Reload this Page >
Balsa USA Brotherhood
Old 12-22-2014, 03:32 AM
  #751
David Gladwin
David Gladwin's Avatar
Put me down, formerly a 1/4 scale Cub with an OS 160 (crashed in bizarre circumstances after 100 hours in the air) and now building a BUSA 1/3 scale Cub as L4 with OS Pegasus 320 . A relaxing change of pace from jets, and working with wood again is such a pleasure. Can't be happier with completeness and quality etc. of BUAS kits.
David Gladwin.
Old 12-22-2014, 07:58 AM
  #752
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome David, I knew there were other Balsa USA builders out there. I was in your wonderful country years ago when I was flying out of Germany, very friendly people. Please post pictures of your build, you will love flying the 1/3 scale J-3 Cub.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
Merry Christmas to all
Rich
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#6 surmovik60 VA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#11 3136 Victoria Austrialia **
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland **
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46 iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#62 ashby NSW Australia **
#63 R/C Art IN USA
#64 on_your_six MD USA
#65 Highflyer2 GA USA
#66 dddaviddean NJ USA
#67 Quagmire CA USA
#68 pending CA USA
#69 ratshooter TX USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#73 sdcranford MO USA
#74 buzzard bait NY USA
#75 chadasmus KY USA (BUSA Team Pilot, Builder and Designer)
#76 fokv25 IN USA
#77 Dynamic! WI USA
#78 WinterHawke WI USA
#79 t6racer NSW Australia **
#80 NM2K GA USA
#81 rcjunky67 FL USA
#82 AndyF IN USA
#83 freefall2907 IA USA
#84 a65l VA USA
#85 Grimracer IL USA
#86 Corsair2013 UT USA
#87 Chevelle NY USA
#88 eagledancer FL USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09 IN USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#96 Shoestring MN USA
#97 David Gladwin United Kingdom **
Old 12-22-2014, 08:43 AM
  #753
AndyF
AndyF's Avatar
Originally Posted by vertical grimmace
Not to mention, these later WW1 aircraft were not marginally powered, as demonstrated by this full scale Fokker DVII with an original BMW engine. Being underpowered seems to be a tall tale. Of course, relative to everything that came after them, but they were still pretty fast for the time.
For those that have not flown their WW1 aircraft with a larger diameter prop, do your self a favor and set one up that way. They really do better with them.
https://www.youtube.com/watch?v=gZZ82xiWP7w
VG,
Question for you. I have an RCGF 60 CC gas engine that I plan to put on my 1/3 scale pup. I would like to run a scale size prop, which I think will be a 33" - 36" diameter. Any idea of a 60 CC engine can handle that much prop? I would set it up so there would be no way to go to full throttle so that I wouldn't bog down the engine. Do you think that would work or would I be better off looking for an engine and gear reduction setup?
Andy
Old 12-22-2014, 09:29 AM
  #754
Karp050555
The prop size for a 60cc engine is usually 24-10 so I can't see how an RCGF is going to swing a 33-36" prop directly. If you want to use that size prop you'll have to go with a belt reduction system.
Old 12-22-2014, 09:52 AM
  #755
Horsepoweraviation
My Feedback: (50)
Horsepoweraviation's Avatar
Originally Posted by karp050555
the prop size for a 60cc engine is usually 24-10 so i can't see how an rcgf is going to swing a 33-36" prop directly. If you want to use that size prop you'll have to go with a belt reduction system.
+1
hpa
# 95
Old 12-22-2014, 10:20 AM
  #756
David Gladwin
Thank you for your welcome. The 1/3 Cub was started some years ago but has now resumed.
I used to fly my 1/4 scale Cub from my garden years ago, my neighbours complained when it was crashed and it's flying stopped, they missed it's gentle purr. (OS 160 twin) !
I hope to do some glider towing with this Cub too and later perhaps put on floats. I used to have great fun flying the real J3 Cub on floats at Jack Brown's seaplane base near Orlando when I was on layover there (I was a 767 captain, but the Cub was more fun!).
I will try and post a few pictures later.
Merry Christmas !
David.
