A little help Converting a funaero albatross DII to a DIII
FL
I finally got around to this kit again it got stuck on the back burner. I was looking for fun aero and it seems they are no longer around. I was hoping to get a copy of the DIII wing plans from the company to make the change from the DII's but to no avail. I can do the wing tip angles but I was hoping to to get length and width of there DIII's kits wings and mounting points for there v struts. Any help in this issue or if you can provide info, old plans or copy's it would be great. I really would like to finish this kit and get her flying as a DIII.
FunAero Albatros DIII plans
I have the DIII wing plans (Sheet 2), and I need the fuselage plans (Sheet 1). This is the Fun Aero Albatros DIII kit, with a 65" span.
Possible we could help each other out here? I don't know if the DII kit and the DIII kit are the same, or totally different. Let's chat!
Don.
Don.
