PM
bicyclemonkey
My Feedback: (7)
OK, I'm calling it quits here.
Old 03-18-2014, 12:53 PM
balsa brain
I learned to fly with a BUSA Easy 100 and built about five of them before moving on to something with a little more performance which was a Stingray 40. I always wanted to build the 120 but never got around to it. I see they still sell the plans so maybe someday.... I think you would be okay with the dowel rod between the elevator halves if you epoxied it in and then do a wrap around it up to the balsa wood with some fiberglass cloth. BTW, BUSA makes you earn what you end up with with all the sanding and carving you have to do to build one of their kits, lol.
Old 03-18-2014, 01:01 PM
balsa brain
Those magnets look familiar. Where did you get them? I forgot to mention in my first post that your build is looking real nice. I think you will love that plane.
Old 03-18-2014, 05:10 PM
bicyclemonkey
My Feedback: (7)
Thanks for the comments. I got my the magnets from this guy.
http://www.magnetsource.com/airfieldmodels/
Old 03-19-2014, 05:29 AM
bicyclemonkey
My Feedback: (7)
Cap stripping the wing now. Had to cut a 1/4 inch strip of balsa to cap each rib.
Before
After
The outer ribs got a 1/2 inch cap
ID:	1982074   Click image for larger version
ID:	1982075   Click image for larger version
Old 03-20-2014, 05:52 AM
bicyclemonkey
My Feedback: (7)
ID:	1982259   Click image for larger version
ID:	1982260   Click image for larger version
Old 03-21-2014, 07:51 AM
Bob Yeager
Bob Yeager's Avatar
Very nice job. This is a wonderful airplane. My old flying buddy in Wyoming, Fred Hildebrand, has been flying one for years. I could never find a kit.
Old 03-21-2014, 07:59 AM
bicyclemonkey
My Feedback: (7)
Thanks! I can't wait to get this finished...first real full build and I can't wait to start the next!
Going to "upgrade" the landing gear. The one's included in the kit are pretty lame. I'm going to add some wheel pants too. This is the Sig Four Star 120 landing gear.
This is the look I'm going for. I even like the color scheme.
ID:	1982265   Click image for larger version
ID:	1982266   Click image for larger version
ID:	1982267   Click image for larger version
Old 03-22-2014, 09:41 PM
bicyclemonkey
My Feedback: (7)
Got the fuselage sides laid out and ready to laminate