Old 12-22-2014, 10:32 AM
  #757
vertical grimmace
vertical grimmace's Avatar
Originally Posted by AndyF
VG,
Andy
I think you will have to go with a reduction drive such as this. http://www.vogelsang-aeroscale.com/g...eschlundt.html
Otherwise, a significantly larger engine would be needed. I do not think throttling back would be a good idea.
Old 12-22-2014, 10:45 AM
  #758
AndyF
AndyF's Avatar
Okay thanks, guys, I'll have to come up with a plan "B". I think the G38 might be too small for my pup which could be in the 40 lbs range after all of the scale detailing is finished.
Andy
Old 12-22-2014, 02:08 PM
  #759
Karp050555
Perhaps removing some of that scale stuff is the answer.
Old 12-22-2014, 02:50 PM
  #760
rickj
My Feedback: (213)
rickj's Avatar
I would like to join the brotherhood.
rickj
Old 12-22-2014, 02:59 PM
  #761
vertical grimmace
I have seen them fly with G62's just fine. But if you want that big prop, you will have to install an engine that will spin it. Something in the 120cc range most likely.
Old 12-22-2014, 04:25 PM
  #762
AndyF
AndyF's Avatar
That's definitely not the answer.
Andy
Old 12-22-2014, 04:32 PM
  #763
AndyF
AndyF's Avatar
Vogelsang has a reduction drive for the G45 and the G62. The only thing I don't like is the big flywheel that is right up front and sticks out through the dummy engine. Maybe I just need to save up for a nice big radial engine to fill the cowl.
Andy
Old 12-22-2014, 04:42 PM
  #764
vertical grimmace
That video claims a 32 x 20 prop! That would do it. I think the reduction on the G62 is your best bet, and see if you can't shoe horn your detail around it. They do have to styles, inline and sideways. I am gonna guess this would work.
Old 12-22-2014, 04:51 PM
  #765
AndyF
AndyF's Avatar
Some are flying the 1/3 scale pup with the scale detailing with the G38 and the reduction drive. I was thinking that the G45 might work too.
Andy
Old 12-22-2014, 06:26 PM
  #766
rich6170
rich6170's Avatar
Default Soviet Sopwith Pup Balsa USA 1/4 scale
Just thought I would post a couple photos of Balsa USA's 1/4 scale Sopwith pup I built to match our Full size plane. Completed last year it was built for WW1 Dawn patrol 100 year celebration at National Museum of the United States Air Force in Dayton Ohio. This is the Full scale plane... Several modifications were made to the BUSA kit to match the full scale plane. Engine used is a Saito GN 180.
I also have a 1/4 scale Fokker DR1 that I built several years ago.. Also BUSA kit.
The kits are fun to build and provide a great base to add any level of scale features that you want.
Great thread Guys!
Soviet Sopwith Pup Project
Springfield OHIO
ID:	2057089   Click image for larger version
ID:	2057090   Click image for larger version
ID:	2057091   Click image for larger version
ID:	2057092   Click image for larger version
Old 12-22-2014, 06:50 PM
  #767
rickj
My Feedback: (213)
rickj's Avatar
Hi Rich,
I would like to join the BUSA brotherhood. As you requested, here is my information.
I did not know this would be so involved. Anyway, I have been with BUSA for 20 some years.At this time I have a 1/3 scale Cub, G62,
1/4 scale Cub on floats, OS160 twin, 1/3 scale Morane Saulnier, G62, 1/4 scale Aeronca C3, OS 12 twin, 1/4 scale N17, G26. I had a
1/3 Sopwith Pup (my baby), RCGF 100cc twin and it was lost this year due to a elevator problem. At this time I am building another 1/3 Pup. I
also have underway a 1/4 Spad, almost ready for covering, a 1/4 Sopwith Baby on floats, A 1/4 scale D VIII kit and a 1/3 scale N 17 kit.
My son flies a 1/4 scale DR1, 1/4 scale Sopwith Pup and new for 2015 he has a 1/3 DR1, DA 85cc. All of my WWI planes covered in Solartex,
are hand painted (no decals) and rib stitched. The landing gear in the 1/3 planes are steel tube welded and designed by me. My radios are
Futaba with a mixture of Futaba and Hitech servos.. I was into and still am WWII planes and high wing plans from the 30`s. In the last 3
years, the WWI planes have taken over. 10 years ago I started a War Bird event for our club and 3 years ago I started a Dawn Patrol for our
club. This year from our 2 fly ins, our club donated over $1600.00 to the Wounded Warrior Project.
