Balsa USA Brotherhood
#501
Mine, unfortunately weighs in at 25 lbs. I can't remember the last time I built a plane that was this tail heavy? The finished weight was 20 lbs. then my friend came over with his balance scales. I had to install 5 lbs in the nose!! Try to find a place to install 5 lbs....just about impossible! The plane flys great and impressive in flight. The weights however, tend to add to engine vibration and reeks Havoc on the plane's detail. Good Luck, hope it works out better for you.
Ray.
Ray.
#502
Thanks.. my plane as the Fuji 34 4 banger in it.. I had a buddy of mine spin the numbers for me and this is what we came up with. (see below)...
Never the less I have a tick more work to do but its close.. keep yaall posted as we get ready to fly it.
¼ balsa USA D7
2225 sq in area
That’s 15.45 sq ft. Say the weight is 25 lbs flying. That’s 400 ounces. Wing loading is 25.9 oz/sq ft. computed stall speed should be 19mph. You generally want a static pitch speed of 2.5 to 3 times times stall speed, so 47.5
To 57mph should be the target range. Calculating 6000 rpms with a 22X8 (to approximate the 22X6X10) results in 394 ounces static thrust, 45.4mph pitch speed. Thrust good for what you want with that plane, pitch speed close but a touch under. If it will handle a 22X10 you should be right in the perfect range both thrust and speed. As long as it will stay at or above 5600 rpms. If not, I’d sacrifice some static thrust for a bit more pitch speed which would allow you to throttle back a lot more in flight. That would mean something like a 20 or 21 inch prop with 10~12 pitch.
¼ balsa USA D7
2225 sq in area
#503
I had to add 2 lbs of lead to balance. It is important to think light in the tail when building these planes. Many times the tail skid etc. is the culprit. What engines are you guys using, as 25lb is a little high. Mine started with a G38, but was very anemic, so I installed a DLE 55 and it is a much better plane now. The large prop really helps on landings.
#508
BUSA brothers
#1 3136 Victoria, Australia
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#6 surmovik60 VA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#11 jwrich OK USA
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46 iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#62 ashby NSW Australia
#63 R/C Art IN USA
#64 on_your_six MD USA
#65 Highflyer2 GA USA
#66 dddaviddean NJ USA
#67 Quagmire CA USA
#68 pending CA USA
#69 ratshooter TX USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#73 sdcranford MO USA
#74 buzzard bait NY USA
#75 chadasmus KY USA (BUSA Team Pilot, Builder and Designer)
#76 fokv25 IN USA
#77 Dynamic! WI USA
#78 WinterHawke WI USA
#79 t6racer NSW Australia
#80 NM2K GA USA
#81 rcjunky67 FL USA
#82 AndyF IN USA
#83 freefall2907 IA USA
#84 a65l VA USA
#85 Grimracer IL USA
#86 Corsair2013 UT USA
#87 Karp 050555 PA USA
Welcome Corsair, keep us updated, nice kit!
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#11 jwrich OK USA
#12 wwoneguy MD USA
#14 rcmiket TX USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#35 Vampire PA USA
#38 SRQFlyer FL USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#51 otterrc FL USA
#53 lazyace NY USA
#57 AMA74894 MN USA
#58 squidman TX USA
#61 optech CA USA
#63 R/C Art IN USA
#67 Quagmire CA USA
#68 pending CA USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#76 fokv25 IN USA
#77 Dynamic! WI USA
#80 NM2K GA USA
#82 AndyF IN USA
#84 a65l VA USA
#512
PA
I've only had it running once but it did ok. At first it was running rough and then I saw I had some loose bolts so I shut it down, tightened everything, and restarted the engine. It was now smooth as silk. It transitioned well and sounded great. This is a well built quality engine and well worth the price. It doesn't have a muffler but it only needs the pipe it comes with. I put on a Higley nut to dress it up and for using my starter. I guess in time I won't need the starter. It's done with break in at 25 to 1 so I'll now run it at 32 to 1 and get it into the air ASAP. It looks like a big OS with a blue head and should perform well on a 1/4 scale WWI plane.
#513
RCU Forum Manager/Admin
My Feedback: (9)
I've interviewed you many times in Toledo doing the "latest greatest Aquacraft boats". I didn't realize you were such a skilled scale plane guy as well. You have earned a new level of respect in my book my friend. Missed seeing you in Toledo this year. Carol said you were off in Wisconsin doing some boat race or something like that. Hopefully we'll get to say "hi" next year in Toledo.
Ken
#523
Hey Chad why don't you start a poll thread asking what would be the favourite 1/6 plane the customers would like?
I personally would like a D7 and Albatross, you just can't please everyone though.
#524
I have to assume that the more complicated models, like the Albatros and the Pfalz are less likely. It would seem an Albatros in 1/4 scale should come first, as I know that would be a good seller. The Fokker's are easy as they are more straightforward designs and less complicated. Not to mention, just blowing them down in scale from the larger offerings is doable.