Well I hope this is enough information to get me started.
Thanks, Rick
Also, I have 163 good rating on RCU.
Old 12-23-2014, 07:23 AM
  #768
bradpaul
bradpaul's Avatar
I guess I am the odd man out running electric in a 1/4 scale BUSA Nieuport 11 and Fokker Dr1.
Before any comments on missing the engine sounds, I am looking at a sound system from Mr. RC Sound http://test.mrrcsound.com/
The version 4.1 system with 3 transducers and a base transducer should put out well over 100db. I will get the WW1 sound chip that has both LeRhone and Gnome start up, engine, shut down and machine gun files.
On the electric systems, I try to match the Kv, prop, voltage and amps to put out ~200oz thrust at 6000 rpm. No vibration and ~15 minutes of flight time. No lead needed to balance just use higher capacity mah batteries in the nose as weight.
Brad
Old 12-23-2014, 07:38 AM
  #769
AndyF
AndyF's Avatar
Brad
Hi Brad,
You are not alone. I have read about guys who are running electrics in 1/3 scale WWI planes. That is another option that I am considering for my pup so I can swing a scale sized prop. I'm just not sure what I'm going to do yet.
Andy
Old 12-23-2014, 07:51 AM
  #770
jwrich
My Feedback: (17)
jwrich's Avatar
Rich6170, are you in the Balsa USA Brotherhood? You have some beautiful planes. I was in Dayton for the Dawn Patrol this year, I think I remember your Pup with with the red star. Let me know if you want to become a brother.
Merry Christmas
Rich
Old 12-23-2014, 07:59 AM
  #771
AMA 74894
Moderator
AMA 74894's Avatar
no bad comments from me regarding electric power (I've heard those sound systems in action and they really ARE pretty cool.)
Wendell Hottmann had a 170 Inch Jenny at Watts over Owatonna this past july, flew absolutely beautifully!
http://www.rcuniverse.com/magazine/a...rticle_id=1574
Old 12-23-2014, 08:25 AM
  #772
rich6170
rich6170's Avatar
Merry Christmas
Rich
Thanks so much.. Sure I would like to be a member. I had a great time with the Guys from BUSA at the event and several of the pilots on the RC side.. It was a bit hectic with so many people crowding around our planes but it was a fun event.
Old 12-23-2014, 08:46 AM
  #773
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome Rich, your number is 98. You are right it was very hectic, I enjoyed every minute of it. This was my 4th trip to the Dayton Dawn Patrol Rendezvous and this was the best ever, beautiful weather, warm temperatures and light winds. We made the early dawn flight three days, I took pictures of my buddy flying as the sun was just breaking. It was great meeting my other friends again. I plan to be at the 2016 event.
Rich
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#12 wwoneguy MD USA
#14 rcmiket TX USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#35 Vampire PA USA
#38 SRQFlyer FL USA
#40 hairy46 WY USA
#41 pettit NC USA
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#51 otterrc FL USA
#53 lazyace NY USA
#57 AMA74894 MN USA
#58 squidman TX USA
#61 optech CA USA
#63 R/C Art IN USA
#67 Quagmire CA USA
#68 pending CA USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#76 fokv25 IN USA
#77 Dynamic! WI USA
#80 NM2K GA USA
#82 AndyF IN USA
#84 a65l VA USA
#87 Chevelle NY USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#98 Rich6170 OH USA
Old 12-23-2014, 09:56 AM
  #774
wildbills21
Count me in the Brotherhood too please, as I am a Team BUSA pilot, builder and the chief mechanic. I keep all the planes flying. Every BUSA plane that is still in the stable is flyable.
Wild Bill
Menominee, Mi
Hometown of BUSA
Old 12-23-2014, 10:09 AM
  #775
rickj
My Feedback: (213)
rickj's Avatar
Hi Rich
